'73 Barracuda manual box work on '71 Charger ? #1147798
12/31/11 07:34 PM
12/31/11 07:34 PM
Buford, GA
I_bleed_MOPAR Offline OP
Buford, GA
Friend has a '73 Barracuda hull w/ manual steering he's willing to let me swap my PS box out with. Will it work? IIRC, '73-up B-bodies are different. Did this carry over to the E-bodies as well?
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: '73 Barracuda manual box work on '71 Charger ? [Re: I_bleed_MOPAR] #1147799
12/31/11 08:26 PM
12/31/11 08:26 PM
Buford, GA
Buford, GA
Looks like '73-4 E-bodies are the same as '73-up B-bodies. Found my answer here.
http://www.carsteering.com/
Tim
'71 Charger 383/727
Re: '73 Barracuda manual box work on '71 Charger ? [Re: I_bleed_MOPAR] #1147800
12/31/11 08:40 PM
12/31/11 08:40 PM
Berwyn, IL
Moparlar Offline
Moparlar  Offline
Berwyn, IL
I think the only difference is the pitman arm. If you use the later pitman arm I think it works.
Larry
Re: '73 Barracuda manual box work on '71 Charger ? [Re: Moparlar] #1147801
12/31/11 08:49 PM
12/31/11 08:49 PM
I think the only difference is the pitman arm. If you use the later pitman arm I think it works. Larry
X2 What Larry said
Re: '73 Barracuda manual box work on '71 Charger ? [Re: I_bleed_MOPAR] #1147802
12/31/11 09:55 PM
12/31/11 09:55 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
Use the barracuda pitman arm.
Re: '73 Barracuda manual box work on '71 Charger ? [Re: RV2] #1147803
01/01/12 10:31 AM
01/01/12 10:31 AM
Buford, GA
Buford, GA
So it will work if I use the 'cuda arm? Good deal. Thanks, guys.
Tim
'71 Charger 383/727
Re: '73 Barracuda manual box work on '71 Charger ? [Re: I_bleed_MOPAR] #1147804
01/01/12 11:05 AM
01/01/12 11:05 AM
State of Corruption
camdog440 Offline
camdog440  Offline
State of Corruption
The splined shafts are different sizes between a manual and a power steering box... make sure to get the steering coupler off of the barracuda too.
Re: '73 Barracuda manual box work on '71 Charger ? [Re: camdog440] #1147805
01/01/12 11:45 AM
01/01/12 11:45 AM
Buford, GA
Buford, GA
I did remember that part (it's a wonder ). The car's a roller he's wanting to sell so I told him I would put it back together w/ my PS box.
Tim
'71 Charger 383/727
Re: '73 Barracuda manual box work on '71 Charger ? [Re: camdog440] #1147806
01/02/12 08:43 AM
01/02/12 08:43 AM
Locomotion Offline
Locomotion  Offline
He'll need the adapter/extension, like Mancini sells, when using a power steering shaft with a manual box because the steering shaft length is different.
The Cuda shaft will be too long to use with the power steering box!
Re: '73 Barracuda manual box work on '71 Charger ? [Re: Locomotion] #1147807
01/02/12 10:02 AM
01/02/12 10:02 AM
Buford, GA
Buford, GA
Already handled. Thanks, Myron.
Tim
'71 Charger 383/727
Re: '73 Barracuda manual box work on '71 Charger ? [Re: I_bleed_MOPAR] #1147808
01/02/12 11:25 PM
01/02/12 11:25 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
arent the manual/power steering columns about one inch different (in length) too---bob
