Re: Source for A-body low tension hood springs [Re: goldmember] #1147511
01/07/12 02:38 AM
01/07/12 02:38 AM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
The A body factory spring is .750" wide the G body spring is .500" wide. Here is a pic of both.
thanks for that man! I will get out to the garage tomorrow morning and measure em up and see
hopefully they will work for me
Re: Source for A-body low tension hood springs [Re: mshred] #1147512
01/08/12 04:53 PM
01/08/12 04:53 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
well I measured the ones I took off the dakota today and they are about .625" wide...in between the g-body and a-body ones
I always thought it was the thickness of the spring as opposed to the width that determined its tension
Re: Source for A-body low tension hood springs [Re: mshred] #1147513
01/08/12 07:02 PM
01/08/12 07:02 PM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
most glass hoods are heavy,those springs you have may work fine.
