Re: What size Big Block
[Re: 1967dartgt]
#1142824
12/28/11 09:30 AM
12/28/11 09:30 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Mr.Yuck if you are talking about Bill's blue demon it is a 499 with a 670 lift roller.He bought the motor out of my brothers full interior 30x10 tire 69 dart with mufflers and went 9.30's at 146.And 1967dart gt if you never see a street car with a big block run good you need to get out to different tracks more often.Not saying they are everywhere but there are some good running ones out there floating around.
Yes they are out there but very few just like small blocks. Its mopars in general not a lot of them. Next time I get down your way I will let you play with my nitrous machine, your brother to with his big block.
67 jeeesh such hate for BB, you know you could of had one that ran as good or better than that SB for 1/2 the price...lol
Yes, bdaz It's Bill demon, I hear he's going bigger next year, same everything except more cubes.
[Re: jim sciortino]
#1142826
12/28/11 11:42 AM
12/28/11 11:42 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Hey Mr yuck you need good heads on a big block to go this fast and everyone in this post has had 440-1 heads. Last time I checked it was a good amount of money for a good set, cnc and rockers intake etc.. It ain't cheap going this fast weather its a big block or small block. I have a lot less in my motor then you think.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 1967dartgt]
#1142828
12/28/11 12:00 PM
12/28/11 12:00 PM
Mr.Yuck
Brookeville, Md
that's why I hit the "bargin bun" here on moparts when I break something. FWIW I think this stock stroke 440 w/ a larger solid roller, maybe more gear would run low 10's easy in an A-body.
[Re: 1967dartgt]
#1142831
12/28/11 12:08 PM
12/28/11 12:08 PM
Mr.Yuck
Brookeville, Md
Long way to go mid 9s from low 10s...and lots of money.
nothing a stroker kit, bigger stall and better intake/carb can't fix. low 10's are w/ the ported stage VI heads and factory 6 pack. But hey I'm happy w/ the way it runs. I drive it to the track and home (barring breakage) Should be close to 11.0's come spring.
[Re: sixpackgut]
#1142836
12/28/11 12:34 PM
12/28/11 12:34 PM
1967dartgt
Hilltown Pa
I though the SRs where the base head. I though all the 440-1 heads flow better. Isn't a ez just a 440-1 with standard exhaust ports?
[Re: pittsburghracer]
#1142840
12/28/11 12:46 PM
12/28/11 12:46 PM
1967dartgt
Hilltown Pa
NO found it works well with radials short, hard, fast burn out that is done in third gear.
