Re: Bellhousing run-out / offset dowel pins
[Re: Crazy68Dart]
#1142508
12/26/11 06:35 PM
12/26/11 06:35 PM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
So, getting the old dowel pins out, pair of vise grips is chewing them up pretty good. They are turning, but just barely.
I am guessing the best way to do this is with acetylene and get things real hot?
I don't have a set of torches which could be a problem.
I've had a bit of luck standing the block vertically on several pieces of plywood then attaching the vice grips to the dowel and then a cherry picker to the vice grips. Start to lift the block and the dowels should come out. If they still don't come out, get the block 1" of the ground and 'hold back' on the vice grips while spinning the block slowly. That should be all it needs.
[Re: John_Kunkel]
#1142510
12/27/11 10:33 AM
12/27/11 10:33 AM
Posts: 4,920 Joplin, MO USA
Robbins
Joplin, MO USA
So this is needing to be done on all bellhousings including stock, then?
Moparlee
[Re: John_Kunkel]
#1142511
12/27/11 11:19 AM
12/27/11 11:19 AM
Posts: 19,682 north of coder
moparx
And here it is. The bellhousing was center-bored on a specific block and stayed with it throughout the assembly process.
john, was this true with torqueflites as well ? ![](/ubbthreads/images/graemlins/beer.gif)
[Re: Robbins]
#1142512
12/27/11 01:28 PM
12/27/11 01:28 PM
Posts: 75,125 A Banana Republic near you.
JohnRR
I would have to say yes if you are putting a bellhousing on a block that it wasn't originally mated to when machined.
[Re: moparx]
#1142513
12/27/11 01:30 PM
12/27/11 01:30 PM
JohnRR
I don't think it would be because you can't get the torque convertor into the trans or easily assemble the trans wit hit bolted to the block and the reason that a FLEX PLATE is used ... but if you have problems eating pump seal and bushing a check of the trans to engine runout would be a good idea.
[Re: Robbins]
#1142515
12/27/11 01:37 PM
12/27/11 01:37 PM
JohnRR
That figures.....cause I already put it back together.
Well just , if you have a problem with your clutch or eating pilot bearings/input shaft bearings then you know what to look at. I put aa alum. 513 bell on a 69 383 and it was off by a lot in 2 directions.
[Re: JohnRR]
#1142516
12/27/11 02:22 PM
12/27/11 02:22 PM
Posts: 1,212 Canton, Ohio
Crazy68Dart
Canton, Ohio
I tried a little heat with propane torch, no luck. Can spin them, which is pretty tough, but any outward force makes the grips slip off.
I am going to drill/tap and pull them out with a bolt and socket.
383, Hemi 4-Speed, AlterKtion, D60
[Re: Crazy68Dart]
#1142517
12/27/11 02:40 PM
12/27/11 02:40 PM
JohnRR
Unless you have a dowel puller they are hard to get out , plus spinning them isn't a good idea because you screwing up the hole they are PRESSED into .
[Re: JohnRR]
#1142518
12/27/11 09:24 PM
12/27/11 09:24 PM
Crazy68Dart
Canton, Ohio
They are out, holes are cherry.
Drilled/tapped 1/4-20, stacked some 1/2" hardened washers around dowels, threaded a hardened bolt with a nut and washer installed, cranked nut down and pulled them right out.
RobbMc replacements are on the way.
[Re: John_Kunkel]
#1142519
12/27/11 09:45 PM
12/27/11 09:45 PM
Posts: 18,428 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Is that for sure John? I was told all had bellhousings installed because the engines were run, misc. tested and timed before going into the car.
[Re: NITROUSN]
#1142520
12/28/11 02:11 AM
12/28/11 02:11 AM
JohnRR
The picture doesn't lie.
You don't need a trans to start the engine , toss on a bellhousing , flywheel and a starter ...
[Re: JohnRR]
#1142521
12/29/11 05:25 PM
12/29/11 05:25 PM
Crazy68Dart
Canton, Ohio
Got the RobbMc pins installed. After some adjustment runout is .002. Thanks for all the help. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: jbc426]
#1142523
12/30/11 10:59 AM
12/30/11 10:59 AM
Crazy68Dart
Canton, Ohio
I've not checked it. How did you go about this?
Did you check the bell housing laying on its mounting surface and then measure at the trans mounting surface?
Did you then measure the flywheel surface run out and compare the results?
I understand this should be done, but seriously think it might be overkill in my application.
[Re: Crazy68Dart]
#1142525
12/30/11 02:41 PM
12/30/11 02:41 PM
Posts: 3,291 West Coast, USA
jbc426
West Coast, USA
The bore can be lined up perfectly, but if the transmission is slightly cocked to one side when its bolted on, that's not good.
It's a simple check that's very similar to what you've already done, and helps ensure that the transmission shaft centerline is in-line with the crank centerline, and not at an angle to it when the transmission is bolted up to the bell housing.
You can use almost the same measurement process you've been using, except you run your dial indicator along the face of the transmission mounting surface instead of along the bore opening.
You should be able to detect any measurable tilt or angle on the face of the bell housing.
Adjustment to counter the tilt can be made by using very thin steel shims(similar to feeler gauges) next to the mounting bolts on the block to counter any offset. Or, if it's significant enough, you may want to take the BH down too the machine shop and have it squared up.
Be sure to use them on both sides of the bolts, and make the adjusting shims wide enough to evenly distribute the clamping force around the bolts. You can label them and make a diagram, so you know where they go when installing/ re-installing them again later.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#1142526
12/30/11 04:03 PM
12/30/11 04:03 PM
Crazy68Dart
Canton, Ohio
I understand, thanks.
I have setup and measured around the mounting surface, keeping the base on the flywheel. My max variance is .003.
What is the acceptable tolerance for this? I'll need to source some shim stock but that should not be too tough being in Canton, OH.
