Page 17 of 18 1 2 15 16 17 18
Re: hemi super stock heads [Re: StewartP] #1141539
11/19/12 09:20 PM
11/19/12 09:20 PM
NJ
SSDAcuda Offline
SSDAcuda  Offline
NJ
Joe, I don't see that clarifying anything. I hope theres a new rule to follow as that was a waste of ink…
Valve cover bolt holes must remain unaltered and in their original location.
SS/DA 1924
Re: hemi super stock heads [Re: SSDAcuda] #1141540
11/19/12 09:25 PM
11/19/12 09:25 PM
NJ
SSDAcuda Offline
SSDAcuda  Offline
NJ
Heres the link:
http://www.nhraracer.com/content/general.asp?articleid=53432&zoneid=132
Rule amendment is under "stock cyl heads"
SS/DA 1924
Re: hemi super stock heads [Re: SSDAcuda] #1141541
11/19/12 11:03 PM
11/19/12 11:03 PM
detroit area
moderncylinder Offline
detroit area
i sent bruce a picture of a valve cover bolt hole in the intake face last thursday or friday and requested 100% clarification as to what the rule means,, they are supposed to come out with a better wording soon
Re: hemi super stock heads [Re: moderncylinder] #1141542
11/20/12 02:22 AM
11/20/12 02:22 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
How much are you allowed to mill the intake face? I have seen examples where the bottom of the valve cover threads showing, this is obviously a means of acheiving a larger cross section port whilst still meeting the CC requirements?
Alan Jones
Re: hemi super stock heads [Re: LA360] #1141543
11/20/12 11:24 AM
11/20/12 11:24 AM
detroit area
detroit area
thats a good question,, tech has been thinking about it for a few months now
Re: hemi super stock heads [Re: moderncylinder] #1141544
11/21/12 08:33 PM
11/21/12 08:33 PM
California
E
Erik Jones Offline
Erik Jones  Offline
E
California
I think the rule is as clear as it can get. It has been clear for as long as the rule has been in place. The only problem is that it wasnt enforced.
As a Stock & SuperStock cylinder head guy i think the rule needs to be taken as is and the subject needs to be dropped.NHRA has done there job on making this rule clear and now they just need to enforce it and stay within the guidlines and wording!!! Its pretty cut and dry guys.
No Disrespect to anyone but lets move on and let the chips fall where they may!
Re: hemi super stock heads [Re: Erik Jones] #1141545
11/21/12 09:46 PM
11/21/12 09:46 PM
NJ
SSDAcuda Offline
SSDAcuda  Offline
NJ
The problem with that theory is NHRA has let this stuff go for so long, not only are 75% or more of the AH racers current heads illegal, but all their old stuff also…
You want to talk about class killer…
And No, I'm not currently affected. My SS/DA hemi heads are legal to the rules and my AH stuff will be raced in bracket mode in local ECSSSA circuit races. Makes alot of VERY expensive current hemi heads worthless…except for AH circuit racers like myself
SS/DA 1924
Re: hemi super stock heads [Re: SSDAcuda] #1141546
11/21/12 11:58 PM
11/21/12 11:58 PM
Dyno1 Offline
Dyno1  Offline
And mine. Dyno
Re: hemi super stock heads [Re: Dyno1] #1141547
11/22/12 03:55 PM
11/22/12 03:55 PM
detroit area
detroit area
Dan,,, you have old Barton stuff from marvel/bàughman,, going by what Eric says they are illegal,,, everybody at Indy this year was illegal going on what Eric says,,, if you see the valve cover bolt hole exposed in the int face,, it's illegal,, rule says int face may not be cut into any part of screw hole,,, any part,, tech says that means at the v cover sealing surface,, but if you listen to Eric and go as written,, it's any part,, so if that is enforced,, I'd say one person will have the advantage
We need this clarified
Happy thanksgiving to all
Jeff
Re: hemi super stock heads [Re: moderncylinder] #1141548
11/22/12 06:03 PM
11/22/12 06:03 PM
California
E
Erik Jones Offline
Erik Jones  Offline
E
California
If you take Jeff's reply and change "Erik" to "NHRA" That's pretty much how a rule is supposed to be taken. Not everyone at indy was illegal because none of my stuff has the bolt hole exposed what so ever because i take the rules as "written" and let the Tech officials figure it out.If anyone thinks the 2 cc's you gain from the two different interpretations of the rule is going to be the difference between 8.90 and 8.30 they are sadly mistaken! Im all in favor of NHRA adding "At the valve cover sealing surface" to the rule book, that way people can take the rule as written!!!!!!!
Re: hemi super stock heads [Re: Erik Jones] #1141549
11/22/12 11:21 PM
11/22/12 11:21 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
It seems to me that the amendment is towards "stock" class heads. If it were for super stock, wouldn't it have been under "super stock cylinder heads"? The short block amendments are separated between the two.
Re: hemi super stock heads [Re: Defbob] #1141550
11/23/12 11:58 AM
11/23/12 11:58 AM
NJ
SSDAcuda Offline
SSDAcuda  Offline
NJ
DefBob, at the begining of the super stock rules:
Requirements and specifications for all Super Stock categories are the same as those for Stock Cars - Section 10A - with the following exceptions:
Unless it is written othrwise, the stock rule applies.
And my point in all of this is that if NHRA does something about all the fighting within the class according to the way the rule book is currently written, There will be alot of very expensive junk hemi heads.
There needs to be an ammicable solution and the majority of hemi heads deemed legal. If the valve cover gasket fits and minimal thread cutting involved, there needs to be a cc penalty or spacer made.
As Erik has stated, a few cc's will not kill the performance of these cars that much. And if you think it will, do a new set of heads sans penalty cc's...
SS/DA 1924
Re: hemi super stock heads [Re: Erik Jones] #1141551
11/23/12 12:14 PM
11/23/12 12:14 PM
detroit area
detroit area
if you think there are 2 cc's difference in the intrepretation of the rule,, you,,,,, are sadly mistaken
when the rule book says one thing,, then you talk to tech and they say this is how we meant it,, then you talk to different divisions and they say this,,, when others say that,, you now have 3 versions of the same rule depending on who you ask in nhra,,, or racers
we just need this clarified,, which should happen in the next few weeks
jeff
Re: hemi super stock heads [Re: moderncylinder] #1141552
11/23/12 12:46 PM
11/23/12 12:46 PM
indiana
ss/ah3480 Offline
ss/ah3480  Offline
indiana
what i want to know i how this crap ever gets started??..seems people with the $$ just throw this [Edited by Moparts - Family Friendly Site - Keep it clean] out there and see if it sticks...id say the rule couldnt be any clearer...and if everyones stuff turns illegal so be it...they really knew it wasnt to start with if they can read...eric seems the only sane one here
Re: hemi super stock heads [Re: ss/ah3480] #1141553
11/23/12 05:47 PM
11/23/12 05:47 PM
Louisiana
Spyphish Offline
Spyphish  Offline
Louisiana
SANE? AH Hemi! OXYMORON
was first in line at R&M Black Friday sale. Got some more 1/4"X 20 bolts.
Currently cheating out 49 Ward Lafrance for Great Race in June.
CALMED THE QUAKE!!!(AGAIN!)
Re: hemi super stock heads [Re: ss/ah3480] #1141554
11/24/12 03:09 PM
11/24/12 03:09 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
So going by the rule, as it is written, IF I machine the intake surface around the valve cover bolt and the valve cover bolt threads are untouched, but the intake surface itself has been completely machined away and a new intake surface rigged up to work behind the valve cover bolts, with the intake machined to match this new head intake surface, is this legal? Not in the spirit of the rule, I know, but I do not see where it states the intake has to be completely flat along the surface. Or did I miss this? By the letter of the rule, this would seem to be legal unless it states the head surface has to be completely flat the entire length of the head-intake surface.
Not trying to point fingers at anyone, but it looks like that is what was done on the picture of the Camo head (I am probably wrong). A friend that builds SB Chevys does this and has never been busted.
Seems like it would make some GM & Ford heads illegal too.
Old Geezer Racing
Re: hemi super stock heads [Re: SCATPACK 1] #1141555
11/24/12 05:55 PM
11/24/12 05:55 PM
StewartP Offline
Mopar Vintage Picture Guy
StewartP  Offline
How about posting a picture of the camo head you are referring to ?
Re: hemi super stock heads [Re: StewartP] #1141556
11/24/12 06:45 PM
11/24/12 06:45 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
The picture is on page 8 near the end. The one posted earlier by Charlie. See the green part of the gasket on the intake with the small square opening. It appears to b just there to clear the VC bolt that was left intact. Pet rules, I agree it would b legal.
Old Geezer Racing
Re: hemi super stock heads [Re: SCATPACK 1] #1141557
11/24/12 07:57 PM
11/24/12 07:57 PM
Louisiana
Spyphish Offline
Spyphish  Offline
Louisiana
If you will employ close range industrial terrestrial photogrammetry (why I get the big bucks!) using that single photo and an actual motor you can gain 3210 lbs of info. Two overlapping photos would be better, the standard, but microns are microns, all 25,400 per inch. I now know the angle of the bolt combined with the angle of the mill cut, how many internal threads should be missing, cut, and where. Can reverse engineer cc volume. Can listen and map his incar stuff. Know everything but how to outrun him......
Re: hemi super stock heads [Re: ss/ah3480] #1141558
11/25/12 09:35 AM
11/25/12 09:35 AM
NJ
SSDAcuda Offline
SSDAcuda  Offline
NJ
SS/AH 3480- you don't have an AH car do you?
I don't know anyone that would make a statement like that who even remotely cares about the class
SS/DA 1924
