Re: NE1 else hearing that Diapers will be required on 10.99
[Re: 70dusterjohn]
#1140814
12/21/11 08:57 PM
12/21/11 08:57 PM
Posts: 2,177 ill
dennismopar73
ill
contact D R E they can even help with custom stuff on diapers, as for me I will have one , It's one of those rules they shouldn't have to have , but with the speeds getting ever faster, and the use of sythetic oils, we as racers should have been doing this on our own and not have to have it pushed on us! Maybe some of these crashed drag cars and injured racers, never would have happened? just a thought
[Re: roadhazard]
#1140816
12/21/11 10:03 PM
12/21/11 10:03 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
If this is the case, anybody want to buy a iron headed 448 incher?
I have a 225/6 I can just build. Sure would be less hassle
GREG,,,,???..!!!..it looks like a business opportunity to me!!! Build DIAPERS,,,I'm sure you have a backload inventory of gaskets..get to work,,,expand your business,,make diapers for all of us!! I will let you use my car for a pattern...just come on down..
If you like drag racing, support your local track.
[Re: 604 Hemi GTX]
#1140817
12/21/11 10:15 PM
12/21/11 10:15 PM
Posts: 52,972 Romeo MI
MR_P_BODY
This rule i can agree with, i was planning on putting one on my bracket car. Kevin
Weather I agree or dis-agree I'm getting REALLY FEED UP with that useless bunch of money grabbing A$$ holes telling me what I have to do all the time with my money... thank GOD I dont need a SFI one where it needs to be re-certed every year... I guess I wont attend any NHRA events FLAME ON guys... I dont care
[Re: MR_P_BODY]
#1140819
12/21/11 10:41 PM
12/21/11 10:41 PM
Posts: 20,689 in a cattle trailer down by th...
Guitar Jones
I'm just going to build a bellypan out of left over stuff I have here.
[Re: MR_P_BODY]
#1140820
12/21/11 10:50 PM
12/21/11 10:50 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
On one hand, there's no such thing as "too many" safety devices....within reason for the car's ET/Speed. I haven't seen too many oil downs at the bracket level around here in the last couple of years. That said, the rule making them required for S/ST (an entry level class, by the way...hahahaha) makes S/ST for us a NO GO for this year. If/when they require one for a 10-sec bracket car, we will slow it down to the low-11's...or put it back on the street. That means we're NOT spending $2000 on a Dana, $2500 on a t-brake 727/converter which is money NOT being spent with those vendors. So in our case, everyone loses. Reason it's deal breaker for us is...NO WAY am I getting a diaper on the Duster with a drag link through the pan and 1 7/8" Hookers that nearly touch the pan in 2 places are in the way of everything. Therefore, a tube k-member, motor plate, R&P steering and coil overs, new headers and oil pan would be required. At $5000-$6000-PLUS THAT aint happening. OR, MAYBE we could make it work with a motor plate, new oil pan and custom fenderwell headers. That alone is a $1500-$2000 fix. Screw that. NHRA is doing all they can to reduce car counts even further. This might have been a better idea when there is some economic stability in this country and people are back to work. Of course to complete my RANT, if it were up to me, S/ST would be limted to 130-or less MPH, with NO electronics, OEM front end and OEM rear frame rails and limited to a max 10.5" wide tire. You know, ENTRY LEVEL. The class has really become Stupid STreet allowing tube frame 150+ mph cars. Thanks for listening, I'm done! Merry Christmas!
[Re: cudadoug]
#1140821
12/21/11 10:53 PM
12/21/11 10:53 PM
Posts: 3,101 cincinnati ohio
mcat4321
cincinnati ohio
Merry Christmas!
just build a belly pan.... problem solved
[Re: WadeMetzinger]
#1140823
12/21/11 11:20 PM
12/21/11 11:20 PM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
I'm sure all these people that are too lazy to drain their antifreeze before they go to the track will be all over installing diapers.
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: Evil Spirit]
#1140824
12/21/11 11:36 PM
12/21/11 11:36 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
well it looks like getting ride of my ride may have been a good thing NHRA is getting worst by the day. I have been looking at a bike to get back to going fast on the cheap and it keeps looking better and better.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: Thumperdart]
#1140826
12/21/11 11:40 PM
12/21/11 11:40 PM
Posts: 452 new york usa
pattyboy 572
new york usa
summit diaper 139.00 jegs 80.00 with shipping on sale prices r in racer program pricing!!!!!!not sfi approved nhra only
[Re: pattyboy 572]
#1140827
12/22/11 12:50 AM
12/22/11 12:50 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
whats gunna happen first time someone throws a rod through a diaper and oils down the trak,KEVLAR?
[Re: bonefish]
#1140828
12/22/11 01:31 AM
12/22/11 01:31 AM
Posts: 4,701 On the parachute mount
n20mstr
If you go on yellow Bullet and search you find some good threads on the belly pans. AND you be surprised the NHRA seems to accept a lot less than you read in the rule book about a belly pan. Also on here if you look in the Silverfish progress/chassis build thread there is a pic of a pretty nice belly pan, also Bigtime bob has one on his car. Hey look this really is a Pain but if you kick a rod or whatever, you prob be very happy you or the guy in the other lane had one.
....BAD A$$ STREET CAR.....
