drive shaft what type to use steel/alum/what #1140142
12/20/11 02:20 PM
12/20/11 02:20 PM
nc
E
earthmover Offline OP
E
nc
ok guys got a lot of good help and places to check on trans ..now we need to know about drive shaft ..whats the best to go behind a 620 at about 1000hp..thanks mike
Re: drive shaft what type to use steel/alum/what [Re: earthmover] #1140143
12/20/11 03:20 PM
12/20/11 03:20 PM
South Jersey, NJ
DragDart360 Offline
DragDart360  Offline
South Jersey, NJ
I don't make that kind of power but Dynotech came highly recommended and I'm very happy with mine. http://www.dynotecheng.com/
70 Dart Swinger, 2850 lbs
SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
Re: drive shaft what type to use steel/alum/what [Re: DragDart360] #1140144
12/20/11 03:46 PM
12/20/11 03:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
call Dynotech... they made 2 for me so
far and they will get my call right after the new year
for my Rampage shaft
Re: drive shaft what type to use steel/alum/what [Re: MR_P_BODY] #1140145
12/20/11 04:24 PM
12/20/11 04:24 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I agree about Dynotech..excellent pieces and service, the one i got was i believe an MMC, was sweet, never a problem.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: drive shaft what type to use steel/alum/what [Re: B3422W5] #1140146
12/20/11 04:43 PM
12/20/11 04:43 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
WHAT did you guys go with .....thin moly, alum or CF ?
Re: drive shaft what type to use steel/alum/what [Re: dOc !] #1140147
12/20/11 04:50 PM
12/20/11 04:50 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I went with moly
Re: drive shaft what type to use steel/alum/what [Re: MR_P_BODY] #1140148
12/21/11 12:05 AM
12/21/11 12:05 AM
Cincinnati,Ohio
jcastle1 Offline
jcastle1  Offline
Cincinnati,Ohio
I don't have that kind of power,but I just got a great deal on a moly from Dr. Diff
Give him a call
Re: drive shaft what type to use steel/alum/what [Re: jcastle1] #1140149
12/21/11 02:02 PM
12/21/11 02:02 PM
Out West
408strokerdart Offline
Out West
Length and critical speed are bigger considerations than power level (believe it or not). I know alot of guys running mild steel shafts in 950+ hp cars....because they are short and critical speed is acceptable. I had to go to a 4" aluminum shaft because my 8100 trap RPM and 49" long shaft. Mine is from Inland Empire and I got it at a great price thru John Holt race cars. About any of the reputable places will build you what you need in the correct material.
