Re: lookin to get a glide [Re: Al_Alguire] #1139777
12/20/11 07:34 PM
12/20/11 07:34 PM
Super Scamp Offline
Super Scamp  Offline
looking like Abruzzi will get my $$$
ABRUZZI is the way to go..... Warren Ohio
Just One Man's Opinion Mopar Mafia Racing
Re: lookin to get a glide [Re: Super Scamp] #1139778
12/21/11 11:47 AM
12/21/11 11:47 AM
nc
E
earthmover Offline OP
E
nc
hey guys can some one tell my why the 1.76 gear would be better for the lite car...would it be more cons. or better of the line ..just asking to learn something here....also i think the car will come in about 23/2400 lbs
Re: lookin to get a glide [Re: earthmover] #1139779
12/21/11 12:28 PM
12/21/11 12:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
With all the power at hand you wouldnt need the steeper
low gear... that helps with heavier cars to get the
weight rolling... I have a glide that I was going to
put behind my B-1 M/C 514ci Daytona... (but I sold
the engine).. I set that up with the 1.76 low because
the car would be light(same weight as what your friend
is using
Re: lookin to get a glide [Re: earthmover] #1139780
12/21/11 01:12 PM
12/21/11 01:12 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
3000 lb car with PG, 1.76 gear and 5400 rpm stall. You really don't want or need the 1.80 in a 2400 lb car.
Re: lookin to get a glide [Re: Dabee] #1139781
12/21/11 02:27 PM
12/21/11 02:27 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
why not??
My T/S car went 1.09 60' on motor with 1.80 straight cuts. 1.06 on spray. That is all I've ever use. Dart goes 1.16x with same trans at #2700.
Honestly I don't think the numerical difference in ratio is that big a deal. I just prefer a straight cut gear, especially in a doorcar.
Re: lookin to get a glide [Re: MegaDart] #1139782
12/22/11 01:55 AM
12/22/11 01:55 AM
ky
68roadrunner Offline
ky
the straight cut must be stronger, takes a lot of power to need to back down low gear.
