Page 4 of 9 1 2 3 4 5 6 7 8 9
Re: Do nitrous cars impress you? [Re: fishy340] #1138740
12/18/11 09:41 PM
12/18/11 09:41 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I would love to see someone spray a 400hp shot with no experience. You know just bolt it on and push the button. I guess that is why you have Monte Smith, Steve Johnson, Jeff Prock, list goes on. If it was so easy how can all these guys make a living tuning nitrous? I would have to say what bores me is any big tires car that doesn't run mid 7s or better, what do you need all that tire for if your not that fast.
I guess 99% of us dont impress you then... oh well...
but then again you dont even impress yourself
thats kind of a cheap shot there MR P i dont maybe because you have a car that can't keep up? i do know one thing if i had a 2400lb running 9's with w9's i wouldn't be throwing stones
Well I have been in the 8s but its just a small engine
without any spray... but I do have a kit I can hang
on it IF I wanted to go faster... but I am to the
point its fast enough and it can run years without
an issue the way its set up........ and it wasnt really
meant as a dig.... but I dont believe he is running
7s... that was my point
Re: Do nitrous cars impress you? [Re: fishy340] #1138741
12/18/11 09:49 PM
12/18/11 09:49 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Not all of them.....
But, a lot of cars including a lot of Mopars on here don't impress me. Not trying to start anything or bad mouth any ones efforts. When I first started any street car that went 10's or faster impressed me. Then I realized what I was willing to spend at the time against what they were spending was worlds apart. The same people I was so impressed by running 10's should have been deep in the 9's. So perspectives change as you season as a racer.
A guy with a nothing combo that bolts a 250hp shot on his car and only picks up a flat second. I am not impressed. The same combo picks up a second with a .063 jet and OK you got my attention. I ran nitrous for years and worked my but off maintaining the car. Went NA racing and thought it was going to be so much easier. Pistons and rings changed over to valve springs. The issue is with NA you are pretty much stuck if your converter is too tight. If you are spraying there is always the opportunity to spray a little more out of the gate. I became fairly successful spraying nitrous. I feel like I will be better after running a max effort NA combo that did not work out well. I knew what was wrong but a $7K tranny was not going to happen. Not that $7K was so bad but it will not hold the power of a bottle. I knew I would always return to a power adder. $100K for a NA engine to compete in the heads up classes is just not me.
I am impressed with anything that runs great for what it is. Problem is some of the NA guys who hate nitrous don't have a clue what they are looking at when it comes to power adders. Therefore instead of admitting they don't know they want to assume it is just a $400 nitrous kit doing all the work. Which in some cases it may be just that simple. But, I think I can tell the difference. Now boost that is something I am more than willing to admit I know little about.
Leon
Re: Do nitrous cars impress you? [Re: Leon441] #1138742
12/18/11 09:56 PM
12/18/11 09:56 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
It would impress me a lot more if it didnt taste like rotten eggs everytime I huffed it....
Re: Do nitrous cars impress you? [Re: dOc !] #1138743
12/18/11 10:02 PM
12/18/11 10:02 PM
pa
demongup Offline
demongup  Offline
pa
Just another booooring N20 pass running 8's
http://youtu.be/4ANTFt5Fzfk
Re: Do nitrous cars impress you? [Re: joshking440] #1138744
12/18/11 10:05 PM
12/18/11 10:05 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Well, he sure got the winter feathers ruffled.
Gotta wonder though......
Is there another post like this on an import site, asking if they think RWD V8s are boring because it's so easy? I mean it's a lot harder to keep that sub-200 inch motor together, and the traction at the front. Those V8 guys just bolt those cars together and put big slicks on the back....
Re: Do nitrous cars impress you? [Re: demongup] #1138745
12/18/11 10:06 PM
12/18/11 10:06 PM
Lehigh Acres, Florida
rickstershemi Offline
That looked spencive
Rickster
Re: Do nitrous cars impress you? [Re: demongup] #1138746
12/18/11 10:08 PM
12/18/11 10:08 PM
pa
demongup Offline
demongup  Offline
pa
Just bolt on 400 and go.......
http://www.youtube.com/watch?v=3-nVFSrHijM
Re: Do nitrous cars impress you? [Re: MR_P_BODY] #1138747
12/18/11 10:10 PM
12/18/11 10:10 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Last time I checked I didn't have a big tire on my car. Unless you think a 295/65/15 drag radial is a big tire.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Do nitrous cars impress you? [Re: demongup] #1138748
12/18/11 10:11 PM
12/18/11 10:11 PM
Salisbury North Carolina
8secDart Offline
8secDart  Offline
LOL,THAT PASS WAS N/A
Re: Do nitrous cars impress you? [Re: joshking440] #1138749
12/18/11 10:13 PM
12/18/11 10:13 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
You got to learn how to filter it.lol
Re: Do nitrous cars impress you? [Re: 1967dartgt] #1138750
12/18/11 10:27 PM
12/18/11 10:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
No I dont call that big... its just 1" taller than
I put on my Rampage... but what I was getting at is
that we have to be in the mid 7s to impress you and
the 99% of us dont impress you... thats all
Re: Do nitrous cars impress you? [Re: demongup] #1138751
12/18/11 10:33 PM
12/18/11 10:33 PM
Whitinsville Ma
superbee500 Offline
superbee500  Offline
Whitinsville Ma
You must get board driving that thing
I like fast cars end of story, I think you and N02 monster have two of the most impressive cars on Moparts.
If i had the extra cash to upgrade the rest of my car
Kevin
69 superbee 04 ram 3500
Re: Do nitrous cars impress you? [Re: 8secDart] #1138752
12/18/11 10:38 PM
12/18/11 10:38 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
that what i thought to Len one of my fav's GET U SOME!!!
Re: Do nitrous cars impress you? [Re: MR_P_BODY] #1138753
12/18/11 10:38 PM
12/18/11 10:38 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Sorry I like small tire racing and have seen how fast you can go on lets say a 28-10.5-15. So when a car with 32-16.5-15 rolls up and runs a 9 or 10 sec pass I think what a waste . My car has run 9.55 at 143 na. This is with a 1.43 60 ft so there's some left on the table. I run at 3250lbs on caltracs and 295 drag radials through mufflers just like I drive it on the street, no changes to car to go drag racing. So sorry if I see a big tire car go the same as my car I am not impressed.
Re: Do nitrous cars impress you? [Re: superbee500] #1138754
12/18/11 10:38 PM
12/18/11 10:38 PM
cincinnati ohio
mcat4321 Offline
mcat4321  Offline
cincinnati ohio
how many 8 second cars or faster are on the moparts fastest list, that are not dragsters or tube chassis and dont use some sort of power adder.
you do what ever it takes to go as fast as you can afford...
and quit frankly, if it doesnt have 2 seats , carpet, a headliner and full working dash with D.O.T tires, tagged and insured...im not really imperessed
Re: Do nitrous cars impress you? [Re: MR_P_BODY] #1138755
12/18/11 10:41 PM
12/18/11 10:41 PM
Heaven
EvilB1Dart Online content
EvilB1Dart  Online Content
Heaven
Guess I came back to MOPARTS at the right time!
"Any fool can know. The point is to understand"
- A. Einstein
Re: Do nitrous cars impress you? [Re: 1967dartgt] #1138756
12/18/11 10:42 PM
12/18/11 10:42 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
big tire small tire who gives a sh1t
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Do nitrous cars impress you? [Re: demongup] #1138757
12/18/11 10:42 PM
12/18/11 10:42 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Thats just a bad a$$ car. And can bracket race too...
Re: Do nitrous cars impress you? [Re: dusturbd340W5] #1138758
12/18/11 10:46 PM
12/18/11 10:46 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
NA or power adder who gives a crap....
Re: Do nitrous cars impress you? [Re: 1967dartgt] #1138759
12/18/11 10:46 PM
12/18/11 10:46 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
i was there that day,donho in the stang said he never in his life saw a front tire 1/2 way down the track in his face before..lol
