ATTN MSHRED #1138557
12/18/11 01:11 PM
12/18/11 01:11 PM
On the parachute mount
N
n20mstr Offline OP
n20mstr  Offline OP
N
Heres the Radiator you looking for kid, If you look around you can find them cheaper, but this pretty much bolts right up to your rad support and it weighs only 9 - 10 lbs
Upper hose i use is for a late 90's gm truck with a big block and lower hose i use (for big block guys) is for 86-89 mustang gt
http://www.autopartswarehouse.com/sku/Ma...tings+Clearance
....BAD A$$ STREET CAR.....
Re: ATTN MSHRED [Re: n20mstr] #1138558
12/18/11 01:15 PM
12/18/11 01:15 PM
Bergen County NJ
N
NoJoke Offline
NoJoke  Offline
N
Bergen County NJ
Thanks Tony you just saved me some weight on my car? Do you run this in your car? Does it cool you car down well?
Re: ATTN MSHRED [Re: NoJoke] #1138559
12/18/11 03:04 PM
12/18/11 03:04 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
That works on a later 70+ SB car?
Looks like the outlets are on the wrong sides. Mine needs drivers upper, pass lower. I've been looking for an alternative to some of the aftermarket stuff.
I know the one I bought for my infiniti was really cheap, like under $100.
Re: ATTN MSHRED [Re: n20mstr] #1138560
12/18/11 09:21 PM
12/18/11 09:21 PM
Toronto
mshred Offline
mshred  Offline
Toronto
LOL thanks for getting back to me Tony! Nice of you to post the info up here too for everyone to see
If I can figure out a way to make the outlets work with my smallblock this could be a great way to go. Thanks!
Re: ATTN MSHRED [Re: mshred] #1138561
12/18/11 09:45 PM
12/18/11 09:45 PM
Ont. Canada
10.90 Racer Offline
super street
10.90 Racer  Offline
super street
Ont. Canada
Let me know how you make out with the small block app.........
Re: ATTN MSHRED [Re: NoJoke] #1138562
12/18/11 11:50 PM
12/18/11 11:50 PM
N
n20mstr Offline OP
n20mstr  Offline OP
N
Thats the rad i have run in my car for the last 12 years, i have to replace it becasue the top tank has a crack that even repaired is coming back (plastic tank) I figure the wheelstands have stressed it. Works Great for a big block and the hoses i listed are like factory fit. In the summer on the street my car runs about 190 with this rad. The nice part it has two bolts per side and it sits nice against the rad support. Mark the 4 holes and drill. thats it bolts right in. AND the best part its prob half the weight of the alum rads out there...Perfect for a limited street use car and race car...CHEAP too...LOL
If wieght reduction fails,.....Just add another nitrous kit
Re: ATTN MSHRED [Re: n20mstr] #1138563
12/19/11 11:35 AM
12/19/11 11:35 AM
Utah
topbrent Offline
topbrent  Offline
Utah
Any pics of your installed setup?
When you say limited street, could you expound on this a bit?
Could it cool a basic big block street/strip car, or it asking a bit much of the design?
Re: ATTN MSHRED [Re: topbrent] #1138564
12/19/11 12:20 PM
12/19/11 12:20 PM
N
n20mstr Offline OP
n20mstr  Offline OP
N
I SAy "limited" street use because thats all i used it for, My car has a 5 gal cell and i have not driven it in traffic , 50+ miles etc. Now i have driven around town etc and car shows in 90+ heat. Keeps my big block coll about 190ish and all i have is the old school elec w/p drive on a stock water pump and a 16" elec fan. Would it work in a daily driver? im not 100% sure. BUT it is very light, cheap , fits good.
Re: ATTN MSHRED [Re: n20mstr] #1138565
12/19/11 09:22 PM
12/19/11 09:22 PM
Ont. Canada
10.90 Racer Offline
super street
10.90 Racer  Offline
super street
Ont. Canada
How much weight do you think you save?????
Re: ATTN MSHRED [Re: 10.90 Racer] #1138566
12/19/11 09:24 PM
12/19/11 09:24 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
im using a 1995 nissan maxima radiater and electric fans
1.39 9.85 - 137 mph
Re: ATTN MSHRED [Re: Ari440] #1138567
12/19/11 09:54 PM
12/19/11 09:54 PM
Ont. Canada
10.90 Racer Offline
super street
10.90 Racer  Offline
super street
Ont. Canada
What does it look like... is it a down flow??? Does it install like a stock rad??
Re: ATTN MSHRED [Re: 10.90 Racer] #1138568
12/19/11 10:00 PM
12/19/11 10:00 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
heres a pic
need the four brackets to hold it up ,two on top two on bottem
got the setup from a junkyard
1.39 9.85 - 137 mph
Re: ATTN MSHRED [Re: Ari440] #1138569
12/19/11 10:17 PM
12/19/11 10:17 PM
Ont. Canada
10.90 Racer Offline
super street
10.90 Racer  Offline
super street
Ont. Canada
heres a pic
Thanks looks god
How much weight do you think you saved??
Re: ATTN MSHRED [Re: 10.90 Racer] #1138570
12/19/11 10:34 PM
12/19/11 10:34 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
dont know exact weigth saving but alot ligther then the jegs uneversal alum radiater I had before
1.39 9.85 - 137 mph
Re: ATTN MSHRED [Re: Ari440] #1138571
12/19/11 10:37 PM
12/19/11 10:37 PM
Ont. Canada
10.90 Racer Offline
super street
10.90 Racer  Offline
super street
Ont. Canada
So considerably much lighter than my stock rad...........
Re: ATTN MSHRED [Re: 10.90 Racer] #1138572
12/19/11 10:40 PM
12/19/11 10:40 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
oh yes
just use good relays and a good output altanater
1.39 9.85 - 137 mph
Re: ATTN MSHRED [Re: Ari440] #1138573
12/20/11 01:44 AM
12/20/11 01:44 AM
Toronto
mshred Offline
mshred  Offline
Toronto
Ari, do you street drive the duster at all? What kinda temps does it see?
Seems like another great lightweight rad combo but again inlets on the wrong side for the smallblock darnit
Re: ATTN MSHRED [Re: mshred] #1138574
12/20/11 01:58 AM
12/20/11 01:58 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
local street driving ,using a stock waterpump setup with a 4 inch underdriven bottem pulley and no thermostat
*180 - *200
1.39 9.85 - 137 mph
Re: ATTN MSHRED [Re: Ari440] #1138575
12/20/11 12:38 PM
12/20/11 12:38 PM
Toronto
mshred Offline
mshred  Offline
Toronto
*180 - *200
pretty good! I think I need to take a trip to the scrap yard and see what I can find in aluminum lightweight factory rads that may have the hose inlets on correct side for an SB....just not sure how I can get a hose from the passenger side of the motor to go all the way to the driver side inlet on the rad lol
Re: ATTN MSHRED [Re: mshred] #1138576
12/20/11 03:19 PM
12/20/11 03:19 PM
Canada
RobR Offline
RobR  Offline
Canada
I just use the 66-67 sb water pump for pass side lower rad hose neck and the later 68-72 water pumps for driver side lower rad hose neck...unless you running an electric pump of some kind then this is of no use to you.
