Re: How to fix this air cleaner base? (missing mount) [Re: DUSTER_340] #3283269
01/17/25 04:10 PM
01/17/25 04:10 PM
BDW Offline OP
BDW  Offline OP
Here's what I see:
It's actually 2 pieces (you can see the spot welds in 2nd pic) that capture the carb stud barrel and the 2 top studs.
2 spot welds at each end to base, the "foot" is not a separate piece, same center piece folded at end.
Total length : 10"
Bevel to Bevel at top: 9"
Base : 1" x 0.5"
Center section is 7/8" and tapers down to 1/2"
Re: How to fix this air cleaner base? (missing mount) [Re: BDW] #3283319
01/17/25 10:19 PM
01/17/25 10:19 PM
Armada MICH.
DUSTER_340 Offline
DUSTER_340  Offline
Armada MICH.
Thanks so much the photos are perfect, and the information you provided is spot on as well.
Thanks again.
