Re: tcs trans 'full metal jacket' drum
[Re: bodyworks racing]
#1134946
12/16/11 10:47 AM
12/16/11 10:47 AM
Posts: 30,466 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
it has a steel sleeve around the band surface. the rest is billet aluminum.just want to find out more before i shell out 625
Just "Raw" alum in the reaction shaft sealing ring area ? ... what do they recommend for sealing rings then ....so the rings don't tear-up the drum ??
[Re: keefe]
#1134951
12/16/11 09:01 PM
12/16/11 09:01 PM
Posts: 1,401 Wi.
old_racer
Wi.
Hi, I have this drum in my car and I'm happy with it, I chose it cause I freshen several friends trans with the alum drum and I don't care for the wear on the drum from the band , also the alum crap all over the inside of the trans also. I think its' a happy medium between alum and billet steel. Russ
[Re: dOc !]
#1134953
12/16/11 11:53 PM
12/16/11 11:53 PM
Posts: 12,589 Great Neck,LI,new york
hemi-itis
PC ... that link is not werkin' furr me ... brass ? ...why not steel? .... all considered at this point .. my choice is leaning towards a steel drum.
BUT NOT the one that has a lot of clutch discs.
Doc,it seems that to use the extra disc,the thinner ones need to be used.My trans guy Tom preferred the thicker clutch disc so it's still,,,,,,,5 I think
I can ask Tom or B1 Johnny will say
[Re: hemi-itis]
#1134954
12/17/11 02:49 AM
12/17/11 02:49 AM
Posts: 4,647 aotearoa
rebel
aotearoa
i tried 6 disc's in my billet steel drum from TCS. i had a lot of overheating probs with the trans. we pulled it down & rebuilt with five fat disc's. seems to run cooler this rebuild.
