Re: How do you "use" feeler gauges
[Re: BloFish]
#1134595
12/15/11 04:13 PM
12/15/11 04:13 PM
Posts: 30,465 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
Well... they're called "feeler" gauges, not "jam-it" gauges; I figure if you're forcing it in at all that you're not getting an accurate measurement.
That's what she... Oh never mind
.... what ...like a 3/8 stem ...with 006 clearance ? ..
[Re: BloFish]
#1134600
12/15/11 06:20 PM
12/15/11 06:20 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
That's the inside mic... Prefer an interference fit!
[Re: Cab_Burge]
#1134601
12/15/11 08:15 PM
12/15/11 08:15 PM
Posts: 8,941 Holly/MI
Dean_Kuzluzski
Holly/MI
I've used the "go, no-go" technique for many years. Usually a .002 difference as mentioned.
[Re: Cab_Burge]
#1134602
12/16/11 12:23 AM
12/16/11 12:23 AM
Posts: 6,847 Missouri
StrokerPost
Missouri
Use a slightly larger gauge as a no-go and the size you want as a "go".
I use the recommendations of a old Mopar engine guru, if it slides in easy it is to loose,he said it should almost cut your finger to make it slide in. I now use the go no go procedure, if a .016 will go in hard and a .017 won't go in no matter how hard I press on it I'm there at .016
Yup, if it fits, thats what it is. I used to set mine by the "run it down till snug and set it" routine, (for rockers) then found if I put a bit of pressure on the next larger feeler it would go in too. I like to set it so that I get a loud "snap" when I remove the feeler, but still just be able to put it back in. That 1 or 2 thou difference though, in most cars, will make little or no difference in performance so I dont get in a twist over it. Just my
[Re: Cab_Burge]
#1134603
12/16/11 12:48 PM
12/16/11 12:48 PM
dartman366
Mt. Vernon, Ohio
thats how I was taught to do it.
[Re: Quicktree]
#1134605
12/16/11 01:59 PM
12/16/11 01:59 PM
Posts: 20,655 in a cattle trailer down by th...
Guitar Jones
Just a slight drag on the gauge. Jamming it or forcing it is not an accurate measurement. Do you clamp a micrometer like a pair of vise grips?
[Re: Guitar Jones]
#1134606
12/16/11 02:01 PM
12/16/11 02:01 PM
Posts: 9,670 Lima, Peru
domingo
EL Master
EL Master
Lima, Peru
