Change oil just because it is black? #1132722
12/12/11 08:51 PM
12/12/11 08:51 PM
Walmart parking lot
yorker Offline OP
Drugs are bad
yorker  Offline OP
Drugs are bad
Walmart parking lot
I have a car with black looking oil on the dip stick.
I know they say change every 6 months or 3,000 miles.
It has about 700 miles since last change and about 10 months.
I have only changed the oil one time since I had bought it.
I drove it a few hundred miles before changing it.
Thinking that the previous owners did not change often enough and now may have deposits, sludge making the oil dark.
Do you think it is sludge turning the oil dark so soon?
Do you think more frequent oil changes would clear up the dark oil?
My Ram, can go 3000 miles before adding oil and it only turns a dark gold color.
( SHONEN KNIFE ) MAKING THE WORLD A BETTER PLACE. ONE SONG, ONE CONCERT AT A TIME FOR OVER 36 YEARS!!
https://www.youtube.com/user/SHONENKNIFETV
Re: Change oil just because it is black? [Re: yorker] #1132723
12/12/11 09:30 PM
12/12/11 09:30 PM
Kirkland, Washington
Pacnorthcuda Offline
Because of its unknown history I would change it--not "just because its black". Have you pulled a valve cover and looked?
You could also run some diesel oil in it (hi detergent) but if its really dirty the new oil will turn black quick also (thats a good thing).
Re: Change oil just because it is black? [Re: Pacnorthcuda] #1132724
12/12/11 09:47 PM
12/12/11 09:47 PM
jersey
Spaceman Spiff Offline
jersey
Prolly not the case here but my '58 chevy has so much blow by, that within 500 miles the oil is BLACK. And it's really clean inside the valve covers and lifter valley.
I would try this on yours.
http://www.auto-rx.com/
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Change oil just because it is black? [Re: Spaceman Spiff] #1132725
12/12/11 09:53 PM
12/12/11 09:53 PM
Walmart parking lot
yorker Offline OP
Drugs are bad
yorker  Offline OP
Drugs are bad
Walmart parking lot
I did have the valve covers off last year. I think it looked pretty good for a 24 year old motor.
Am thinking I will change it anyway as it has already used a quart in 700 miles.
Perhaps the dark oil was just what would not drain out at time of the oil change.
I used Penzoil and it does say it cleans out the motor.
Seen a previous post here saying Penzoil was no good, but have been using it for years in my other cars.
Re: Change oil just because it is black? [Re: yorker] #1132726
12/12/11 10:47 PM
12/12/11 10:47 PM
I would change it & if the next batch gets dark fast I'd look for the cause, dirty air, blowby. Something's making it change color & as you noted your other one does not. Before you reinstall the drain plug toss a qt or 2 in to flush the last remnants of the black oil out
Re: Change oil just because it is black? [Re: yorker] #1132727
12/12/11 10:47 PM
12/12/11 10:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Put a QT of trans fluid in it and run it for a week
before you change the oil.. it acts as a cleaner
Re: Change oil just because it is black? [Re: yorker] #1132728
12/12/11 10:59 PM
12/12/11 10:59 PM
scratchnfotraction Offline
good oil gets black fast,its the detergents cleaning the inside of the engine.
with that amount of drive time and that much sitting time I would change it. at the 3 months or 3,000 miles.
with it not getting hot to burn of moisture/acidic contaminates it has got black fast and is most likly contaminated sitting 10 months.
send a sample for a oil analyssis to see what its like
on my new engine build I changed oil as soon as it got black for the first yr,then it stayed clean longer inbetween oil changes and got black about 3,000 miles.
I know it seems like a waste to change oil from sitting only 3 months,but it does get contaminated with very little run time and only sitting.
also the brand of oil will make a differance on how fast it gets black, the faster the better the oil and is working like it should cleaning the carbon deposits out.
Re: Change oil just because it is black? [Re: scratchnfotraction] #1132729
12/12/11 11:49 PM
12/12/11 11:49 PM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
"used a quart in 700 miles" i might think the last owner didn't change it,thinking he was putting in new oil so often,thinking sluge build up
Re: Change oil just because it is black? [Re: meepmeep70] #1132730
12/12/11 11:57 PM
12/12/11 11:57 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
If I were you ....I would seriously-consider dropping the oil pan and cleaning that out.
Re: Change oil just because it is black? [Re: yorker] #1132731
12/13/11 08:57 AM
12/13/11 08:57 AM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
It's simply not possible to determine the actual condition of motor oil by looking at it's color.
For example, take a look at this video: Busting Oil Change Myth - link
If you're really concerned and want to set aside speculation, you could send in a used oil sample and get a lab report back that shows the actual condition of the oil and if the engine has any deficiencies you may not know about. For example, excess fuel dilution, dirt intrusion thought the air filter or intake, an internal coolant leak, etc.
Also, nothing wrong with Pennzoil. In the 1930s it wasn't that great, but today it's a good oil. Any name brand oil that's SN/GF-5 rated has good cleansing ability as specified by the API the spec.
Re: Change oil just because it is black? [Re: CompSyn] #1132732
12/13/11 12:23 PM
12/13/11 12:23 PM
dogdays Offline
dogdays  Offline
Someone mentioned testing. You may be surprised to find you are throwing away good oil. I believe car guys use from 2-3 times the amount of oil they have to.
A few years ago my wife's primary transportation was a 1993 Chevy Suburban 4wd 3//4 ton. I was changing the oil every 5000 miles, the car had about 100K miles on its 350. One day I stumbled on a few Titan Labs test kits at a KMart for cheap. So I got the brilliant idea to test the Sub's oil. When I went to change the oil I found that instead of 5K miles it had more like 12K miles! Calamity! About half of these miles were city driving, the other half were Interstate at 82mph.
The oil was petroleum based, probably 10W-30 that I had bought on clearance at a Checker Auto for a quarter a can.
A week later I got the test results back. The oil was within spec and I could have used it longer!
I think we are so eager to show that we love our cars that we run way too much oil through them just to make ourselves feel good.
R.
Re: Change oil just because it is black? [Re: dogdays] #1132733
12/13/11 12:46 PM
12/13/11 12:46 PM
That's the story of my life
Re: Change oil just because it is black? [Re: dogdays] #1132734
12/13/11 01:03 PM
12/13/11 01:03 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
doggy .....just car guys ? ... how about the general public? ... they are OVER SOLD on all types of car-stuff.
And don't get me started on the medical profession..... just a little TIDbit ... WHERE are all the CURES for all our ills that have been promised for decades ?
There are basically NONE ...and never will be. BECAUSE ... as some even in the medical profession say .. they is NO MONEY in a cure ... it is all-in a many-times never-ending TREATMENTS.
And to ON TOPIC ... the soccer mom who takes her minivan to the oil-change-place .... they are NEVER going to say "your oil is OK". They are going to try and convince her to get a change every 3k miles ....even though it will go 7.
Re: Change oil just because it is black? [Re: dOc !] #1132735
12/13/11 01:16 PM
12/13/11 01:16 PM
Doc I had no idea you really were a doc
Re: Change oil just because it is black? [Re: RapidRobert] #1132736
12/13/11 01:39 PM
12/13/11 01:39 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Yep have it tested - these guys need to make a living too. Likely cost more than just changing the oil. Oh yeah that's right there is an oil shortage.
Bakken Formation in North Dakota could boost America’s Oil reserves by an incredible 10 times, giving western economies the trump card against OPEC’s short squeeze on oil supply and making Iranian and Venezuelan threats of disrupted supply irrelevant.
There is more oil under ND, MT., & Saskatchewan than future generations will ever use. In fact the oil boom is causing big problems. elderly and other people on fixed incomes can no longer afford the rents being charged other things that they need are priced out of range by people out to make killing and are being forced to move.
Re: Change oil just because it is black? [Re: dOc !] #1132737
12/13/11 01:46 PM
12/13/11 01:46 PM
Ball Ground, Georgia
Dixie Offline
Dixie  Offline
You forgot to add, "and sell her an air filter or other not needed product."
Dixie Restoration Parts
Phone -(770) 975-9898
Phone Hours: M-F 10am-5pm EST
website: www.dixierestorationparts.com
email: mail@dixierestorationparts.com
Veteran owned small business
The Best Parts at a Fair Price.
Re: Change oil just because it is black? [Re: RapidRobert] #1132738
12/13/11 02:15 PM
12/13/11 02:15 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
RR ...I always supply good Rx !
Re: Change oil just because it is black? [Re: dOc !] #1132739
12/13/11 02:23 PM
12/13/11 02:23 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
Even the "oil-change-places" may be recommending something other than 3k miles... Jiffy Lube Retires 3000-mile Rule - Article
According to a recent survey by the NPD Group, 51% of motorists believe oil should be changed every 3-months or 3000-miles, down from 59% in 2007 - Article link
Slow but sure. What the owners manual actually says and what the "oil-change-places" are starting to say may be resonating with the consumer.
The oil analysis is about the cost of one oil change give or take. The empowerment of increased awareness and attendant cost savings starts soon after, e.g., Had no idea there was a small coolant leak at the head gasket slowly zapping the life out of the oil and the engine or that one leaky fuel injector was diluting the oil. No wonder the fuel economy wasn't what it used to be... One oil analysis report away.
Re: Change oil just because it is black? [Re: MoparforLife] #1132740
12/13/11 02:58 PM
12/13/11 02:58 PM
dogdays Offline
dogdays  Offline
It cost me around $10.00, I believe it's about double that retail.
Just because there is a lot of something doesn't mean we have to waste it.
If you test at say 3000 miles and 6000 miles and 9000 miles and they all come back good then you shouldn't have to test so often the next time. Knowledge is forever.
R.
PS: My cousin is an oil millionaire from that formation, so I have heard all about it. You can put your wagging finger away.
Re: Change oil just because it is black? [Re: dogdays] #1132741
12/13/11 03:40 PM
12/13/11 03:40 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I have been changing oil at 10K miles for 25 years now. My big trucks go to 20K miles
BTW as soon as I put new oil in one of my diesel engines it's black as soon as I start it.
I have to laugh at people who say it's needed at 3-5K miles becaue I have been proving otherwise for a long time. I change oil in over 25 vehicles and about 10 small engines. I buy my oil in bulk.
