Re: The best method for one person to bleed brakes?
#113118
08/31/08 10:07 PM
08/31/08 10:07 PM
Posts: 3,380 KY USA
mopargem
KY USA
Just get the one man bleeder cup, I think mine is Lisle tool brand available at a lot of auto stores. It's simple and really works, I have used mine dozens of times. Gravity doesnt always work with the small diameter of the line you can get an airlock. Never used a suction pump but dont waist your money.Trust me on this one, I have owned almost 100 cars so far and the one man bleeder cups are easy to use really do work.
68 Polara 500...LL1 Y7 M6X 69 Hemi road runner...X9 X9 M6X 69 A12 road runner....R4 R4 M6X 69 ModTop FLORAL Super Bee...F6 M6W 70 AAR 'cuda...EW1 EW1 H4X9 71 Duster 340...FJ6 V24 L6X9 71 road runner FC7 V1X M6X9 72 Rallye Charger B5 V1W 74 'cuda 360...KB5 V1X A6X9 08 SRT Challenger #234
[Re: mopargem]
#113119
09/01/08 05:44 PM
09/01/08 05:44 PM
Posts: 576 Escondido, CA
kick_the_reverb
Escondido, CA
I had to chuckle a little bit reading the above posts, not just the ones about making the wife pump the brakes way too many times, but also about the mity vac and the one-man tube with the check valve. A couple of years ago when I was still helping my buddy at his shop, I tried the mity-vac...always slipped off the bleeder just as vacuum was built. Recently I was trying to bleed my A100 brakes at home, went to the parts store and happily bought the tube+check valve tool. It stayed on for two pumps and always flew off afterwards. Quite "enjoyable". So, as usual, YMMV, but for me the helper pumping the pedal is the chosen method. I don't mind being the pedal pusher. Ran
"Hey mister, something's wrong with your car, it idles roughly" - number one comment I got in Israel when daily driving a 70 Barracuda with a lopey cam.
Currently working on - 1966 Dodge A100 van 318/auto Finally - disc brakes on the front. In the plans - rear disc brakes, B&M 250 blower
[Re: minivan]
#113121
09/01/08 10:31 PM
09/01/08 10:31 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Take the cap off the master and open all the bleeders. Let them bleed with gravity until no air comes from the bleeder then close it. Keep the MS filled.
Simplest best way I have found also....
I have done this many times and it worked every time. I did both my sons Dart and my 63 like this by myself. But you have to make sure you get all the air and the MC does not get to low and suck in air. Ron
[Re: 4BBodies]
#113123
09/03/08 09:44 AM
09/03/08 09:44 AM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
Mityvac to get everything flowing then I gravity bleed a little bit more.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
[Re: justinp61]
#113124
09/03/08 12:24 PM
09/03/08 12:24 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
There is also a pet [Edited by Moparts - Keep it clean] in line to break the vacuum when needed.
Ha, Ha. Apparently we need to be careful when typing 'petcock'.
As for the other, they make decisions for us, and some of them have names, but they are **not** pets!
Parts I seek:
driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set
16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better.
69-73 C-body caliper brackets and/or splashields
Send a PM.
[Re: Fury Fan]
#113125
09/03/08 02:56 PM
09/03/08 02:56 PM
RapidRobert
whosever wife you end up useing instruct her not to push the pedal past it's normal travel which moves the neoprene cups past their normal wear area & can hasten their demise. If she is instructionally impaired(& most are) put a block of wood under the pedal.
[Re: RapidRobert]
#113126
09/03/08 08:12 PM
09/03/08 08:12 PM
Posts: 18,160 Mass
DAYCLONA
Mass
Or put the "wood" to her?
