Page 2 of 3 1 2 3
Re: Educate me about vacuum pumps [Re: 540dust] #1127056
12/04/11 09:12 PM
12/04/11 09:12 PM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
If you're looking at the Moroso pumps, I think you should give this a look GZ VP104 Super Pro pump seems like a better deal to me, more capacity and less cost. Check it out http://www.gzmotorsports.com/compare.html
Thats what we used on our 640ci. Pretty sure it would be overkill for your engine but it has been a great pump for us!
Re: Educate me about vacuum pumps [Re: Big Squeeze] #1127057
12/04/11 11:08 PM
12/04/11 11:08 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
Most of the decent engines I have come across ran a Star Machine Vacuum pump.
I decided on a Star for one major reason they do not pull anything directly into the pump. Everything goes thru their VACUUM PUMP OIL SEPARATOR/EXHAUST TANK
first thus no trash that can tear up the rotors. All other designs require oil be passed into them. Star pumps are designed to run dry.
The Pump is a “OIL-LESS” design, which requires NO LUBRICATION for operation. Oil in the Pump will not damage the Pump,
however it will reduce its performance. The dryer you can keep this Pump, the better it will work!
VACUUM PUMP OIL SEPARATOR/EXHAUST TANK This new vacuum pump accessory is yet another example of Star Machines’ continuing effort to offer only the
finest vacuum components to the motorsports industry. Constructed of aluminum and CNC machined, the tank
can be completely disassembled if necessary. The “tank within a tank” design incorporates two separate
chambers. The inner oil separator chamber, containing a baffle and filter media, acts to reduce or eliminate oil
reaching the vacuum pump. A secondary benefit of this section is its ability to trap debris resulting from engine
failure before it can reach the vacuum pump and cause damage. The outer chamber serves as a free flowing
exhaust vent for the pump and also contains filter media. Separate drain cocks located in the bottom plate will
individually drain both chambers.
home of the
Sox and Martin Hemi Duster
Re: Educate me about vacuum pumps [Re: HEMIFRED] #1127058
12/05/11 10:06 AM
12/05/11 10:06 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
I was able to borrow a Star vacuum pump at our last race. Pulled a safe 10 inches and it did nothing to my time slip, what is wrong with my engine?
Re: Educate me about vacuum pumps [Re: scatpacktom] #1127059
12/05/11 03:29 PM
12/05/11 03:29 PM
I have heard that the vacume pumps only help above 6000 RPM What RPM do you shift your car at?
Re: Educate me about vacuum pumps [Re: Cab_Burge] #1127060
12/05/11 03:32 PM
12/05/11 03:32 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
FWIW we run a Moroso enhanced 4 vane on the orange car. I have it limited to 14lbs and have since the beginning. Tore it down at 223 passes and there was no sign of pin issues. It is back on thier now at the same vac settings. So far so good.
the silver car has a Dailey 5 stage dry sump and according to the data logger sees right at 18" a each pass.
Re: Educate me about vacuum pumps [Re: Al_Alguire] #1127061
12/05/11 04:53 PM
12/05/11 04:53 PM
sg66mopar Offline
sg66mopar  Offline
I went with the GZ setup. Mostly because they answered the phone and talked me through all the parts I needed.
The price was OK and the kit showed up here real fast.
Mine's only pulling around 12 at the top end because I have it regulated down that much.
After experimenting a little I finally put the pickup in the driver side valve cover (Thank's Al) and put an extension on the top of the tank so the breather is well above the tank.
Re: Educate me about vacuum pumps [Re: scatpacktom] #1127062
12/05/11 05:13 PM
12/05/11 05:13 PM
NY
F1Scamp Offline
F1Scamp  Offline
NY
Maybe your headgasket was already on its way out?
Work In Progress- 71' Duster F.A.S.T.- 10.36@130 Smallblock Record Holder.
Re: Educate me about vacuum pumps [Re: F1Scamp] #1127063
12/06/11 10:56 AM
12/06/11 10:56 AM
an8sec70cuda Offline
I've had an aerospace pump on my car since 2008. No oiling problems. I have it set to pull about 12".
The pump did fail 2 weeks ago at a true street race at rockingham...just put the new one on this past weekend.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Educate me about vacuum pumps [Re: scatpacktom] #1127064
12/06/11 11:25 AM
12/06/11 11:25 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
not all engines will gain power with a pump.It depoends on the ring tension
Unless there is a decent amount of back pressure in the crankcase and it is effecting the ring seal it won't help.
home of the
Re: Educate me about vacuum pumps [Re: an8sec70cuda] #1127065
12/06/11 11:59 AM
12/06/11 11:59 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
they suck!!...
Re: Educate me about vacuum pumps [Re: Edge] #1127066
12/06/11 07:56 PM
12/06/11 07:56 PM
London, England
mopar_mark Offline
mopar_mark  Offline
London, England
Instead of pulling vacuuum from the valve cover you can pull from the fuel pump location as there is a limited amount of oil splashing from this location.
Is or has anyone else tried plumbing their Vacuum this way ?
Re: Educate me about vacuum pumps [Re: mopar_mark] #1127067
12/07/11 10:34 AM
12/07/11 10:34 AM
I have not, but a lot of people do and have no problems.
CHIP
Re: Educate me about vacuum pumps [Re: an8sec70cuda] #1127068
12/07/11 12:56 PM
12/07/11 12:56 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
any pictures with this setup??..
Re: Educate me about vacuum pumps [Re: smokinwoody] #1127069
12/07/11 01:37 PM
12/07/11 01:37 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
I do know pulling vacuum from the valley cover is a bad idea. I tried it, it was pulling so much oil the output looked like a fire hose.
Re: Educate me about vacuum pumps [Re: jyrki] #1127070
12/07/11 02:18 PM
12/07/11 02:18 PM
gregsdart Offline
gregsdart  Offline
I had vacuum leaks that were hard to track down and could only pull 7 inch vac for quite a while on the moroso 3 vane. If I had it to do again, I would go four vain and use a bleed to control vacuum. I don't need one now on my 528, it will only pull 10/12 inches spinning it 50 percent engine speed, or about 3700 rpm. The bigger unit will consistently pull max vacuum from launch, and if you develop a small leak will still give you good vacuum to a point. Plus, for the few extra $$ you are set for a bigger motor if you move up.
I use a good, sidebucket oil pan, a baffled valve cover with a large baffle under the breather, set up front on the valve cover. I pull so little oil that I have gone five or six passes and it wasn't worth draining the little puke tank. I also use two breathers on the puke tank, to make sure that if there is any restriction with one, I don't have to worry about it. I wash them once a year.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: Educate me about vacuum pumps [Re: Bigcube] #1127071
12/07/11 03:02 PM
12/07/11 03:02 PM
Winterpeg, Canada
hvyweight Offline
hvyweight  Offline
Winterpeg, Canada
That is the only way I could control the amount of oil coming into the pump. I tried the valley pan and the valve cover. The fuel pump plate work for me. I can also tell you that I had to put a shield around the front half of the breather tank to elminate a siphoning effect from the wind going throught the front of my car at 145+ mph!
Re: Educate me about vacuum pumps [Re: smokinwoody] #1127072
12/07/11 04:23 PM
12/07/11 04:23 PM
Alberta Canada
E
Edge Offline
Edge  Offline
E
Alberta Canada
there is a picture in my earlier post on the topic, not a great picture but you can see the 12 AN line from the pump going behind motorplate to the fuel pump plate. It is Moroso piece that comes with the 12 AN male end and the plate is tapped and machined for the ORB fitting
76 Duster work in progress
Re: Educate me about vacuum pumps [Re: Edge] #1127073
05/05/12 05:41 PM
05/05/12 05:41 PM
Mo.
racerx Offline
racerx  Offline
Mo.
I did a search and came up with this old thread on vacuum pumps.Just like to add that sense I've change out my valley plate and installed a set of the Super Performance gaskets i've see an increase in vacuum readings so ...anyone no whats a good reading at idle?I know that u don't want to go past 14" in a full past.........Thax.
Re: Educate me about vacuum pumps [Re: 540dust] #1127074
05/05/12 10:26 PM
05/05/12 10:26 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
If you're looking at the Moroso pumps, I think you should give this a look GZ VP104 Super Pro pump seems like a better deal to me, more capacity and less cost. Check it out http://www.gzmotorsports.com/compare.html [/quote
I agree on paper they look as good as anybody. About the same cost as a Moroso but a nicer piece. Is it better? well see in a month or so.
Doug
Re: Educate me about vacuum pumps [Re: smokinwoody] #1127075
05/05/12 10:29 PM
05/05/12 10:29 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I did it . 1/2' pipe tapped into the block off plate. With a Jessel there's nothing spinning in there except the crank. Additionally the GZ pump is designed to pull some oil.
Doug
Page 2 of 3 1 2 3
