Re: better gears for more purpose use but power to.
[Re: dogdays]
#1126929
12/06/11 01:06 PM
12/06/11 01:06 PM
Posts: 52,972 Romeo MI
MR_P_BODY
You could put a 1000 lb-ft torque engine in front of an 8 3/4 and as long as the tires broke free first the rear end would live. It's the amount of torque RESISTANCE that breaks the rear or the driveshaft or the transmission or the u-joints. Also spelled traction or hook.
R.
I've been VERY happy with my 8 3/4 with a 1.19 60'.... if you put certain items in/on a 8 3/4 they can/will live a long life.... but I do have a light car
[Re: MR_P_BODY]
#1126930
12/06/11 03:39 PM
12/06/11 03:39 PM
Posts: 1,949 land of 10,000______'s
BDS871Cuda
I would put in a 3.23 or 3.08 depending on how much freeway speed you want. Then drive it with your head, not with your foot!!
Snap your neck, mega G-force launch, is all I want!
[Re: BDS871Cuda]
#1126932
12/06/11 05:02 PM
12/06/11 05:02 PM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
except there is no 3.08 for the 8.75
[Re: JohnRR]
#1126933
12/06/11 05:21 PM
12/06/11 05:21 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Are you spinning the tires or the clutch ? I mean I have 4.30's with 30" tall radial slicks and I can be going 60 mph at 3300 rpm and hit it hard and it will easily run up to 120 mph before I crank over 6500 rpm. But I drive on slicks so the tires usually stay hoooked when I step on it at 60 mph. And by the calculations my eng makes about 600 flywheel hp. Just seems like with 3.91's that wont happen so easy unless something slips. Ron
