Page 2 of 3 1 2 3
Re: Dynomax mufflers VS Flowmasters [Re: pinkduster] #1126520
12/04/11 03:44 PM
12/04/11 03:44 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Yeah, that's what the center in / dual out looks like, but what about the center in / center out? My car had the huge three chambers on it when I bought it. I recently switched to the little single chambers for two reasons. #1, I wanted to see if I'd pick up at the track, and #2, I wanted the car to be as loud and obnoxious as possible, but not run cut-outs. I picked up .02 and 1 mph at the track and yes, the car is crazy loud and 100% totally obnoxious. Simply out of curiosity, I think I'm going to buy a set of these hopefullyflows that everybody here is in love with and see if they actually make any difference at the track without any other changes to the car. Now THAT would be a real world test.
I couldn't find an internal shot of anything other than the single-in, dual-out single chamber. But it will have the trademark Flowmaster "wall of death" first deflector. ANY muffler that has an obstruction in the flowpath, no matter what it looks like - I don't care if it comes from NASA, an obstruction causes flow impedence. Flow impedence = restriction. To certain degrees, some of this will not adversely affect your performance, it depends on your HP, the pipe diameter of your system, etc. Too small of diameter pipes will cause restriction as well, so remember that even though the pipes are "straight through." I wish I would have understood this exhaust stuff back in 1983 when I replaced my mufflers on my '71 Hemi Charger. I thought - OK, I got a Hemi car, so I should replace the original mufflers with Hemi mufflers! So I bought a pair of "Hemi" mufflers from Mitchell Motors. The ones I received were shorter than the originals (originals were 20" long bodies). I put them on anyway & I could tell they were restrictive - I mean you could hear it & feel it. If I had known something about exhaust, I would have put on a pair of Walker Redline Z mufflers (which later evolved into the Dynomax Super Turbos).
Dynomax's head of performance exhaust engineering has been an engineer for Walker/Dynomax since about 1974, so he's lived through many muffler designs, & seen lots of mufflers come & go. I learned a lot from him, & contributed a lot to Dynomax when I was there also. There are about a dozen Dynomax mufflers that I suggested we build back 11 years ago, & they were all added to the line. Then I suggested we add a new series of QUALITY mufflers to the Thrush line rather than skirt the brand - hell I contended that more people knew the Thrush muffler brand than Dynomax! Why buy out a company like Thrush & then do nothing with it? It didn't make sense to either of us. Tenneco did eventually add a new family of welded Thrush mufflers, so this may have come from my idea I don't know - I had left the company in 2001. Then the bean counters at Tenneco decided one Friday to kill the Thrush Turbo Tube chambered mufflers around 2000. This was a big mistake. It led to me eventually making MY mufflers - the chambered POWERSTICK. They are based on the same premise of the Turbo Tube, but mine flow a LOT better, & are much more heavily constructed. Plus, I have a family of TRUE 3" versions that sound much more brutal than any muffler on the market. If you want something really different, & really aggressive, you may want to look into them. The thing that always amused me about real chambered exhaust tubes, was the way they sounded so unique. The crimps in the outside casing of the mufflers are what do the sound tuning. They create a sound wave anamoly that no other muffler designs can duplicate.
Re: Dynomax mufflers VS Flowmasters [Re: Sunroofcuda] #1126521
12/04/11 05:56 PM
12/04/11 05:56 PM
MO, USA
Tom Hand Offline
Tom Hand  Offline
MO, USA
Pinkduster, not sure but the list they refer to may be the one Dad and I generated with all of our testing.
We chose to use only mufflers that were similar to stock sized mufflers or in the range of what were then being called turbo-sized. Mainly, we used the 14" and 20" body-sized case. Plus we had no reason to use single chamber mufflers as they are so loud no one could possibly stand to drive around with them too long or they might go deaf. :)
The other reason UltraFlo mufflers work so well is that they have inside diameter pipe that is actually slightly larger than the inlet and outlet bushings. We indeed saw (fantastic performance and) higher than 100% airflow numbers when we tested them as compared to equivalent lengths of straight, unperforated pipe.
Hope this makes sense.
Tom Hand
Re: Dynomax mufflers VS Flowmasters [Re: Tom Hand] #1126522
12/04/11 06:19 PM
12/04/11 06:19 PM
Birmingham, England
Mick70RR Offline
Mick70RR  Offline
Birmingham, England
I just like the sound of Flowmasters, that's why I use them. I fitted electric cutouts just after the collectors and my ET/mph is the same with them open or closed so they are not restrictive at my HP level. I use 3" delta 40's and 3" pipe all the way to the bumper.
Here's a nice clip of a Charger with Flowmasters.
http://www.youtube.com/watch?v=Hu8_uxk4hiM
1970 Road Runner 505 cid MCH CNC ported Stealth heads MP 528 camshaft 4 speed GV overdrive 11.98 @ 117 on street treads
Re: Dynomax mufflers VS Flowmasters [Re: Mick70RR] #1126523
12/04/11 11:36 PM
12/04/11 11:36 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
Nice! I'm one of the few that actually LIKE the sound of Flowmasters too. However, I'll try a set of the Ultra Flos next season. If they can get me over the 11.80s hump and into the 11.70s or .60s just by changing mufflers, then I'll be a Dynomax convertee. And I'll be sure to post my results on here.
Re: Dynomax mufflers VS Flowmasters [Re: pinkduster] #1126524
12/05/11 01:07 AM
12/05/11 01:07 AM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Truth be told, I like the way they sound too on most applications. One of my buddies has a 3" system on a '73 Rallye Charger & the car sounds great - REALLY nice! BUT, a few years ago we rode to a show in it 35 miles away & I'll tell you, the resonance was bad enough that I had a headache by the time we got there, plus my ears were ringing. Flowmasters do have the resonance thing really going on bad.
Re: Dynomax mufflers VS Flowmasters [Re: Sunroofcuda] #1126525
12/06/11 12:53 AM
12/06/11 12:53 AM
Granite Bay CA
Kern Dog Offline OP
Striving for excellence
Kern Dog  Offline OP
Granite Bay CA
I enjoy the sound of Flowmaster equipped cars. I must be one of the few that have a "drone-free" set of mufflers. I have a 440/493 with a 292/509 cam, TTI 2" headers, 2 1/2 pipes with 42451 Flowmasters and full tailpipes. Simply put, I found the chart listed in that other muffler post quite interesting and it made me curious. My exhaust system is 8 years old but looks and sounds new. I am not looking to replace rusty muffers here, I was just interested in what the flow rates translate to in terms of power.
Re: Dynomax mufflers VS Flowmasters [Re: Tom Hand] #1126526
12/07/11 08:27 AM
12/07/11 08:27 AM
Tennessee
Hemi ragtop Offline
Hemi ragtop  Offline
Tennessee
Tom Hand
All this talk about mufflers is interesting. Some of you are obviously very well infomrmed. I just wonder if any of you have tested Accurate LTD HEMI mufflers and what where the results?
Re: Dynomax mufflers VS Flowmasters [Re: Hemi ragtop] #1126527
12/08/11 12:12 AM
12/08/11 12:12 AM
MO, USA
Tom Hand Offline
Tom Hand  Offline
MO, USA
Hemi, you know, we never got a chance to test them but they will end up similar to the Dynomax Super Turbo offset in center out with a tad less airflow. The reason I say this is they are a reverse flow muffler (I believe) and they will act similarly to other three pass reverse flow mufflers except they have larger internal pass tubes that will drop the back pressure, lower the sound frequency and raise the sound level slightly. Without the patented "Flow Directors" however, they will lose a bit of air flow through them.
Accurate is a fine bunch of folks and I bet they have some actual numbers to share, you might email them and ask and please share if you find out.
Tom Hand
Re: Dynomax mufflers VS Flowmasters [Re: Tom Hand] #1126528
12/08/11 01:38 AM
12/08/11 01:38 AM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Yeah, I believe the Accurate Hemi mufflers are 3-tubes. They won't have the patented Super Turbo flow directors (bank turns) so that will slow things down internally. I've never looked inside an Accurate muffler to note the dia. of the flow tubes. If they neck-down like OE mufflers, that will also affect the flow quite a bit. Tom is on-target with his comments.
I'm guessing the Accurate Hemi mufflers will flow around 300-350 sCFM if tested the same way the Dynomax mufflers are tested.
To put into perspective, I brought in an NOS AAR/T/A muffler one day when I worked for Tenneco (mufflers for my AAR) & we flow tested it. It had a flow rate of 175 sCFM (BAD!). Then our head engineer designed a couple & our prototype dept. built them (stainless too). They did not have any flow directors on-hand when they built them, but they were built with larger cores. The ones they built had flow rates of 375 sCFM - a HUGE improvement. I tried to get these into production but to no avail............ I don't have my car close to running yet, so I don't know what they sound like. I can't wait though.
Re: Dynomax mufflers VS Flowmasters [Re: Sunroofcuda] #1126529
12/08/11 08:51 AM
12/08/11 08:51 AM
Royersford, PA
bschargerse Offline
bschargerse  Offline
Royersford, PA
Accurate sells a Hemi High-Flow muffler also. I wonder how that would compare... I have a set for my Charger that someday will get installed.
Brian - 1971 Dodge Challenger
"The Dodge, which was practically stock, just left the Mustang like you wouldn't believe."
Re: Dynomax mufflers VS Flowmasters [Re: bschargerse] #1126530
12/08/11 11:09 AM
12/08/11 11:09 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I'm a fan of the powersticks myself. awesome sound, but they can be loud. my dakota has 2 of the 31" x 3" versions, welded end to end, and I left that dumped at first. it sounded great, but my first long trip with it left my ears bleeding! I dug out some foamie ear plugs and stuck them in to finish the trip.
that could be because I had them dumped infront of the axle, could be tube length left a resonance, I don't know. I cut off the dump, added a 12" glasspack and then took the exhaust up and over the axle, and now it's angled down/back at 45 degrees so the sound shoots out from under the truck. just about everywhere I go, people come up and comment on how good it sounds, one guy even ran up to me as we were leaving Carlisle and wanted to know where I bought my "cat back" from. his eyes kind of glazed over with the "oh crap" look when I told him it wasn't a cat-back, but a full custom exhaust, but then seemed to come back a little bit when I told him I only had about $250 wrapped up in the whole system (he had been shopping cat-back exhausts which retail for some stupid number, like $500 for some pipe, a muffler, and tips.)
**Photobucket sucks**
Re: Dynomax mufflers VS Flowmasters [Re: 70Cuda383] #1126531
12/08/11 05:19 PM
12/08/11 05:19 PM
dogdays Offline
dogdays  Offline
My '64Dog has 2 1/2" Super Turbos 17748 or 9s (I can never remember which) running from the stock Poly manifolds out in front of the rear tires.
"Weedburners"
I have received several compliments from strangers who said it had "just the right sound". The pipes are probably too big for the 318 but I like'em that way.
If I do it again I'll extend pipes to the rear bumper to cut noise a little on those 600 mile trips.
R.
PS: Thanks for the measured data, it is worth much more than the butt dyno.
Re: Dynomax mufflers VS Flowmasters [Re: Sunroofcuda] #1126532
12/08/11 08:02 PM
12/08/11 08:02 PM
MO, USA
Tom Hand Offline
Tom Hand  Offline
MO, USA
Dogdays, 17748s are center outlets so that is likely what you run too. I have some spares around.
And as Eric said, the three pass mufflers are pretty similar. For reference, the old true Corvair Turbo 2.5" inlet/outlet muffler flows about 54% of an open pipe. The SuperTurbos, around 70% or so, UltraFlos around 100% and typical DeltaFlow Flowmaster-type mufflers around 53% or so, depending upon inlet/outlet configuration and length.
The patented flow directors do add a lot to the air flow potential through the three pass SuperTurbo mufflers even if the pass tube diameters are slightly smaller than inlet and outlet bushings.
The old stock mufflers are in the range of 35% or so. My VOE is about 33% then switches up to about 55% or so. Not super hot-rod performance but better than some others you can buy and I have the option of running quieter than stock but as loud as chambered mufflers. :)
Tom Hand
Re: Dynomax mufflers VS Flowmasters [Re: Sunroofcuda] #1126533
12/09/11 09:40 PM
12/09/11 09:40 PM
Witness Protection Program
Kudakidd Offline
Kudakidd  Offline
How do Super Turbos compare to Ultra flows? BTW, I have Super Turbos on my Duster right now. Will the Ultras be louder and provide more HP?
Re: Dynomax mufflers VS Flowmasters [Re: Kudakidd] #1126534
12/10/11 01:35 AM
12/10/11 01:35 AM
Eden, Texas
Strawdawg Offline
Strawdawg  Offline
Eden, Texas
The post above yours gives a comparison as to how they relate. If you make enuf power, they will allow it with less restriction, but, you have to be making serious hp.
IMO, they sound different, but, not necessarily that much louder. Again, a lot of the "sound" depends upon engine combination, in my experience.
Steve
Re: Dynomax mufflers VS Flowmasters [Re: Strawdawg] #1126535
12/12/11 12:59 PM
12/12/11 12:59 PM
IL
furious70 Offline
furious70  Offline
IL
Anyone know who makes Summit's turbo mufflers and how well they flow? I've got their 3" ones on my Fury, and some people on the turbo board suggested they may be part of my high back pressure measurements on my turbo system.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Dynomax mufflers VS Flowmasters [Re: furious70] #1126536
12/28/11 07:07 PM
12/28/11 07:07 PM
IL
furious70 Offline
furious70  Offline
IL
Is there much of a performance difference between the 14" and 20" bodies on the superturbos? Much of a decibel difference?
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Dynomax mufflers VS Flowmasters [Re: Sunroofcuda] #1126537
12/28/11 09:01 PM
12/28/11 09:01 PM
Kudakidd Offline
Kudakidd  Offline
Funny how the little "single" chamber Flowmaster wasn't on that list, just the two and three chambers.
Here's what the single chamber FM looks like on the inside - looks like the exhaust instantly hits a wall upon arrival into the muffler. This causes a huge backlash, which is NOT good. I'd rather run a longer one! We tested 2 & 3 chamber, & Delta Flow FM's when I worked at Dynomax. The 2.5" AND 3" of these series FM's had flow rates of right around 350 sCFM. This translates into 318 loss-free HP with a dual exhaust setup. The Super Turbo 17748 (2.5" x 20" Hemi Super Turbo) has a flow rate of 415 sCFM, which = 378 loss-free HP dual exhaust. A straight-through stainless 2.5" Ultra Flow (#17289 offset/center) has a flow rate of 955 sCFM, which allows 868 loss-free HP on dual exhaust. This is the best flowing 2.5" x 20" oval, offset/center muffler on the market, bar none. The deflector setups inside the Flowmaster mufflers are horrible for flow - they totally kill the flow velocity of the exhaust. Buy them for sound, but not performance.
BTW, a Dynomax 3" x 20" offset/center oval Super Turbo #17769 flows 551 sCFM, which provides 500 loss-free HP on a dual exhaust. A 3" Welded Ultra Flow (20" body, offset/center) #17233 flows 1800 sCFM thus providing 1636 loss-free HP. You can decide from here!
Great write up!
Re: Dynomax mufflers VS Flowmasters [Re: furious70] #1126538
12/28/11 09:05 PM
12/28/11 09:05 PM
Central NC
gch Offline
gch  Offline
Central NC
See above.
The longer case will flow better and be quieter(if that's what you want).
Re: Dynomax mufflers VS Flowmasters [Re: gch] #1126539
12/28/11 11:04 PM
12/28/11 11:04 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Most of this discussion is based around 2 1/2" exhaust but I have 3" on my car and I have plenty of room for the largest case they make.
Is there a Dynomax muffler longer than 20" with a 3" in and out?
Gus
64 Plymouth Savoy
Dana 60
Page 2 of 3 1 2 3
