Page 6 of 10 1 2 4 5 6 7 8 9 10
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125375
01/05/12 12:43 AM
01/05/12 12:43 AM
Northern MN
1E2C Offline
1E2C  Offline
Northern MN
So, what's the latest, Larry? Did you take the whole holiday period off?
Mike
Re: Junkyard D150 Progress [Re: 1E2C] #1125376
01/05/12 01:30 AM
01/05/12 01:30 AM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
HI Mike; Happy New Year. Well the frame is all painted and I have the pullies figured out; Trying to decide on a rear end/spring combination. I know scratch has a truck 8 3/4 and that would be the easiest but I am open to other combinations. I'd like to get the complete drivetrain complete in the next month or so, so I can move on to the body work. Did you ever find out what rear is under your parts truck? Talk to you soon.
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125377
01/05/12 11:28 AM
01/05/12 11:28 AM
Northern MN
1E2C Offline
1E2C  Offline
Northern MN
Hey Larry, Happy New Year to you too. The parts truck has an 8.25 pegleg with the 2.9 gears. There's a 77 C body 9.25 out there also, it's a S/G with 2.something gears also, don't remember the ratio though. Did you ever find a core tranny? I think I may have one of those if you haven't.
Mike
Re: Junkyard D150 Progress [Re: 1E2C] #1125378
01/05/12 06:21 PM
01/05/12 06:21 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Hi Mike, pm me on what you want for the core as I talked to quickd100 about building me one. I have a line on 2 truck 8 3/4 housings, so we'll see how that pans out. I have the same rear in my truck as you do in the parts truck..
Thanks for your help
Hey, it's 43 degrees out and the snow is melting....
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125379
01/05/12 06:45 PM
01/05/12 06:45 PM
scratchnfotraction Offline
heres a shot of the truck housing i have
i sand blasted it and painted it gloss black with some art work
Re: Junkyard D150 Progress [Re: scratchnfotraction] #1125380
01/05/12 06:48 PM
01/05/12 06:48 PM
heres my A-body one in the 88 truck
art work is optional
I like it myself and have allways done 8 3/4s up this way since i was 15 and started driveing
Re: Junkyard D150 Progress [Re: scratchnfotraction] #1125381
01/05/12 06:55 PM
01/05/12 06:55 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
And I am sure that most people see that art work as you are leaving them in the dust!!!
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125382
01/05/12 10:36 PM
01/05/12 10:36 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
maybe if it ever gets a tranny in it LOL. Come on Scratchy,,, "Get er done"
I am truckless..
Re: Junkyard D150 Progress [Re: 340SHORTY] #1125383
01/05/12 11:28 PM
01/05/12 11:28 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Finally got the pulley mess figured out, as I was running a federal pump before and now I am running a saginaw press on 3/4"
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125384
01/05/12 11:33 PM
01/05/12 11:33 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Found a brand new March 531 pulley on ebay for about 1/3 the cost; this pulley is originally for a chevy but March lists it for a big block mopar with a press on saginaw pump. Had to use spacers to achieve the correct pulley alignment. Because it is a lot smaller than original I went back to my smaller crank pulley so I would'nt overspeed the pump bearings.
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125385
01/05/12 11:37 PM
01/05/12 11:37 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Had to clearance (grind) the oil pump boss on this MP/World Block to achieve some belt adjustablility with this type of pump. The federal pump also needed clearancing but not as much.
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125386
01/26/12 07:23 PM
01/26/12 07:23 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Little update on the D150:
1) Received a real nice 8 3/4 housing from moparmarks; it was nice with no pitting and arrived well preserved with oil. Outside and inside in excellent condition.
2) 1E2C provided me with a core 727 and quickd100 is rebuilding it as we speek with a hughes performance race kit.
3) doctordiff fixed me up with a pair of high strength axles with green bearings installed.
4) scratchinfotraction has provided me with an over abundance of tips and knowledge on this build.
I am still hunting for a good 8 3/4 chunk and a torque converter, but I assembled what I had and will probably go with caltracs after my CC stops smokin!!! One thing I can say is: it is a heck of lot cheaper to build up a truck than an A/B/E body. Here are a few pix
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125387
01/26/12 07:36 PM
01/26/12 07:36 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Pix of brake
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125388
01/26/12 07:40 PM
01/26/12 07:40 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Doctordiff axles
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125389
02/02/12 09:54 PM
02/02/12 09:54 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Well things are moving right along; quickd100 dropped off my tranny after he overhauled it with the good parts and performed some magic on the valve body. I installed a deep pan and pickup from Mancini and a new dipstick from Bouchillon. My converter should be here the end of next week and then I can marry up the motor and trans.
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125390
02/02/12 10:30 PM
02/02/12 10:30 PM
and made good use of the mopar sticker
do you have a front tag yet?
any ideas for one yet?
i have one for it if you need something to start out with
Re: Junkyard D150 Progress [Re: scratchnfotraction] #1125391
02/02/12 11:13 PM
02/02/12 11:13 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Mike, unfortunately ND is one of those states that require a front and rear plate; but you can get a personalized plate that is very easy to get as the state population is low....
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125392
02/03/12 12:21 AM
02/03/12 12:21 AM
Northern MN
1E2C Offline
1E2C  Offline
Northern MN
Looks like it's coming right along Larry, keep up the good work.
Re: Junkyard D150 Progress [Re: 1E2C] #1125393
02/13/12 10:05 PM
02/13/12 10:05 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Thanks for the kind words Mike.
Torque converter showed up today and I was finally able to marry up the two and bolt everything in...
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125394
02/13/12 10:11 PM
02/13/12 10:11 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Another angle
