Re: Coolant through the tailpipe: what's the cause? [Re: 1968RR] #1124165
12/01/11 01:47 AM
12/01/11 01:47 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
I just noticed that the wire ran across a coolant port and an oil hole before going into the cylinder.
That's what I was going to go with..
Re: Coolant through the tailpipe: what's the cause? [Re: dodgeboy11] #1124166
12/01/11 09:36 AM
12/01/11 09:36 AM
Elk Grove, Calif.
bigblock340power Offline
Elk Grove, Calif.
I didn't vote, 'cause to simply say one way or the other without pulling things apart wouldn't help you. Do the work and find out.
Now if this is just a poll to find out how many guessed right, I can see the reasoning. Either way, coolant coming out your tail pipe isn't going to be a fix without some tools flying around the shop!
