Hiding the HEI module, mech regulator cars.... #1122777
11/28/11 12:31 AM
11/28/11 12:31 AM
Madison Wi
NTOLERANCE Offline OP
Madison Wi
I plan to run an HEI module on my mopar electronic distributor. Came up with a creative place to put it.
It will look odd, since I plan to use the solidstate regulator to run the alternator, but the strange looks will be worth it.
Re: Hiding the HEI module, mech regulator cars.... [Re: NTOLERANCE] #1122778
11/28/11 12:33 AM
11/28/11 12:33 AM
Madison Wi
Madison Wi
Second pic. If you remove all the mechanical regulator stuff, one mounting hole and one locating hole line up. I ground the other locating tab and drilled one hole. Some dielectric grease, and if warranted an aluminum plate, and its out of sight.
(hopefully this is in the right forum this time)
Re: Hiding the HEI module, mech regulator cars.... [Re: NTOLERANCE] #1122779
11/28/11 12:34 AM
11/28/11 12:34 AM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
Thats cool just make sure its grounded and has heat sink paste on the back. You could mount it under the distributor too if you have an aftermarket smooth billet style. Thats a good swap.
Re: Hiding the HEI module, mech regulator cars.... [Re: NTOLERANCE] #1122780
11/28/11 12:37 AM
11/28/11 12:37 AM
& where is the electronic reg mounted!
Re: Hiding the HEI module, mech regulator cars.... [Re: RapidRobert] #1122781
11/28/11 12:47 AM
11/28/11 12:47 AM
Madison Wi
Madison Wi
Right where the balast resistor goes. Since I wont be using it, just need to redo the harness a bit.
Re: Hiding the HEI module, mech regulator cars.... [Re: pishta] #1122782
11/28/11 12:48 AM
11/28/11 12:48 AM
Madison Wi
Madison Wi
Yes, I meant heatsink compund, not dielectric. Thanks!
I know about the dist. bracket, nice piece.
Re: Hiding the HEI module, mech regulator cars.... [Re: NTOLERANCE] #1122783
11/28/11 01:48 AM
11/28/11 01:48 AM
Central US
grancuda Offline
grancuda  Offline
Central US
What's the advantage of an HEI set-up vs the mopar elec. ignition or Pertronix?
Re: Hiding the HEI module, mech regulator cars.... [Re: grancuda] #1122784
11/28/11 02:13 AM
11/28/11 02:13 AM
Madison Wi
Madison Wi
Good spark and simplicity
http://duster318.freeservers.com/tech/hei.html
Re: Hiding the HEI module, mech regulator cars.... [Re: NTOLERANCE] #1122785
11/28/11 04:39 AM
11/28/11 04:39 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
it doesnt fail like the infamous ORANGE box does..
cheaper if it does fail
havnt seen the disr adapter plate lately. Is it still out there?
I am truckless..
Re: Hiding the HEI module, mech regulator cars.... [Re: 340SHORTY] #1122786
11/28/11 08:10 AM
11/28/11 08:10 AM
Berlin, N.J.
abodyjoe Offline
abodyjoe  Offline
Berlin, N.J.
a second voltage regulator?? not sure that looks right. why not gut a normal ecu and wire it to the pins and use the stock electronic style plug..
even this little bracket http://www.designed2drive.com/ would look a lot cleaner then a second regulator.
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
Re: Hiding the HEI module, mech regulator cars.... [Re: abodyjoe] #1122787
11/28/11 08:22 AM
11/28/11 08:22 AM
Berlin, N.J.
abodyjoe Offline
abodyjoe  Offline
Berlin, N.J.
Re: Hiding the HEI module, mech regulator cars.... [Re: NTOLERANCE] #1122788
11/28/11 11:30 AM
11/28/11 11:30 AM
I've always used dielectric compound, What's that other stuff that I should be using? brand/Part #
Re: Hiding the HEI module, mech regulator cars.... [Re: RapidRobert] #1122789
11/28/11 12:02 PM
11/28/11 12:02 PM
Eden, Texas
Strawdawg Offline
Strawdawg  Offline
Eden, Texas
Robert, normally the modules come with a little pack of compound, but, many people use this
http://www.radioshack.com/product/index.jsp?productId=2102858 and I have also used Arctic Silver compound from my pc building.
Di-electric is just silicone and does not have anything in it to assist in heat transfer as I under it.
Steve
Re: Hiding the HEI module, mech regulator cars.... [Re: RapidRobert] #1122790
11/28/11 12:04 PM
11/28/11 12:04 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Dielectric grease is for electrical connectors to keep them from oxidizing and keeping water out , it's not for transfering heat.
Re: Hiding the HEI module, mech regulator cars.... [Re: JohnRR] #1122791
11/28/11 12:07 PM
11/28/11 12:07 PM
Thanks Dawg, I'll call/visit RS
Re: Hiding the HEI module, mech regulator cars.... [Re: NTOLERANCE] #1122792
12/01/11 12:59 PM
12/01/11 12:59 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
why don't you make what Don's at FBO is making with the "Brand new "Mopar" Ecu module"?. Find some old ECU, remove the inners and fit inside the HEI, module, using the stock 5 pins ECU plug
