Page 3 of 3 1 2 3
Re: Made some Stuff At Work Today [Re: RAMM] #1121300
11/27/11 07:20 PM
11/27/11 07:20 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
Beautiful work. When I worked in the toolroom at a diecasting plant several years ago, that's what we called it too! Government jobs, usually on a night shift. J.Rob
We call jobs like that "Foreigners", to which I do many!
Alan Jones
Re: Made some Stuff At Work Today [Re: Hot 340] #1121301
11/28/11 03:26 AM
11/28/11 03:26 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
How did you get that finish on the valley plate? Did the stock come like that or did you hit it with some sort of abrasive roll/belt sander? If it came like that, what kind of aluminum stock is that?
regular 1/2" 6061. Hit it with some alcohol and scotch-brite.
Nice work, but did you consider making it a 2 piece? Or make it with a removable panel to be able to work in the lifter valley without pulling a head.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Made some Stuff At Work Today [Re: Evil Spirit] #1121302
11/28/11 07:40 PM
11/28/11 07:40 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Didnt consider making it a two piece or anything. Im lazy.
Re: Made some Stuff At Work Today [Re: Evil Spirit] #1121303
11/28/11 10:02 PM
11/28/11 10:02 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
If you cut it right. You pull the bolts slide if forward and it will come right up. This is only on tall decks. On short decks the plate sits over the heads.
Leon
Re: Made some Stuff At Work Today [Re: Leon441] #1121304
11/28/11 10:37 PM
11/28/11 10:37 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Leon
Yep, it slides out with the heads on it. I think it will clear the front of the car..
Re: Made some Stuff At Work Today [Re: Hot 340] #1121305
11/29/11 03:31 AM
11/29/11 03:31 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Leon
It does - now. Problem is after it's been stuck in place with sealer. It only took us 1 time of removing the plate out of an Indy headed B/B to cut the plate into a 2 piece.
Don't get me wrong - it's a beautiful piece and I am in no way trying to knock it's quality. I was just asking about making it in a 2 piece version - I may be changing my combo in the future and may need a valley plate made.
Page 3 of 3 1 2 3
