Re: Made some Stuff At Work Today
[Re: Guitar Jones]
#1121280
11/26/11 11:02 AM
11/26/11 11:02 AM
Posts: 3,998 GO BUCKS !!!!!!!
340RICK
GO BUCKS !!!!!!!
Beautiful work. I take it you have access to more than just a hacksaw, cutoff wheel and a die grinder.
That is small block jewelery right there.
[Re: Guitar Jones]
#1121285
11/26/11 12:32 PM
11/26/11 12:32 PM
Posts: 22,873 Chicken coop
dustergirl340
Chicken Little
Chicken Little
Chicken coop
Really nice work...prettier and more useful than jewelry.
[Re: dustergirl340]
#1121288
11/26/11 05:31 PM
11/26/11 05:31 PM
Posts: 3,397 Pa
Hot 340
Pa
Thanks. And GJ, We even have a hammer and chisel laying around somewhere.
[Re: MR_P_BODY]
#1121289
11/26/11 05:36 PM
11/26/11 05:36 PM
Posts: 3,397 Pa
Hot 340
Pa
Thanks for the compliments guys.. its always fun to make racecar parts. Hitman, I was on the fence about using phenolic, probably should have used it, but didnt. Not sure about nylon, I would make sure it could stand the temps. Worst part about phenolic is working with it, yuck.
Yeah that phenolic makes some bad dust
Its awesome stuff, hard as nails, probably the best temp insulator out there, but I have to jump in the shower the minute I get home from working with it. It makes you so itchy. Even if you use coolant, somehow it finds you .
Re: Made some stuff at work today
[Re: RAMM]
#1121292
11/26/11 06:56 PM
11/26/11 06:56 PM
BradH
... In fact I am on another forum marketing a line of .125" plastic gaskets (the last pair of intake gaskets you'll ever need). J.Rob
A non-Mopar forum, I assume?
Plan to do anything along those lines for BB Mopars?
[Re: Hot 340]
#1121293
11/26/11 08:07 PM
11/26/11 08:07 PM
Posts: 20,679 in a cattle trailer down by th...
Guitar Jones
Dang a hammer AND a chisel?!? You guys must be like ISO 9000 compliant or something.
All cerial aside you do some very, very nice work.
[Re: RAMM]
#1121295
11/26/11 08:38 PM
11/26/11 08:38 PM
Posts: 601 Niles, Michigan
Hitman340
Niles, Michigan
Jesse It was your Engine I was referring to.Sorry Im not sure why I thought it was nylon.I really thought it was a great idea you had.
[Re: Hitman340]
#1121296
11/26/11 08:43 PM
11/26/11 08:43 PM
Posts: 1,051 The Great White North
RAMM
Jeff it was great to meet you and you probably thought Nylon 'cuz its white. I have a set of black gaskets made that will probably work just as well. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
[Re: WO23Coronet]
#1121297
11/26/11 10:31 PM
11/26/11 10:31 PM
Posts: 3,397 Pa
Hot 340
Pa
How did you get that finish on the valley plate? Did the stock come like that or did you hit it with some sort of abrasive roll/belt sander? If it came like that, what kind of aluminum stock is that?
regular 1/2" 6061. Hit it with some alcohol and scotch-brite.
[Re: Hot 340]
#1121298
11/26/11 11:22 PM
11/26/11 11:22 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
I made spacers out of Phenolic resin for my 468 small block. The heads were lightened and I needed to seal off the cut out portion of the head. My valley plate is just alluminum with some lightening done underneath. I had to use 3/8 to maintain a seal between the phenolic and the valley tray.
The following year Bishcoff had phenolic spacers on his Engine masters build. I was tickled when he said he had seen it at the track and couldn't remember where. Course I had to let the cat out of the bag and tell him where he saw it.
With enough vacuum I still could loose the seal. So later I fixed the heads.
Nice work
Leon
