Page 2 of 3 1 2 3
Re: OK season's over time for "DON'T ASK ME HOW I KNOW' [Re: slantzilla] #1120903
11/25/11 11:13 AM
11/25/11 11:13 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
When racing your street car at night, turning on the defroster also turns on the A/C compressor, and will slow you down a couple tenths in the 3rd round. DAMHIK
Re: OK season's over time for "DON'T ASK ME HOW I KNOW' [Re: slantzilla] #1120904
11/25/11 11:28 AM
11/25/11 11:28 AM
Charleston, SC
SCDaytona Offline
SCDaytona  Offline
Charleston, SC
When you tow to a race track 200 miles away, make sure you bring your wallet with money, driving license and racing license. Ask me how I know!
Re: OK season's over time for "DON'T ASK ME HOW I KNOW' [Re: SCDaytona] #1120905
11/25/11 12:20 PM
11/25/11 12:20 PM
Lenox Iowa
MMiller Offline
MMiller  Offline
Lenox Iowa
If the vaccumn gauge is bouncing at home and the engine doesn't seem right, it won't fix itself hauling it on the trailer. Keep it home and get it right before going to the track.
Michael
93 W250 CTD getrag, Bosch 185 injectors, AFE air filter. Trailer puller, daily driver,
90 W250 CTD 727 with smokin 5" stacks. Off road truck
75 Dodge W200 440 4spd 4x4 locked front and rear, twin disc clutch, E85. Pulling truck
Re: OK season's over time for "DON'T ASK ME HOW I KNOW' [Re: SCDaytona] #1120906
11/25/11 12:27 PM
11/25/11 12:27 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
After sending your ignition box in for repairs, installing it and calling them because it doesn't work. First be sure you hooked it up at the master cut-off switch. Don't ask me how I know. Jim
Re: OK season's over time for "DON'T ASK ME HOW I KNOW' [Re: rt66jim] #1120907
11/25/11 12:38 PM
11/25/11 12:38 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
When you grab that rear axle on wheels to roll it across the lot, do not grab the pinion snubber to hold up the center section. DAMHIK!
Re: OK season's over time for "DON'T ASK ME HOW I KNOW' [Re: slantzilla] #1120908
11/25/11 01:56 PM
11/25/11 01:56 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
Re: OK season's over time for "DON'T ASK ME HOW I KNOW' [Re: bonefish] #1120909
11/25/11 02:28 PM
11/25/11 02:28 PM
Dearborn Hts, MI
Sledge_57 Offline
Sledge_57  Offline
Dearborn Hts, MI
when your on the way to the trak and you cant beleive how well your tow rig is runnin,make sure you put the car back in the trailer.DONT EVEN ASK.
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker
Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
Re: OK season's over time for "DON'T ASK ME HOW I KNOW' [Re: slantzilla] #1120910
11/25/11 02:53 PM
11/25/11 02:53 PM
A shed in England
Tig Online work
Tig  Online Work
A shed in England
When monitoring Left & Right AFR's and tearing your hair out with bizarre staggered jetting results. Make sure the O2 sensors are actually monitoring the sides you think they are.
"Dont ask me how I know"
Re: OK season's over time for "DON'T ASK ME HOW I KNOW' [Re: emarine01] #1120911
11/25/11 03:13 PM
11/25/11 03:13 PM
Idaho, USA
W
White440 Offline
White440  Offline
W
Idaho, USA
If you put a screwdriver in to hold the throttle plate open when compression testing..... remember to remove it before starting up the engine.... & never hold a hot cup of coffee over your lap when you realise that the throttle is jammed wide open ... Dont ask me how I know
Mine was a big gulp Pepsi.
"Full throttle until you see GOD then brake!" <img src="/ubbthreads/images/graemlins/drive.gif" alt="" /> Life's to short to ride the brakes!
Re: OK season's over time for "DON'T ASK ME HOW I KNOW' [Re: HEMIFRED] #1120912
11/25/11 04:21 PM
11/25/11 04:21 PM
Alberta Canada
StrokerAspen Offline
Alberta Canada
When you are racing a Dodge Aspen from 1976 with all factory brake equipment in place, be sure the codder pins on the brake pedal pin are still in place. It may leave you stranded in the burn out box in the final round of the night.
DON'T ASK ME HOW I KNOW...
Re: OK season's over time for "DON'T ASK ME HOW I KNOW' [Re: StrokerAspen] #1120913
11/25/11 05:10 PM
11/25/11 05:10 PM
Guitar Jones Offline
When you buy a new tow vehicle don't wait until you're late leaving for a race to find out the trailer plug isn't wired correctly. Don't ask me how I know.
Re: OK season's over time for "DON'T ASK ME HOW I KNOW' [Re: Guitar Jones] #1120914
11/25/11 05:59 PM
11/25/11 05:59 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Never assume you took out the hood scoop plug.
When your carb is sealed tightly to the hood it's really amazing how fast the top of the scoop will get sucked down doing a 5K burnout during the 3rd on a night when your drivers door latch is messed up
DAMHIK
Re: OK season's over time for "DON'T ASK ME HOW I KNOW' [Re: WILD BILL] #1120915
11/25/11 06:07 PM
11/25/11 06:07 PM
PA
moparacer Offline
moparacer  Offline
PA
After an all night thrash to fix a broken rear, don't assume because the wheels were put back on the car that they were tightened......
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: OK season's over time for "DON'T ASK ME HOW I KNOW' [Re: moparacer] #1120916
11/25/11 09:14 PM
11/25/11 09:14 PM
Lehigh Acres, Florida
rickstershemi Offline
When you pull up first in line at a National Event Elimination Run, make sure you put your helmet in the car....Don't ask me how I know.
Rickster
Re: OK season's over time for "DON'T ASK ME HOW I KNOW' [Re: rickstershemi] #1120917
11/25/11 09:42 PM
11/25/11 09:42 PM
Coon Rapids, Minn.
MW Racecraft Offline
Coon Rapids, Minn.
Been there, done that
Re: OK season's over time for "DON'T ASK ME HOW I KNOW' [Re: MW Racecraft] #1120918
11/26/11 12:00 AM
11/26/11 12:00 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Always be sure you put the cap back on the fuel cell after topping it off.
The resulting "waterfall" coming out of your trunk will REALLY annoy the track crew should this little tidbit slip your mind.
DAMHIK
Re: OK season's over time for "DON'T ASK ME HOW I KNOW' [Re: WILD BILL] #1120919
11/26/11 12:10 AM
11/26/11 12:10 AM
gregsdart Offline
gregsdart  Offline
When the throttle feels mushy during the burnout, be sure and check to see you CO2 bottle is on to work the throttle controler and the air shifter,
Re: OK season's over time for "DON'T ASK ME HOW I KNOW' [Re: WILD BILL] #1120920
11/26/11 12:18 AM
11/26/11 12:18 AM
Super Scamp Offline
Super Scamp  Offline
Going to a race 300 miles away fully loaded, all gased up food in frig,everything you can think of in motorhome and trailer and when you get to the track and get all setup (Thursday night). Went to go get a cold beer Yep you know it !!!! left it in the garage 3 cases of beer..
Just One Man's Opinion Mopar Mafia Racing
Re: OK season's over time for "DON'T ASK ME HOW I KNOW' [Re: Super Scamp] #1120921
11/26/11 02:25 AM
11/26/11 02:25 AM
Columbus, Ohio
wheelsup68dart Offline
Columbus, Ohio
If you wreck your car early in the season, don't keep feeding it money to limp it by till the end of the season.. Park it, do it right, and come back when Karma is back on your side. DAMHIK, Oh yeah, if running a CO2 throttle stop make sure when you set your regulator pressure cold it does not change when the interior gets 150 degrees. DAMHIK
Re: OK season's over time for "DON'T ASK ME HOW I KNOW' [Re: HEMIFRED] #1120922
11/26/11 03:50 AM
11/26/11 03:50 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I have a few shameful my self
If your door windows are removable make sure you take them with you to the track
"DON'T ASK ME HOW I KNOW"
If you move your seat to a new position make sure to try it out with your helmet to make sure it fits at home...not at the track
If the "R" on Freds keyboard is broken......Don't ask me how I know!
Page 2 of 3 1 2 3
