Re: Any MSD Street Fire users? [Re: mikemee1331] #1120111
12/02/11 10:49 PM
12/02/11 10:49 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
I got mine today and it says on the front of the box, USA MADE.
Are there people having issues with dial back timing lights and MSD? My light is an old Craftsman dial back. It appears that if mine does not like the MSD, then my old standard timing light with some timing tape is a cheap fix for the initial timing and then I can use the dial back when checking total timing above 3000rpms.
There is a tach note in the instructions that some might have issues reading this box but the list says that Autometer (my tach brand) does not. good note.
Thanks everyone.
Re: Any MSD Street Fire users? [Re: YO7_A66] #1120112
12/03/11 07:01 PM
12/03/11 07:01 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
These boxes are fairly small. Check out the difference between the orange box and the Street Fire unit.
This unit will mount directly to my existing Challenger ECU mounting bracket with the top two holes. The bottom two holes I will run ground wires from. I will take another picture once it is fully installed but so far, the wiring is going quick.
Re: Any MSD Street Fire users? [Re: YO7_A66] #1120113
12/03/11 07:12 PM
12/03/11 07:12 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
I had previously taken some measurements, and your photo confirms what I thought.
I plan to fab up a bracket similar to the stock bracket and mount mine in the factory firewall holes.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: Any MSD Street Fire users? [Re: YO7_A66] #1120114
12/03/11 07:32 PM
12/03/11 07:32 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
Thanks everyone.
it's all CD type ignitions not just MSD. i'm pretty sure you will like the box. there's a huge difference in starting, idling and you might be able to open your spark gap more. i wouldn't do that right away though.
Re: Any MSD Street Fire users? [Re: mikemee1331] #1120115
12/04/11 03:32 PM
12/04/11 03:32 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
This is the unit installed.
Re: Any MSD Street Fire users? [Re: YO7_A66] #1120116
12/05/11 01:45 PM
12/05/11 01:45 PM
dogdays Offline
dogdays  Offline
Glad to hear it's made in the USA. I've run gaps around 0.045" with my 6A.
R.
