Re: Anyone ever upgraded their engine to Propane? [Re: Pyper70] #1119634
11/24/11 12:16 PM
11/24/11 12:16 PM
The Wet Coast, Canada
megajoltman Offline
megajoltman  Offline
Wow...I clearly havent given this much thought....I do not want to turn my engine bay into this. I am guessing these are purely for LPG as a fuel on your vehicle. Guessing that since I want dual fuel I will need an atomizer on top of each Edelbrock. My six pack air cleaner may end up having to be removed, may end up with a inverted scoop hood. I guess since I have the dual quad intake that tunnel ram you made will not be needed for my application. I'm at aesthetics now. I should be looking at the performance aspect. Im gonna shoot a few more emails, see the cost of installing it. Talked with a friend of mine who knows another dude who works at an installation shop...might go pay him a visit and get the skinny.
I thank you all for mentioning your real world applications. If anyone has more to add I will happily read.
yes it is quite ugly, this was built to run only on propane and more for function than form (daily driver 4x4).There was lots of room under the hood so placing everything right there was the easiest and cheapest way to go. Also this system was built well over 15 years ago so there is much better equipment out there now.
Only real problem I had was finding avaliable places to fill up and once there if anyone on staff was qualifed to pump it
1969 Dart 383/727/D60
CTD Ram 4x4 Mega Cab
Procharged 350Z
Re: Anyone ever upgraded their engine to Propane? [Re: Pyper70] #1119635
11/24/11 02:15 PM
11/24/11 02:15 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
I'm late to the party here, but there were two dual fuel cars in the family back in the mid 1970's - the days of oil embargoes and CA state subsidies for "clean air" stuff. One conversion was my sister's 1972(?) AMC Hornet 258 and the other was my dad's 1971 Newport with a 383 magnum. Both were done by the same outfit, and shared the same basic setup.
Here's what I recall:
Tank in the trunk, taking up much of the space in the Hornet, and fitting easily in the Newport.
Had a state sticker that exempted us from the state tax on propane (early tree-hugger "clean air" stuff). Got us a good price at the pump, but you had to fill up at a short list of propane stations. You could not buy from the fill-your-BBQ-tank deal behind the gasoline station.
Exemption from NOx retrofit requirements.
Delivered liquid from the tank to an underhood mixer. If I remember correctly, the mixer had engine coolant plumbed to it.
The system used the throat of the carburetor as the propane delivery device, with a large metal elbow in place of the air cleaner assembly.
To switch between fuels, the driver hit an electrical toggle switch (fuel cutoff valves) AND pushed or pulled a plunger (cabled to the air diverter).
Power was noticeably down when running on propane, and overall vehicle performance [no matter the fuel] was not helped by lugging around a big propane tank in the trunk. The hornet got sold with the equipment on it, but the Newport was traded in on my dad's next car, and the dealer absolutely required that the propane stuff be removed. I took it off for him, and had the use of the car for the weekend before turning it in on Monday. Boy am I sorry I didn't have a chance to drive the Newport longer - that car was a surprisingly fast car running on gasoline and not carrying around all the propane stuff.
On a dual fuel car running propane through the carb, it is ABSOLUTELY NECESSARY to run it on gasoline periodically. My dad was not as careful as he should have been on this point. One time, the car was run out of propane after not running on gas for a long time. I was tasked to drive it down to fill it with propane. It ran like crap, started smoking at the end of the trip, and died just as I pulled up beside the twenty foot tall tanks of propane.
Trivia:
a. A sixteen year old on adrenaline can single-handedly push a 1971 Newport about 50 feet, especially if it is on fire beside twenty foot tall tanks of propane.
b. There are a surprising number of fire extinguishers on hand at a propane station, and even the clerical help in the office are willing to wield them if it seems necessary.
Down to just a blue car now.
Re: Anyone ever upgraded their engine to Propane? [Re: fullonmopar] #1119636
11/25/11 02:01 AM
11/25/11 02:01 AM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
I speed read through this post, sorry if duplicate... I did some brief research on this a few years ago, and the deal killer (if you must keep your car legal (and laws may vary)) was that the high pressure tanks have a limited lifespan. The vehicle itself may have years of life left in it, but when the tank certification expired, the vehicle was basically scrap. Replacement tank costs exceeded the value of the vehicle.
The law states in OZ that any pressure vessel (inc vehicle lpg tanks) must be examined for internal rust, dents, welding fatique etc every 10 years and the average cost by a licensed inspector is $200 because the tank has to be removed from the vehicle. Very few tanks fail and the same tank is reuasable for another 10 years once certified and date stamped. Some earlier tanks were stainless steel to save weight but they tended to get damaged easier because they are much thinner and the welds tended to be porous. If a tank fails a test second hand tanks with a fresh certification only cost $300 fitted by a licenced gas fitter. The laws here are very strict and mechanics have to do an intensive course to be able to fit LPG to cars and their work is often subject to random inspections.
Here in Maryland (little California ), I was looking at gov't auctions for mid-90's mopar small block trucks and B-vans and Y2K ish Ferd Crown Vics that were factory set up for LNG. They were basically going for near salvage value because the tanks had expired. I stopped looking at that point, maybe I quit researching too soon. The other HUGE problem here was that only local governments were supporting these vehicles so re-fueling stations were VERY limited, you'd need to drive 20 miles out of your way to fuel up. However, I have also seen regular gas stations in other areas (near Fairmont and Morgantown, West Virginia, IIRC) that were situated close to natural gas production and sold LNG freely to the public. Good if you live in one of these areas.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Anyone ever upgraded their engine to Propane? [Re: megajoltman] #1119637
11/25/11 10:21 AM
11/25/11 10:21 AM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
Upgrade? Tonight a Taxi from San Francisco ran out of fuel at a bad spot. He said it was Propane. Nearest station was not close. Not for me. I drove a Crowne Vic in Houston w/Propane. Good performance, frequent fueling.
The (overpriced) Tesla owners park in the sun. Wind is less than 2% of our power. I'll take conventional fossil fuel anytime. I step on the gas and it goes. I need fuel and it is easily found.
Re: Anyone ever upgraded their engine to Propane? [Re: DennisH ] #1119638
11/25/11 11:53 AM
11/25/11 11:53 AM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
Well 90% of the gas stations in Greece have AutoGas (LPG/Propane) so there isn't a problem there. If I do go ahead with it, it will be dual fuel...so even if one runs out, you have the other to scoot you home.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Anyone ever upgraded their engine to Propane? [Re: GO_Fish] #1119639
11/25/11 12:43 PM
11/25/11 12:43 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
I few years ago
when I was searching salvage yards online
looking for
factory Dodge 1992-1995 5.2 CNG vehicles,
I noticed that there were a lot of
Propane conversion 5.2/5.9 V8 Dodges
in salvage yards in Canada
and some in the far northern USA.
Apparently in the early 1990's the Canadian government had a tax incentive program to convert vehicles to Propane.
At late year 2011 current prices
CNG is a lot less expensive than
Propane.
As a rough 'rule of thumb'
you can take the
'cost per million Btu' price of natural gas,
divide by 10
then add in 50 cents
to find the
"Gasoline equivalent price" of CNG
With bulk
Natural gas prices
around
$ 3.57 per million BTU fon the futures markets
0.357 plus 0.50
= 86 cents per gallon fuel
Propane is in the
$2 to $3 per gallon range in the summer
when prices are best,
and you need to increase this by about 15% to reflect the LPG heating value difference compared to
117,000 BTU per US gallon
average 87 octane
USA pump gasoline
{even less in winter blend}
Re: Anyone ever upgraded their engine to Propane? [Re: 360view] #1119640
11/25/11 01:28 PM
11/25/11 01:28 PM
hawaii
P
pauly v.100 Offline
pauly v.100  Offline
P
hawaii
Re: Anyone ever upgraded their engine to Propane? [Re: pauly v.100] #1119641
11/25/11 03:22 PM
11/25/11 03:22 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
Bring enough popcorn for everyone?
Re: Anyone ever upgraded their engine to Propane? [Re: 68HemiB] #1119642
11/25/11 03:37 PM
11/25/11 03:37 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Trivia:
Re: Anyone ever upgraded their engine to Propane? [Re: 1_WILD_RT] #1119643
11/25/11 03:41 PM
11/25/11 03:41 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Trivia:
Life sure was boring before youtube and you could share circumstances like that with the rest of us.
Re: Anyone ever upgraded their engine to Propane? [Re: 360view] #1119644
11/26/11 02:59 AM
11/26/11 02:59 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
I have been giving this a lot of thought for my 79 Pick up,
Here is a video of a Dodge truck dual fuel...
http://www.youtube.com/watch?v=cO-1M24qFiI
Re: Anyone ever upgraded their engine to Propane? [Re: sthemi] #1119645
11/26/11 05:18 AM
11/26/11 05:18 AM
Australia
fullonmopar Offline
fullonmopar  Offline
Australia
http://www.gasresearch.com.au/
These people design LPG units for drag cars and diesel powered vehicles, as the name suggest they do a lot of R & D into LPG systems.
Re: Anyone ever upgraded their engine to Propane? [Re: fullonmopar] #1119646
11/26/11 11:49 PM
11/26/11 11:49 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
Alot of neat stuff on that site
