Re: 63/65 rear axle
[Re: DoctorDiff]
#1119408
11/24/11 11:41 AM
11/24/11 11:41 AM
Posts: 75,125 A Banana Republic near you.
JohnRR
Bearing Technologies (Green Bearing Company) makes the narrow lock ring.
In fact, ST-400 Green bearings come with the narrow ring included in the kit. BTW, the only difference between the MO-400 and ST-400 Green bearings is the width of the lock ring.
Can a person buy just the narrow lock ring ?
Looks like a 62/63 8.75 could be a good donor for an A body swap ?
Re: 63/65 rear axle
[Re: JohnRR]
#1119410
11/24/11 12:42 PM
11/24/11 12:42 PM
Posts: 12,495 Western Colorado High Desert
moparmarks
1-3/8" wider than an A-body. Run a 5-1/2" back space wheel. I have a 62 rear. Have a couple A-bodies.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
Re: 63/65 rear axle
[Re: moparmarks]
#1119411
11/24/11 12:55 PM
11/24/11 12:55 PM
JohnRR
I was thinking stock offset small bolt pattern , less than an inch wider.
Re: 63/65 rear axle
[Re: JohnRR]
#1119412
11/24/11 01:09 PM
11/24/11 01:09 PM
moparmarks
Either way. I'm wanting LBC cuz I have the 73-up disc. Been looking for an A 8.75. Move the perches in 1" and get set of axles from Cass at the MATS and vala?? Could it be that easy John?
