Re: 63/65 rear axle [Re: DoctorDiff] #1119408
11/24/11 11:41 AM
11/24/11 11:41 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Bearing Technologies (Green Bearing Company) makes the narrow lock ring.
In fact, ST-400 Green bearings come with the narrow ring included in the kit. BTW, the only difference between the MO-400 and ST-400 Green bearings is the width of the lock ring.
Can a person buy just the narrow lock ring ?
Looks like a 62/63 8.75 could be a good donor for an A body swap ?
Re: 63/65 rear axle [Re: JohnRR] #1119409
11/24/11 12:19 PM
11/24/11 12:19 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I stock a few narrow lock rings. I normally sell them as part of my super-duty A-7 adjustable wheel bearing kits, however.
Your best bet is Strange Engineering.
Re: 63/65 rear axle [Re: JohnRR] #1119410
11/24/11 12:42 PM
11/24/11 12:42 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
1-3/8" wider than an A-body. Run a 5-1/2" back space wheel. I have a 62 rear. Have a couple A-bodies.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 63/65 rear axle [Re: moparmarks] #1119411
11/24/11 12:55 PM
11/24/11 12:55 PM
JohnRR Offline
JohnRR  Offline
I was thinking stock offset small bolt pattern , less than an inch wider.
Re: 63/65 rear axle [Re: JohnRR] #1119412
11/24/11 01:09 PM
11/24/11 01:09 PM
moparmarks Offline
moparmarks  Offline
Either way. I'm wanting LBC cuz I have the 73-up disc. Been looking for an A 8.75. Move the perches in 1" and get set of axles from Cass at the MATS and vala?? Could it be that easy John?
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: 63/65 rear axle [Re: moparmarks] #1119413
11/25/11 12:16 AM
11/25/11 12:16 AM
JohnRR Offline
JohnRR  Offline
Many don't even bother moving the perches , just force it on the springs .
