Page 2 of 3 1 2 3
Re: 71 Road Runner / GTX Air Grabber Hood cars- Hood Paint [Re: Butterscotch71] #1118296
11/23/11 02:38 PM
11/23/11 02:38 PM
Berwyn, IL
Moparlar Offline
Moparlar  Offline
Berwyn, IL
Did painting the back of the hood also mean painting the cowl area under the vents black sorta of like when they black out behind the grilles.
Larry
Re: 71 Road Runner / GTX Air Grabber Hood cars- Hood Paint [Re: Moparlar] #1118297
11/23/11 02:49 PM
11/23/11 02:49 PM
home of the Buckeyes
Butterscotch71 Offline
Lost Title
Lost Title
Larry
That should be the case, although I believe dark colors did not get the cowl blackout....I' have to check, but I believe the factory engineering docs do indicate which colors did (didn't) require the blackout.
addict:to devote or surrender (oneself) to something habitually or obsessively ....hmmmm
Re: 71 Road Runner / GTX Air Grabber Hood cars- Hood Paint [Re: Butterscotch71] #1118298
11/23/11 02:58 PM
11/23/11 02:58 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
Also, I have details for stripes that were never factory installed on cars (obviously discontinued before production).
that would be very interesting to see..
any way to share??
Re: 71 Road Runner / GTX Air Grabber Hood cars- Hood Paint [Re: Butterscotch71] #1118299
11/23/11 03:02 PM
11/23/11 03:02 PM
Fort Worth, Texas
xs29j8 Offline
xs29j8  Offline
Fort Worth, Texas
Larry
The cowl blackout was for all cars, regardless of hood type or hood paint... except for colors listed on the attached drawing.
Re: 71 Road Runner / GTX Air Grabber Hood cars- Hood Paint [Re: flypaper] #1118300
11/23/11 03:04 PM
11/23/11 03:04 PM
Fort Worth, Texas
xs29j8 Offline
xs29j8  Offline
Fort Worth, Texas
any way to share??
No, sharing is not allowed...
Re: 71 Road Runner / GTX Air Grabber Hood cars- Hood Paint [Re: xs29j8] #1118301
11/23/11 03:06 PM
11/23/11 03:06 PM
Fort Worth, Texas
xs29j8 Offline
xs29j8  Offline
Fort Worth, Texas
any way to share??
Strictly forbidden...
Re: 71 Road Runner / GTX Air Grabber Hood cars- Hood Paint [Re: xs29j8] #1118302
11/23/11 03:15 PM
11/23/11 03:15 PM
Fort Worth, Texas
xs29j8 Offline
xs29j8  Offline
Fort Worth, Texas
any way to share??
Don't try to change my mind...
Re: 71 Road Runner / GTX Air Grabber Hood cars- Hood Paint [Re: xs29j8] #1118303
11/23/11 03:22 PM
11/23/11 03:22 PM
Fort Worth, Texas
xs29j8 Offline
xs29j8  Offline
Fort Worth, Texas
any way to share??
Re: 71 Road Runner / GTX Air Grabber Hood cars- Hood Paint [Re: xs29j8] #1118304
11/23/11 04:03 PM
11/23/11 04:03 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
On the engineering drawings -
0 = all
**** so the "MODEL" line would read G/R-0-23 1971/Plymouth B-body-ALL-2 door hardtop RM23 (Road Runner) & RS23 (GTX)
$ = extra-cost OPTION
I also agree that the drawing & Plymouth's "intent" was to have the vent area of the "AIR GRABBER" hood (behind the insert) painted with "organisol". The issue that is clouding the topic is V21 or "our" interpretation of what it is.
1 - I can find no evidence of V21 being an orderable OPTION (with or without cost)
2 - It is included with OPTION A87 $85.60 on Road Runners - "Road Runner Decor package"
3 - Road Runners & GTXs were assembled at 3 different plants in '71 - coding differed from plant-to-plant & during the year
Re: 71 Road Runner / GTX Air Grabber Hood cars- Hood Paint [Re: 6bblgt] #1118305
11/23/11 04:17 PM
11/23/11 04:17 PM
Fort Worth, Texas
xs29j8 Offline
xs29j8  Offline
Fort Worth, Texas
0 = all
Thanks Dan! I was fairly sure the "O" meant all, but was not sure what the symbols were or meant... makes sense now tho. Is the symbol before "A93" a "$"...? I guess it would be...
So, in your opinion, does the paint application apply to all A/G equipped cars... at least from a drawing interpretation standpoint, regardless of how it was actually built?
Re: 71 Road Runner / GTX Air Grabber Hood cars- Hood Paint [Re: xs29j8] #1118306
11/23/11 04:40 PM
11/23/11 04:40 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
Larry
The note indicates "ORGANISOL HOOD ONLY" - so cowl blackout was on N96 cars ONLY!!
All available '71 colors except - GF7 GB7 GY9 TX9
Re: 71 Road Runner / GTX Air Grabber Hood cars- Hood Paint [Re: 6bblgt] #1118307
11/23/11 05:11 PM
11/23/11 05:11 PM
Fort Worth, Texas
xs29j8 Offline
xs29j8  Offline
Fort Worth, Texas
Larry
I interpreted the note to mean Organisol as an alternate only on Organisol painted hoods... it appears I was mistaken.
Re: 71 Road Runner / GTX Air Grabber Hood cars- Hood Paint [Re: 6bblgt] #1118308
11/23/11 05:50 PM
11/23/11 05:50 PM
Lost Title
Lost Title
While V21 does not show as a separate line in the pricing guide, it would be very easy to fill in the line on the order sheet (car specification schedule) as it has boxes at the top right for V codes (V with a blank for fill in).
If the logic followed that it was not orderable, no GTXs should have V21 (or all should). I have a 71 Xs in my records that have V21 on the standard hood and some that do not (non-N96 hood indent pinstripes)....both fender tag and broadcast sheet codes. If this was only available with the A87 (ROAD RUNNER decor package) then there should be no way a standard hood GTX would have the pinstripes (or all should if it was standard GTX).
Without getting into the fender tag coding differences between build plants, I can tell you that the V21 code is not dependent on build plant, and I have a good mix of N96 cars from all plants with and without V21 on the tags.
0 = all
Re: 71 Road Runner / GTX Air Grabber Hood cars- Hood Paint [Re: Butterscotch71] #1118309
11/23/11 05:54 PM
11/23/11 05:54 PM
Lost Title
Lost Title
Not to say these were always correct, as they were published before the production start, but here's a photo from the 71 Data Book (courtesy of Hamtramck Historical)
Re: 71 Road Runner / GTX Air Grabber Hood cars- Hood Paint [Re: Butterscotch71] #1118310
11/23/11 06:29 PM
11/23/11 06:29 PM
Lost Title
Lost Title
After looking very carefully through my database,
I believe the following to be correct for 71s:
GTX
N96 - V21 blackout was standard
non N96 - V21 pinstripes were standard but could be omitted
Road Runner
N96 - V21 blackout was optional (and included in A87)
non N96 - V21 pinstripes were only available with A87
Re: 71 Road Runner / GTX Air Grabber Hood cars- Hood Paint [Re: Butterscotch71] #1118311
11/23/11 09:14 PM
11/23/11 09:14 PM
Fort Worth, Texas
xs29j8 Offline
xs29j8  Offline
Fort Worth, Texas
While V21 does not show as a separate line in the pricing guide...
Do you have a complete set of supplements?... See Challenger example below.
Re: 71 Road Runner / GTX Air Grabber Hood cars- Hood Paint [Re: xs29j8] #1118312
11/23/11 11:05 PM
11/23/11 11:05 PM
Lost Title
Lost Title
Yes I have the suppliments for the Satellite line and as I mentioned they do not list V21
Re: 71 Road Runner / GTX Air Grabber Hood cars- Hood Paint [Re: Moparlar] #1118313
12/04/11 02:09 PM
12/04/11 02:09 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
I looked at my 72 today and it looks like the back of the hood was painted as well as the cowl area inside the hood gasket.
Larry
The 72 V21 is a completely different animal. My car is an example of the '72 V21/V25 stripe code, available only on N96 cars.
Bottom silhouette represents the V21/V25 option:
(photo credit Hamtramck-Historical)
It is my understanding that a 72 should not have the blackout extended to the back of the hood.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: 71 Road Runner / GTX Air Grabber Hood cars- Hood Paint [Re: 471Magnum] #1118314
12/04/11 02:49 PM
12/04/11 02:49 PM
Berwyn, IL
Moparlar Offline
Moparlar  Offline
Berwyn, IL
Larry
Maybe mine got painted since it is a first week august built car.
Larry
Re: 71 Road Runner / GTX Air Grabber Hood cars- Hood Paint [Re: Butterscotch71] #1118315
12/04/11 04:53 PM
12/04/11 04:53 PM
MN
ryangtogtx Offline
ryangtogtx  Offline
MN
GTX
Road Runner
Eric, are you saying that even though my car is not coded for V21 on the 2 broadcast sheets I have, it should be painted on my car?
Page 2 of 3 1 2 3
