Re: Soft Brake Pedal after bleeding 3 times?????
[Re: HelleOnWheels]
#1117228
11/20/11 09:25 PM
11/20/11 09:25 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
No sir,
Ignorant would have been to keep going the way you were never asking for any assistance and assuming you knew it all.
Have you gotten a chance to adjust and re bleed them yet?
[Re: WILD BILL]
#1117229
11/20/11 10:02 PM
11/20/11 10:02 PM
Posts: 228 FL
HelleOnWheels
FL
No sir,
Not yet....We are in the market for a new home and were out shopping most of the day.
I am planning on doing them tomorrow night after work with my dad....a little father/son brake job bonding
[Re: WILD BILL]
#1117231
11/21/11 08:31 PM
11/21/11 08:31 PM
WILD BILL
BROOK PARK, OH
[Re: Moparmick]
#1117233
11/21/11 11:21 PM
11/21/11 11:21 PM
Posts: 4,628 Columbus, Ohio
wheelsup68dart
Columbus, Ohio
I know the way you are describing to bleed the brakes and it will work as you stated if you do one more step. The cup with your brake fluid must be held above the the bleeder screw itself. If I am understanding your procedure properly you are attatching a hose to the bulb of the bleeder, opening bleeder, pumping brake pedal to force air out and suck fluid back in. Then close bleeder. Like stated, your results will be better if cup with fluid is above, not below bleeder. I do prefer to use the traditional method of pumping three times, holding, cracking bleeder, closing, release pedal. Repeat till no air seen. Another vote here to put plugs in M/C and pump slowly till you should feel the pedal get very firm. And very good advice to not push the pedal all the way to the floor when bleeding as it can damage the seals in the M/C. If you need to isolate the wheel affected you can clamp off the rubber hose at the rear splitter and see if the pressure gets better, indicating air in rear. Same applies to each of the front hoses. And other good info regarding brake shoe adjustments.
[Re: HelleOnWheels]
#1117236
11/23/11 01:40 AM
11/23/11 01:40 AM
WILD BILL
BROOK PARK, OH
How many times go you go back around each wheel?
Sometimes it takes going from RR, LR, RF, , LF and then checking the adjustment on all 4 and doing it again.
Sometimes I will adjust the drums really tight to bleed and then back them off to the proper adjustment afterwards.
As for how it should feel, I haven't done a 4 wheel drum system in many years so I couldn't help without being there and or driving it.
Sorry.
[Re: RapidRobert]
#1117238
11/24/11 12:53 AM
11/24/11 12:53 AM
Posts: 228 FL
HelleOnWheels
FL
Spent alot more time adjusting each wheel and making sure they were closely matched to each other. Went around and bled the wheels again and it is much better. Took it out for the first time in 12 years and things went great The only thing I noticed was that I have no dash lights Now on to the next issue....at least this one wont keep me from driving it!!!! Picked up my passes to the Turkey Rod Run on my test drive and things are looking great for my weekend!!!!!
[Re: HelleOnWheels]
#1117239
11/24/11 01:26 AM
11/24/11 01:26 AM
WILD BILL
BROOK PARK, OH
That's what I like to hear
Have a happy Thanksgiving
[Re: WILD BILL]
#1117240
11/24/11 09:38 AM
11/24/11 09:38 AM
Posts: 228 FL
HelleOnWheels
FL
Thanks Bill!!
Hope you have a Happy Thanksgiving as well!!!!
[Re: HelleOnWheels]
#1117241
11/24/11 09:52 AM
11/24/11 09:52 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Glad you got it worked out! manual brakes should DEFINITELY have a firm brake pedal. but, how firm depends on what size master vs what size wheel cylinders. you can "soften" the brake pedal by going to a smaller master or larger wheel cylinders, and doing so will also increase your brake effort without increasing pedal feel/leg input. go drive that car!
**Photobucket sucks**
[Re: 70Cuda383]
#1117242
11/24/11 11:16 AM
11/24/11 11:16 AM
Posts: 228 FL
HelleOnWheels
FL
go drive that car!
You don't have to tell me twice!!!!!
