Re: 48 Plymouth business coupe, Dakota frame, low bucks
[Re: Hemi Allstate]
#1116488
11/29/11 09:50 PM
11/29/11 09:50 PM
Posts: 10,599 Freeport IL USA
poorboy
Freeport IL USA
Thanks guys. Funny thing about that Dakota, I stripped almost all the sheet metal from the structure before it left. I also kept anything I remotely thought I might be able to use, the trunk of the coupe and a shelf in my garage are full of Dakota parts. I even had a full sized Dodge truck here that has become a Dakota parts storage unit. LOL. As the build progresses, you will see many more Dakota parts showing up. As your looking at the pictures, keep in mind, the Dakota was originally white, and the coupe was black. Anything you see that is or was white came off the Dakota, sheet metal included.
I didn't have a chance to get new pictures of the door bottom build, so that installment may come out of order. Gene
[Re: 56_Royal_Lancer]
#1116490
11/30/11 08:12 PM
11/30/11 08:12 PM
Posts: 1,186 OHIO
THE GLASS MAN
OHIO
Inspiring build, that's for sure. Ability has always impressed me much more than money.
And how is the 56 coming along?
[Re: bboogieart]
#1116492
12/02/11 03:17 AM
12/02/11 03:17 AM
poorboy
Freeport IL USA
I got a couple pictures of the door bottom & door corners. I need to make a bunch of poor excuses with these pictures. All of the "new" metal welded in here was from the hood & box sides from the Dakota. When the metal was welded on, I only removed the paint from the weld area, the welding was done outside on a couple of pretty windy days, I was trying to close up the car before winter set in. After the welding was done (minutes after) the whole area was spray bombed with cheap black paint over dirt, cracked old paint, and still warm welds that were not ground down.
With that in mind, The passenger side door was cut off just below the lower door hinge but a previous owner. What your looking at is a hand formed inner door panel, welded to a hand formed outer panel patch. There are also pictures of the door corners, I didn't want the 90 degree door bottoms.
