Re: Why can't i mount a msd blaster 2 horizontal? [Re: A12] #1116164
11/18/11 10:44 PM
11/18/11 10:44 PM
How do we know which ones might leak?
Call Don at FBO & in the meantime go from the prob to the solution w a bracket like Andy's
Re: Why can't i mount a msd blaster 2 horizontal? [Re: RapidRobert] #1116165
11/18/11 11:15 PM
11/18/11 11:15 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
No I'll need to buy another brand or type of higher performance than stock coil that mounts horizontal. Used it because I wanted it to look stock in the past and was going to use it on the GTX for the same reason. This is an older MSD Blaster on my '68 rr painted black, on an Edelbrock aluminum CHB4, (Edelbrock and numbers ground off ) with an electronic distributor with the ECU mounted inside under the dash and the ECU wiring run inside of the stock wiring harness and through the bulkhead junction (red wire). That's a Holley SA under there with a nice cam and kind of stock looking. Doing the same with the '69 GTX so I need to figure out if the MSD Blaster I have now will work?
MikeR
Re: Why can't i mount a msd blaster 2 horizontal? [Re: A12] #1116166
11/18/11 11:29 PM
11/18/11 11:29 PM
Careful, the terminals on the new 8202 Blasters are junk too.
I barely tightened the + wire on mine and it broke and stripped the threads.
$40 down the toilet!
Car runs fine with an old black Chrysler coil.
Re: Why can't i mount a msd blaster 2 horizontal? #1116167
11/19/11 12:41 AM
11/19/11 12:41 AM
Surface of the Sun, AZ
Hotwheelsjr Offline
Hotwheelsjr  Offline
Been running mine horizontal for years with no issues.
Re: Why can't i mount a msd blaster 2 horizontal? [Re: Hotwheelsjr] #1116168
11/19/11 12:46 AM
11/19/11 12:46 AM
Howell, Michigan
Hemidavey Offline
Hemidavey  Offline
Howell, Michigan
All 4 cars running horizontal for years, never had a problem, now they will leak!
Re: Why can't i mount a msd blaster 2 horizontal? [Re: cjs69mope] #1116169
11/19/11 12:54 AM
11/19/11 12:54 AM
No Mas
Re: Why can't i mount a msd blaster 2 horizontal? [Re: AndyF] #1116170
11/19/11 01:00 AM
11/19/11 01:00 AM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
Hughes has a little L bracket that mounts the coil vertically.
http://www.hughesengines.com/Index/produ...mp;partid=25486
That's pretty cool. Will it fit under a 70-72 B-body Air Grabber 383/400 or 440 air cleaner base?
Re: Why can't i mount a msd blaster 2 horizontal? [Re: 73rrak] #1116171
11/19/11 07:11 AM
11/19/11 07:11 AM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
Vertical and in the wind for me !!!!!
Thats how I ended up putting mine...In the wind as you said it
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Why can't i mount a msd blaster 2 horizontal? [Re: Pyper70] #1116172
11/19/11 10:44 AM
11/19/11 10:44 AM
ILLinois
DartGTS Offline
super street
DartGTS  Offline
super street
ILLinois
Hello
MSD get it together...$250 for dist. $175 for control box (AL-6). Top line stuff. I agree on that.
Then a coil that leaks??
Where is your Quality???
Why do we settle for this??
Maynard
Re: Why can't i mount a msd blaster 2 horizontal? [Re: RapidRobert] #1116173
11/19/11 11:43 AM
11/19/11 11:43 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
According to MSD tech forums a coil mounted sideways may run to hot since not all the coils will be submersed in cooling oil. I just got a dry Blaster SS that I plan on mounting today.
68 Barracuda Formula S 340
Re: Why can't i mount a msd blaster 2 horizontal? [Re: Bad340fish] #1116174
11/19/11 12:06 PM
11/19/11 12:06 PM
ill
dennismopar73 Offline
ill
Mine mounted upside down on my pulling truck????
