Re: new 440 motor wont start? [Re: mopar_man] #1115584
11/18/11 03:13 PM
11/18/11 03:13 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
i tested everything accourding to the procedure that someone posted a link to . i tested the resistor, the ECU , the distributor, and still cant figure it out.
it does have spark when i pull the wire off to test it. it is getting fuel to the carb, i probably only poured 2 ounces down the carb , may be i should try more , i just didnt want to start a big fire!
i checked the distributor timing 3 times to make sure it was on the compression stroke firing.
i think it must have fired at least once since the plug i pulled was a little black , and they were new plugs.
it has sat a while since being built. must be at least 2 or 3 months.
i am going to check over everything again and may be try it tomorrow.
Re: new 440 motor wont start? [Re: dirt] #1115585
11/18/11 03:17 PM
11/18/11 03:17 PM
It's getting fire when someone cranks it w the key. 2oz probably drowned it! Time that dist/clean plugs/shot of starting fluid & it'll go
Re: new 440 motor wont start? [Re: RapidRobert] #1115586
11/18/11 04:09 PM
11/18/11 04:09 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Turn the ignition switch to "on" position and then cross the relay with a screwdriver. I had trouble with an ignition switch in the column that did not always provide power to the ECU. Sometimes when releasing the key from the start position to on power was lost, sometimes not. Since this is an initial start-up it wouldn't hurt to raise the idle some so when it does start you keep the lifters rotating.
...FAFO...
Re: new 440 motor wont start? [Re: dirt] #1115587
11/18/11 04:28 PM
11/18/11 04:28 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
FWIW 2 oz is not enough to fire a six pack. It has very long runners. I filled my primary bowl full when I fired mine for the 1st time. id you pull the coil wire and crank and check for spark? Did you pull a plug wire, jam a screw driver in it and check for spark? With the key "on" did you check the ballast side of the coil? you said you had 6v at the coil...that is not enough juice.
Re: new 440 motor wont start? [Re: Mr.Yuck] #1115588
11/18/11 08:50 PM
11/18/11 08:50 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
i could not get hemi to fire was getting fuel and spark well check the gas and it was almost like water swaped it out tried to fire but not run so turned the idel screw in 2 full turns and the bad boy tried to run then lol
was weird cause took the carb off a running 440 but it needed more air on the hemi...
just a thought
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: new 440 motor wont start? [Re: toplescuda] #1115589
11/18/11 11:38 PM
11/18/11 11:38 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Are the carbs fresh too? If so, how do you know the float height is right? With this much cranking you should have plenty of gas in the center carb if you pop out the sight plug you should be able to find some signs of gas. Also when pumping the throttle by hand, does the accelerator pump spray fuel? FWIW, I started my last fresh engine up with an electric fuel pump to avoid fuel supply issues on the first start-up.
Re: new 440 motor wont start? [Re: dirt] #1115590
11/18/11 11:47 PM
11/18/11 11:47 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
i did convert to electronic ignition.
"Orange box" of death?
Re: new 440 motor wont start? [Re: skicker] #1115591
11/20/11 12:56 AM
11/20/11 12:56 AM
ohio
67mprfan Offline
67mprfan  Offline
ohio
very nice satellite wish there was a 65 sitting beside it
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: new 440 motor wont start? [Re: 67mprfan] #1115592
11/21/11 10:15 AM
11/21/11 10:15 AM
E Central IN
N
nd65 Offline
nd65  Offline
N
E Central IN
Check the pick-up gap in the distributor. It should be gapped .004 to.008.
Re: new 440 motor wont start? [Re: nd65] #1115593
11/21/11 02:52 PM
11/21/11 02:52 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
The guy that built the motor stopped in this morning. he put a cloths pin on the choke flap to hold it open, pumped the throttle and said give it a try. i jumped in and hit the key and it fired up instantly!
the only other thing i did was charge the battery up to 13.5V this time. it was at 12.5 before.
it ran smooth and everything seems good. we let it run for probably a half hour at 2000 - 2500 rpm probably.
the only problem was that the alternator wasnt charging and before he shut the motor off he reved it up and the alternator shot lightning out of its self. it looked like a scene from back to the future right before he warped through time.
thanks for all the good advice, kenny
