Re: 451 low deck
[Re: CompWedgeEngines]
#1114837
11/18/11 12:09 AM
11/18/11 12:09 AM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
RIP Monte Smith
Re: 451 low deck
#1114838
11/18/11 12:11 AM
11/18/11 12:11 AM
CompWedgeEngines
Syracuse,NY
440 crank with no turned counterweights, only clearanced block, but needed chamfered counterweights
RIP Monte Smith
Re: 451 low deck
#1114839
11/18/11 12:14 AM
11/18/11 12:14 AM
CompWedgeEngines
Syracuse,NY
Also a 451...
RIP Monte Smith
Re: 451 low deck
[Re: dogdays]
#1114843
11/18/11 01:23 PM
11/18/11 01:23 PM
Posts: 9,888 Weddington, N.C.
Streetwize
Weddington, N.C.
Dog, Yeah I remember Arias would make you a 451 slug, with a .990 pin and you had to bronze bush your LY (or my prefered 383) rods. The undersize of the slug had "427" (chevy BB) cast into it. You're right Arias and Venolia were about the only 2 Piston players that would make you one back then. It was expensive but fun times, very 'hush-hush' back then in the pre F.A.S.T. days when we had a few very quick '383's trawling around
Re: 451 low deck
[Re: Streetwize]
#1114844
11/18/11 02:02 PM
11/18/11 02:02 PM
CompWedgeEngines
Syracuse,NY
Everyone ( the customer ) has different needs,wants,expectations and especially budgets . I would love to sell every single customer a new crankshaft,rods and pistons. That would be a perfect World indeed. The reality is that simply isnt going to happen. When you build enough engines as a business, and not a hobby, you find out you deal with an incredible cross section of " personalities". They have many many different requirements. This is where a builder needs to put himself in the customers shoes as if it was their money and build. I agree that its always best to use new parts whenever possible. I recently did a 451 with stock crank and stock 400 rods. There was no need for this guy to buy a new aftermarket crank and h beam rods. He took that money and put it into a set of Edelbrock heads. He wanted a torquey,simple drive it anywhere street car. Thats what he got. The original poster asked some specific questions obviously so he knew more about how to make 451. Does he need a new crank? I dont know. None of us know his budget or needs at this point. Good info here, but be careful of simply broadbrushing everyone into the same picture. Bobby, i do agree on the 4.250 crank motors much of the time. Usually just makes sense, but again, not everyone wants or needs maximum torque and horsepower. What did thoseu 431's go in amd how did they run? What heads and cams? I like the availability of the 383 blocks for the street/strip guys.
RIP Monte Smith
Re: 451 low deck
[Re: buck440]
#1114845
11/18/11 04:50 PM
11/18/11 04:50 PM
Posts: 1,397 Carson City, Nevada
Biginchmopar
Carson City, Nevada
All the work is in the crankshaft.
Mine makes 525hp 500tq at the rear wheels and is street driven on a regular basis.
so theres no block notching or a nothing like that?
NOPE!
Re: 451 low deck
[Re: buck440]
#1114850
11/19/11 03:22 PM
11/19/11 03:22 PM
CompWedgeEngines
Syracuse,NY
Please pm me your phone number
RIP Monte Smith
Re: 451 low deck
[Re: 440Jim]
#1114852
11/19/11 07:06 PM
11/19/11 07:06 PM
Posts: 16,930 NC
440Jim
NC
With typical 6.76" long connecting rods, a piston with a compression height about 1.32" puts the piston near zero deck. Some specific rod lengths, pistons, and block deck heights may result in the piston down the hole (low compression ratio); so check the details (especially the machined deck block height) of the parts you plan to use:
+9.980 Block deck height (could be 9.97x after machining) -1.875 Crank stroke divided by 2 (3.75/2) -6.768 Connecting rod length (many H-beams are 6.760") -1.320 Piston compression height ------ 0.017" below the deck
And be sure the pistons you buy use the pin diameter to match the connecting rods you use (1.094", 0.990" common)
Examples of pistons: Bore___CH__weight_ring pack sizes__piston pin size_ part no. 4.375, 1.320, 510g, 1/16, 1/16, 3/16, 1.094 x 2.930, 99494 Ross 4.375, 1.320, 527g, 1/16, 1/16, 3/16, 0.990 x 2.930, 99495 Ross 4.375, 1.313, 524g, 1/16, 1/16, 3/16, 1.094 x 2.930,131175 JE 4.375, 1.313, 525g, 1/16, 1/16, 3/16, 0.990 x 2.930,131174 JE 4.375, 1.300, 515g, 1/16, 1/16, 3/16, 0.990 x 2.930,K296A35 Wiseco
Check KB also. I don't know if all the above are still available, but they were stocking parts back then.
Re: 451 low deck
[Re: buck440]
#1114855
11/21/11 06:08 PM
11/21/11 06:08 PM
Posts: 1,093 Long Beach, CA
Mike Swann
Long Beach, CA
I have a 451 for sale . . . 3.45 x 4.560
Re: 451 low deck
[Re: larry890]
#1114856
11/21/11 07:07 PM
11/21/11 07:07 PM
Posts: 295 maryland
buck440
maryland
My 451 is low 700 hp, pushes my 3600lbs car 9.73to 9.85 all day. and the best news is its FOR SALE for way less than you could build it.
how much you can pm me if you like.
