A33 track pak package includes what?
#1114094
11/15/11 03:53 AM
11/15/11 03:53 AM
Posts: 1,992 midwest
68427vette
midwest
A33 69-71 Track Pak w/3.54 ratio i can find the link to the dealership, "package" brochure, dos anyone have it? does the a33 include a dana 60? the car is D21 4 speed/n96 1969 r/t
Re: A33 track pak package includes what?
[Re: JohnRR]
#1114096
11/15/11 09:31 AM
11/15/11 09:31 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
IIRC the "Super" track pac had the 4:10s..
I am truckless..
[Re: 68427vette]
#1114098
11/15/11 09:43 AM
11/15/11 09:43 AM
Posts: 5,123 Warrenton, VA
RoadRunnerJD
Warrenton, VA
A33 came with heavy duty (18 spline) 4 speed trans, Hurst shifter with wood grain ball, 9 3/4" 3.54 Dana rear, Hemi leaf springs, dual point Prestolite distributor, 7 blade torque drive fan (216 fan with 070 clutch),heavy duty radiator (054) with fan shroud.
[Re: RoadRunnerJD]
#1114099
11/15/11 11:25 AM
11/15/11 11:25 AM
Posts: 75,274 A gulag near you.
JohnRR
A gulag near you.
JD , I thought the rad in that package was the 055 ?
[Re: 68427vette]
#1114100
11/15/11 11:31 AM
11/15/11 11:31 AM
Posts: 1,028 NB, Canada
moparfan53
NB, Canada
Here are the A33 pages from the dealer data book and price list. Also, no offence to the posts above but A33 could have either 054 or 055 rad, both were 26".
[Re: moparfan53]
#1114102
11/15/11 01:37 PM
11/15/11 01:37 PM
JohnRR
A gulag near you.
But there is a difference in the rads , 055 is a 2 core 26" the 054 is a 3 core 26". I want to think it would have the 3 core, considering the 383 cars with 3.91's and 3.55's got the 054, but I seem to remember this being hashed out in the past and the answer was not as expected.
[Re: JohnRR]
#1114103
11/15/11 02:36 PM
11/15/11 02:36 PM
RoadRunnerJD
Warrenton, VA
The option included what Chrysler called the " Maximum cooling system" which is the 054.
[Re: RoadRunnerJD]
#1114104
11/15/11 02:42 PM
11/15/11 02:42 PM
JohnRR
A gulag near you.
That I know but in the brochure posted above it/s not called MAX cooling , they call it 26" High Performance Radiator w/fan shroud.
Refresh my memory , what was the 055 used with ?
[Re: RoadRunnerJD]
#1114108
11/15/11 06:16 PM
11/15/11 06:16 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
You may have had an auto trans and 8 3/4 rear? The high performance radiator is supposed to be the 054. The 055 is for A/C which is not available with 4 speed.
Not sure what you are asking? Yes the 8 3/4 is the standard diff for all engines with an auto and 383 regarless of tranny. My 440-6 car has no superperformance axle package and so has the standard 8 3/4.
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: DPelletier]
#1114109
11/15/11 07:55 PM
11/15/11 07:55 PM
RoadRunnerJD
Warrenton, VA
What I am saying is that I believe the 1969 high performance B-Body radiator is the 054. The 055 is for A/C cars where a performance axle package was not available. Otherwise, why would they call it an HP radiator if it's not the 054?
[Re: DPelletier]
#1114111
11/15/11 09:31 PM
11/15/11 09:31 PM
Posts: 21,747 It's a dry heat
gtx6970
It's a dry heat
None of the promotional data I have says 054 = High performance.... all they say is that Max cooling includes a "high capacity" 26" radiator and the axle packages include a "high Performance" 26" rad I don't know which is the 054 and which is the 055.
....so I guess you're saying the "high performance" rad = 054 and Bill is saying that based on his experience the "high performance" rad = 055.
Exactly. I've seen several original 440 4spd cars with the standard 3.54 dana and the 055 radiator.
I bought my former 1969 GTX vert from the 2nd owner. And I would dare say it was the original radiator in it.
440 4spd, 3.54 dana , manual steering and manual drum brakes, no power steering cooler obviously
