Re: A-833 4 speed racers...Setup?
[Re: LAR_414]
#1113631
11/14/11 08:25 PM
11/14/11 08:25 PM
Posts: 2,414 St. Croix, US Virgin Islands
David_in_St_Croi
We have a 70 RR currently with a Performance Only 452. 23 spline 833, no mods. 4.3 S60 with a true trac. Tim Hyatt built Mcleod based Soft-Lock clutch. Still playing around with clutch settings, have been dropping base pressure to as low as 3 turns. Original 383 rear leaf springs, have been clamping them and breaking 3/8" Grade 8 bolts on the clamps so clamping must be doing something. Shocks are stock from Advance Auto (I think, bought them when on a trip up to Babylon a few years back). Tires are Hoosier 9x29x15, D07 compound. Just getting used to those. Before were 9x28x15 D06 compound. Typically I launch 5000, 5500 hundred (no two step or anything) Generally if anything have wheelspin issues. Plan to add frame connectors when the engine comes out to fix the roller lifter that got lunched. Best time is 11.67 at around 120. 60 ft's down in the 1.61 range,although it claimed 1.45 once but I have to believe that was a timing light glitch. Car could really use cal-tracs and I am sure new springs and adjustable shocks. The front suspension is the same stock shocks and I have 1" torsion bars for our streets down here. I do drop the front end down until the bump stops are maybe 1/2" off the frame Tranny oil is 80-90 gear oil, Coastal brand I think. It is a blast, no way am I going auto. How long that 23 spline will continue to last in a 3800 pound RR time will tell. I am sure the Tim Hyatt clutch is a big factor in the tranny living. A Jerico or Nash would be nice eventually. I have no problem with non-synchro transmissions, either on the street or the track (actually would prefer it, but currently own the 833). On the street I just tighten up the clutch and put the street tires on. Sometimes I even put the mufflers back on. ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: David_in_St_Croi]
#1113633
11/14/11 08:52 PM
11/14/11 08:52 PM
Posts: 331 Cincinnati Oh
fasthawk6
Cincinnati Oh
23 Spline , center force clutch.Leave off a 2 step at 3500 rpm and runs 60 fts in the low to mid 1.6s on a 27/10 et street with caltracs and factory leafsprings.Has qa1 adj shocks all the way around. I shift at 7200 to 7400 with 4.10s and run 126 mph at 3470.Still a factory setup trans .
[Re: LAR_414]
#1113634
11/14/11 08:55 PM
11/14/11 08:55 PM
Posts: 3,427 Toronto
mshred
Toronto
Power level and e/t may be good ones to add in here as well...This past years setup is in my sig- junkyard bottom end 360 making maybe 320 to the wheels at the most based on e/t and mph calcs. 23 spline, powershifting every gear at the track Launching at 5k (didnt like 5500, so i went back down) shifting around 6-6100 (light is set at 5900) Trapping at about 5500 (needs more gear) 3400lb car with me in it Using a Centerforce Dual Friction 28x12.5 et streets, stock 6cyl springs and the full caltrac setup, not spinning much (maybe 1 turn?) For fluid I tried a bunch...right now running Castrol Type F in it, but im thinking of running heavy gear oil in it this upcoming season... transmission was always popping out of 2nd on decel and sometimes crunching on the 2-3 powershift towards the end of the season...picking a backup transmission up soon, and im going to refresh both over the winter This thing is never getting an auto ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: sshemi]
#1113636
11/15/11 08:53 AM
11/15/11 08:53 AM
fasthawk6
Cincinnati Oh
How do the centerforce df clutch work? does it slip and how fast does it wear out?
It does not slip. Seems to be a good clutch but depending on power level it can be hard on parts and wears seems to be good.
[Re: LAR_414]
#1113637
11/15/11 09:05 AM
11/15/11 09:05 AM
Posts: 1,240 Fairfield Maine
hemi4speed
Fairfield Maine
Original stock 4 speed 23 spline Power shifting at 62-6500 RPM Launching at 38-4000 (didnt like anything above 4500) 1.62 60ft best. original leafs with one full leaf added and clamped DF Centerforce the best non-ajustable street and strip clutch set up so far. Tires spin very little. 80-90 lube non syn best 7.52@ 93 mph 1/8 mile, should go high 11's in 1/4? 3350 with me in it Not at the track enough to get real consistant, but a blast to drive ![](/ubbthreads/images/graemlins/beer.gif)
[Re: LAR_414]
#1113639
11/15/11 12:13 PM
11/15/11 12:13 PM
Posts: 1,262 Netherlands
72Challenger
Netherlands
Rowing these gears is the best way to enjoy your car if you ask me. I changed to a 833 (18spline)couple of years ago resulting in breaking teeth of the gears, ruining clutches while trying different setups but all without any real luck. This all was with my street/strip challenger with 528 Hemi running 10's. In the end bite the bullet and got myself a tubechassis car and bought a GForce 4-speed and custom AC clutch setup to put behind the same pumpgas street engine. Results; 8,9's and it's still alive ![](/ubbthreads/images/graemlins/grin.gif) Can't improve the funfactor ![](/ubbthreads/images/graemlins/drive.gif)
[Re: 72Challenger]
#1113640
11/15/11 02:23 PM
11/15/11 02:23 PM
Posts: 202 Barboursville, VA
belvedere383
Barboursville, VA
My setup is:
65 Belvedere II 65 A833 w/ ball and trunion RXT twin Disc Launch at 3400-3500 slipping the clutch Goes like 1.70 60ft Usually shift it at 7200 80w90 gear oil in Trans
All of this behind a 496 B motor, it usually runs around 11.1x at around 125-126.
When I really get after it on the launch it breaks something, last time out I put the 2 step to 5500 and it broke the spring perches clean off of the rear end.
65' Belvedere
496'' Stroker Indy Heads
[Re: belvedere383]
#1113646
11/18/11 08:34 PM
11/18/11 08:34 PM
Posts: 4,013 South Park, Pa.
68LAR
South Park, Pa.
Seeing as how my son started this post I'll drop my combo for all to scrutinize. engine 446 ci big block car 68 Roadrunner weight 3926 with me in the seat Trans is stock 23 spline A833 no mods. trans fluid ATF dextron Launch rpm 49-5600 rpm depending on track conditions. shift 6400 rpm trap rpm 6300 slick pressure anywhere from 15 - 19 psi rear gear 4.56 Dana Clutch is Center Force Dual Friction 11" with aluminum flywheel (13 pounds) best et and mph is signature ![](/ubbthreads/images/graemlins/drive.gif)
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
