Re: What can I expect for E.T. [Re: 340Scamp] #1111156
11/12/11 10:15 AM
11/12/11 10:15 AM
JOPLIN MO 64804
RBDART1 Offline
RBDART1  Offline
JOPLIN MO 64804
Get a dp 750-800 min maybe single plane intake would say hi-11's feasable, I like the 4.30 gear, hard to say just have to tweak on it til u find its grove...had 69 dart 340 4spd 3.91'sg ld-340 750dp crane hyd 510-298 adj rockers ported x heads..headers home-made traction bars, 10.5comp .040flat-tops 10.5x27slicks ran best of 12.54 drove to work everyday[until it rained]Im a bblk fan but cut my teeth on 340's they aint no punk...
Re: What can I expect for E.T. [Re: RBDART1] #1111157
11/12/11 11:17 AM
11/12/11 11:17 AM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
Thanks everyone. I forgot to mention this is a street car. I think anything steeper than 4.10's will be to much for the street. It's a 750 Performance carb. Thanks again.
Well, we narrowed it down to mid 11's - high 13's
A better carb would show cheap and easy gains. One thing that would really be a nice change (but not cheap) would be a 904 transmission with a low gear set. The 4.10's with 29" tires will allow you to cruze on the highway comfortably but the low gear set will launch like you had 4:56's. In addition to significant gains from better 60' times, you will pick up a tenth or two just from the improved efficiency of the 904.
How the car runs will depend alot on the condition of the shortblock and heads. "Ported heads" can mean many things.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: What can I expect for E.T. [Re: Rapid340] #1111158
11/12/11 11:33 AM
11/12/11 11:33 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
carb will fall off at the 900 foot mark... AMHIK
Re: What can I expect for E.T. [Re: Mr.Yuck] #1111159
11/14/11 08:55 PM
11/14/11 08:55 PM
Western Colorado
3
340Scamp Offline OP
340Scamp  Offline OP
Western Colorado
I just bought a Quick flow 1050 carb. That should be plenty to feed it. I'm hoping for 11.90's or low 12's. Thanks everyone.
Re: What can I expect for E.T. [Re: 340Scamp] #1111160
11/14/11 09:02 PM
11/14/11 09:02 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Your kidding right??
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: What can I expect for E.T. [Re: 340Scamp] #1111161
11/14/11 09:02 PM
11/14/11 09:02 PM
Q
Quicktree Offline
Quicktree  Offline
Q
