Re: NEW BEST 9.85 137 mph
[Re: Ari440]
#1111028
11/17/11 08:29 PM
11/17/11 08:29 PM
Posts: 3,210 robin hood country
deaks
robin hood country
Dont TTI make a 2"-2-1/8 step header, or stahl headers are 2-1/8 as well. BTW Congrats on your time
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: moparniac]
#1111030
11/17/11 08:51 PM
11/17/11 08:51 PM
Posts: 6,295 U.S.
moparniac
U.S.
People always seem to say the full Hooker fenderwells make more power than the proparts... Who knows! I know our combos are similar and run the cnc345s . I saw you posted you went from single 4 to the tunnel ram!
Mopar Performance
[Re: moparniac]
#1111031
11/17/11 09:20 PM
11/17/11 09:20 PM
Posts: 5,618 long island NY
Ari440
long island NY
I had the cppa /tti headers very tigth fit and the hooker headers no room for tire and master cylinder ,just didmt like them , I even welded back the panels that I cut off
1050 had 98 jets went to a tunnelram two 750s 80 jets in them , timming at *38
the heddman headers look nice to try out or go custem
1.39 9.85 - 137 mph
[Re: moparniac]
#1111033
11/18/11 10:16 AM
11/18/11 10:16 AM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
ARI...I have to agree w/ sledgehammer about the timing. I'm assuming you have flattop pistons since your compression is around 12:1 w/ those heads and that many cubes. If so, then you ought to try backing the timing down to 36°, then try 34°. I bet it runs better w/ less timing.
[Re: an8sec70cuda]
#1111034
11/18/11 02:08 PM
11/18/11 02:08 PM
Posts: 6,295 U.S.
moparniac
U.S.
Chip I'm starting to get this SV1 tuned in better! I went 111 and change in the 1/8th and went from 28 to 32s on the highs and I went 112.8mph on back to back passes and nothing else changed... 60s were even 1.44 each... It was a hair over 1.5mph pickup! I have lots more tuning left but only other time out was the Jensen mean street deal.
Mopar Performance
[Re: moparniac]
#1111035
11/18/11 06:20 PM
11/18/11 06:20 PM
Ari440
long island NY
compresion is 13.1 flat top J/E pistons 7cc valve releafs and 71cc heads next time out I will have the 1050 with 95 jets and *35 timming need to stay out of the 9 sec zone or im going home again I will do some 1/8 mile testing or get my comp lesions (sp) thanks for the tips !
1.39 9.85 - 137 mph
[Re: Ari440]
#1111036
11/18/11 06:45 PM
11/18/11 06:45 PM
Posts: 20,630 in a cattle trailer down by th...
Guitar Jones
compresion is 13.1
Just go ahead and get you license and the full monkey suit. It really wasn't that hard. I went to a walk in clinic for the physical, $100. Made all the passes on a test and tune night.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Ari440]
#1111039
11/18/11 10:56 PM
11/18/11 10:56 PM
Guitar Jones
compresion is 13.1
is there a blindfold test to do too
just incase of an accedent (sp)
You know your car right. Could you hit the shut off without seeing it? You pass. Just line up a couple people you know that are licensed to sign your application before you do it. No sweat.
