Re: Drag racing ONLY....To run a thermostat or not? [Re: sshemi] #1110963
11/12/11 11:49 PM
11/12/11 11:49 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
The only reason to restrict flow is to make the engine run hotter, or to prevent pump pressure from blowing the cap open on a top tank radiator. You can not make the engine run cooler by restricting flow. That is an old wives tale that has been disproven by scientific testing. Higher flow = lower, more consistant temps in the heads, reduces steam pockets and reduces detonation. Proceed acordingly.
Is that really a fact?
I believe that if water flows slow through the rad it will be cooler entering the motor.
Btw i have always used a stat with a mech pump.
I even used a stat on my hemi with elec pump seemed to work but got too little run time to say for sure
Well, think of of this way: Would you slow down the flow of air thru the radiator so that it had more time to absorb heat? Of course not. It is the same thing.
Re: Drag racing ONLY....To run a thermostat or not? [Re: an8sec70cuda] #1110964
11/13/11 12:01 AM
11/13/11 12:01 AM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
If you have an electric water pump, don't run a thermostat or a restrictor.
please explain why not.
Doesnt an electric pump move more water than a mech at idle?
Im about to use both a stat and the heater.
You can leave the pump running and completely cool the motor down. If the thermostat closes, you can't circulate water.
Meziere says NOT to run a thermostat w/ any of their pumps.
They may say not to, but that doesn't mean it can't be done. Street driven with a Meziere for 6 years with a 160º stat with five 1/8" holes around the perimeter, never a problem. The holes make all the difference.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Drag racing ONLY....To run a thermostat or not? [Re: an8sec70cuda] #1110965
11/13/11 10:46 AM
11/13/11 10:46 AM
IN
Dartman928 Offline
Dartman928  Offline
IN
This how I run my car..street and strip for 6-7 year..no problems
Re: Drag racing ONLY....To run a thermostat or not? [Re: Dartman928] #1110966
11/14/11 12:34 AM
11/14/11 12:34 AM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
The formula for cooing is 1.1(?) x gpm x deltaT = cooling
The mre flow, the more cooling, The better rad, better cooling (delta T =temp difference between in and out)
