Help me I.D. my hemi 4-speeds #1110414
11/09/11 06:59 PM
11/09/11 06:59 PM
junction city oregon
V
viperblue72 Offline OP
V
I have 2 hemi 4 speeds. One is long tailshaft dual mount. On the I.d. pad is
OE 124742
Pp833 3022
And on the tranny is
C 99129 H
The other short one. On the I.d. pad is
8BI98222
PP833 2293 0021
And on the tranny
E 4
C 97622
I don't know much about these trannys. I want to rebuild them both and use one of them in my duster. One needs a cluster gear and I see brewer sells them.
Re: Help me I.D. my hemi 4-speeds [Re: viperblue72] #1110415
11/09/11 07:27 PM
11/09/11 07:27 PM
Retired now in Tennessee
Chi_Town_Runner Offline
0E124742
0=1970 model year
E= Vehicle assembly plant=Los Angeles
124742=LAst six digits of VIN
PP833=New Process Division A-833 4-speed trans
3022=date trans was built=Wed, 5 Nov 1969
8B198222
8=1968 model year
B=Hamtramck
198222=lastsix of VIN
2293=built on Tue, 7 Nov 1967
0021=21st trans built that day
FRank
Remember - 2 wrongs don't make a right - but 3 rights make a left!
Re: Help me I.D. my hemi 4-speeds [Re: Chi_Town_Runner] #1110416
11/09/11 07:30 PM
11/09/11 07:30 PM
V
V
Wow! Thank you . So I'm guessing the short one is E body and long one is B body?
Re: Help me I.D. my hemi 4-speeds [Re: viperblue72] #1110417
11/09/11 07:39 PM
11/09/11 07:39 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
The "0E" trans would be 1970 B or E body with 440 or 440+6. probably a Challenger R/T
*** That is ..... if it has always been a 18 spline transmission & long tailshaft.
The "8B" trans would be 1968 Charger R/T with 440 or HEMI if it has always been a 18 spline transmission.
*** But, with a short tailshaft ..... it would've been a 23-spline ..... too early for HEMI a-bodys.
Re: Help me I.D. my hemi 4-speeds [Re: 6bblgt] #1110418
11/09/11 07:51 PM
11/09/11 07:51 PM
V
V
My mistake! Both tailshafts are the same length. Just that was has a mount for linkage in 2 places.
Re: Help me I.D. my hemi 4-speeds [Re: viperblue72] #1110419
11/09/11 08:24 PM
11/09/11 08:24 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Then one is a B/E and the other is a B . , to will have to run a shorter driveshaft and make some type of adapter for the shifter to use it in your A body. But since you plan to rebuild it find a non OD A body 4 speed and swap on the tail and mainshaft.
Re: Help me I.D. my hemi 4-speeds [Re: viperblue72] #1110420
11/09/11 08:25 PM
11/09/11 08:25 PM
Just that one has a mount for linkage in 2 places
Probably the 1970 model trans.
Frank
Re: Help me I.D. my hemi 4-speeds [Re: Chi_Town_Runner] #1110421
11/09/11 10:44 PM
11/09/11 10:44 PM
V
V
Yes the 1970 has dual pads for the shifter and the crossmember mount is closer to the front. Being that I'm starting from scratch which tranny is better for an A-body? I'm not worried about driveshaft length. Just the shifter location and crossmember mount.
Re: Help me I.D. my hemi 4-speeds [Re: viperblue72] #1110422
11/09/11 10:53 PM
11/09/11 10:53 PM
V
V
So the mainshaft A body will work? I actually have a tailshaft only in the shed too. And I have a fully synchronized 3 speed but that's probably different?
Re: Help me I.D. my hemi 4-speeds [Re: viperblue72] #1110423
11/10/11 10:40 AM
11/10/11 10:40 AM
JohnRR Offline
JohnRR  Offline
I don't know which works better , put the A body tail up against the 2 other tails and see which one has the trans mount pad in the same location and that will also give you an idea of what you need to do to move the shifter into the correct location. But use the mainshaft from an A body NON OD 833 will work , I'm building an A body hemi 4speed using the Passon alum. case.
I really don't know but I will say no the 3 speed mainshaft is not the same.
Re: Help me I.D. my hemi 4-speeds [Re: JohnRR] #1110424
11/10/11 01:31 PM
11/10/11 01:31 PM
V
V
John rr,
Thanks I will do that today. I was just trying to avoid digging it out of the shed just yet as it is a mess.
