Re: Let Me Pass This By You Turbo Guys [Re: turbobitt] #1109894
11/11/11 12:35 AM
11/11/11 12:35 AM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
Guys,
Don't crucify me for posting this but this is a link to a friend of mine running a single 60-1 hybrid turbo. This is the same 3 bolt exhaust with the P-trim turbine.
http://www.turbobuick.com/forums/time-slip-combo-database/347741-10-61-127-85-60-1-compressor.html
Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: Let Me Pass This By You Turbo Guys [Re: turbobitt] #1109895
11/11/11 01:50 AM
11/11/11 01:50 AM
Borden, Indiana, U.S.A.
W
wrenchinrandy Offline
W
I believe it is those "other details" that are limiting my build more than the turbos themselves. With that said though, based on Furious 70's back pressure measurements, I may be in the upper third of what I can expect from those turbos. My approach thus far has been, if something happens to the motor (read blow it up), then I will address all the things that I suspect may be holding back. This was my first turbo project. I have learned a lot during the journey. Like any first effort, the knowledge gained will result in better future attempts.
Re: Let Me Pass This By You Turbo Guys [Re: wrenchinrandy] #1109896
11/11/11 09:34 AM
11/11/11 09:34 AM
IL
furious70 Offline
furious70  Offline
IL
A reliable, 700hp first project is a pretty good start
How much HP a turbo is capable of is only 1 aspect of sizing it. If we were to plot Randy's engine on a map it would probably push off the map to the right and low (as mine does). Most big blocks will push off both a compressor and turbine map hard to the right and low. That turbo might be capable of 600hp, but to do that it's expecting a 3:1 pressure ratio at 1/2 the lbs/min that Randy is pushing through it.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Let Me Pass This By You Turbo Guys [Re: turbobitt] #1109897
11/14/11 12:46 PM
11/14/11 12:46 PM
MR_P_BODY Offline OP
Furious70
I was looking at your build and it appears that your turbo is not a 60-1 compressor but maybe a 60 Trim wheel which is different. You Reference a turbocoupe turbo and would not have a 60mm wheel. I can see that this turbo is smaller than I thought.
Allan G.
Edit - I'm confusing Wrenchinandy set=up with Furious70, sorry.
This is the part that confuses me... when they say
60mm trim wheel VS a 60-1 ... isnt a 60-1 a 60mm
housing(inlet)... I need to get better familiarized
with the terminaligy
Re: Let Me Pass This By You Turbo Guys [Re: MR_P_BODY] #1109898
11/14/11 12:59 PM
11/14/11 12:59 PM
IL
furious70 Offline
furious70  Offline
IL
Yes, mine are not 60mm wheels, they are 60trim wheels. If you look at the common compressor map sites you'll see 50 and 60 trim wheels, super 60, and then 60-1 I think, all progressively larger.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Let Me Pass This By You Turbo Guys [Re: furious70] #1109899
11/14/11 01:44 PM
11/14/11 01:44 PM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
60 Trim and 60mm wheels do not mean the same thing. The trim is a ratio between inducer and exducer of the same wheel. Example,
Trim = (minor diameter / major diameter) ^2 * 100
Here is another example using real numbers. My turbine has an exducer of 89mm and the inducer is 96.5mm. This would make the trim 85. So, some may refer this to a 89mm 85 trim wheel.
The 60mm is uasually the measurement of the compressor inducer.
I did a quick search and found this link that has some definitions.
http://www.turbominivan.com/tech/turbo201.htm
Allan G.
Re: Let Me Pass This By You Turbo Guys [Re: turbobitt] #1109900
11/20/11 04:18 PM
11/20/11 04:18 PM
Grande Prairie, Alberta, Can.
CW25 Offline
CW25  Offline
On the comment that the turbos should make more HP because of the HP rating on the compresor map... Turbos Most often choke on the exhaust side no the compressor side. That combo may be done at 10 psi because of exhaust backpressure not compressor flow. There are 2 sides to a turbo and most only look at the compressor. I have a S400 T6 with a 75mm compressor and a 1.0 hsg 83mm/74mm exhaust wheel and it will only make 581 to the rear tires bacuse the exhaust side is so choked...
If it is to choked on the exhaust side then it can actually hurt spoolup. Uncorking the exhaust with a larger wheel can acutally spool faster than one with a choked small wheel. My truck will build 10 psi backpressure before it will even spool the turbo. Not reall good. When it does spool it will shoot straight to 35+ psi and pushes my peak HP down to 5000 RPM. It will pull clean to 6500 but not like it would with a better selection of exhaust wheel.
IMO if you put a T3 wheel on that 416 it would be a mistake
11.67@118 1.88 60' with only 7-8 lbs of boost. Turbocharged, megasquirted, 407 BB, 440 source heads, roller cam, 9:1 comp. http://s292.photobucket.com/albums/mm14/beansgracie
Re: Let Me Pass This By You Turbo Guys [Re: CW25] #1109901
11/23/11 08:15 PM
11/23/11 08:15 PM
I'm looking at a pair of t-61 t-4s with a comp wheel
.70 A/R and the turbine side of .68... I think these
will be over kill for what I want
Re: Let Me Pass This By You Turbo Guys [Re: MR_P_BODY] #1109902
11/23/11 10:21 PM
11/23/11 10:21 PM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
I'm by no means a "Twin" expert but you may want to consider more A/R on the exhaust side like .83.
FYI - The compressor A/R doesn't really matter and is usually not an option to change.
Allan G.
Re: Let Me Pass This By You Turbo Guys [Re: CW25] #1109903
11/23/11 10:48 PM
11/23/11 10:48 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Yep.
Re: Let Me Pass This By You Turbo Guys [Re: turbobitt] #1109904
11/24/11 12:03 AM
11/24/11 12:03 AM
Allan G.
Ok... from what I've read, MOST end up changing the
turbine side A/R anyways because you never seem to
get it right the first time BUT I will look for a
something closer to a .86... even reading in the book
Maximum Boost he doesnt really explain it very well
Re: Let Me Pass This By You Turbo Guys [Re: MR_P_BODY] #1109905
11/24/11 12:13 PM
11/24/11 12:13 PM
Where does the P trim fall in the lines of the A/R
ratio... is it in the .86 area? I see some with P,
Q and some other letters
Re: Let Me Pass This By You Turbo Guys [Re: MR_P_BODY] #1109906
11/24/11 12:34 PM
11/24/11 12:34 PM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
"P" and "Q" trim refers to the turbine wheels. The "P" trim is an old school wheel with the "Q" trim being a little bigger and newer.
The Housing A/R is independent of the turbine wheel. Both wheels can be had with a variety of A/R ratio housings. But, the housing would need to match the wheel size.
Allan G.
Re: Let Me Pass This By You Turbo Guys [Re: MR_P_BODY] #1109907
11/24/11 12:40 PM
11/24/11 12:40 PM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
Twin T-61 T-4's will support really good power. Don't know if you can get these in "Q" trim but may be better if you could get it that way.
The tangental exhaust housings flow better than the on center housings. Another thing to think about.
Allan G.
Re: Let Me Pass This By You Turbo Guys [Re: turbobitt] #1109908
11/25/11 01:06 PM
11/25/11 01:06 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Allan G.
P trim turbines are the most common of them all. Q trim wheels are a larger version of the p trims. The newest version is the gtq. Only available in large shaft dimensions though. In the attached pic you can see how much bigger the gtq wheel is compared to an old p trim. Even with its increased size, the turbos spooled faster with the increased shaft torque and free flow these turbine wheels impart. I used the same exhaust housing from the p trims,(turbonetics 1.30 a/r) I machined them to fit the larger gtq turbine wheels. If you start with a p trim housing, you can do some cool stuff with tuning the spool rate. The p trim housing has a narrower slot in it. If you leave it as narrow as possible, and still get the gtq to fit it spools VERY fast, but at a cost of max flow/power. I kept widening the slot to get my backpressure down. I actually ended up with a slot wider than the wheel tip height. Not something I would suggest to most users, but I thought I'd throw it out there.
As far as exhaust a/r housing decoding... The simplest explaination to what is going on here is this. A higher number will direct exhaust flow at the turbine wheel at an angle more directed at the center of the wheel (higher flow), where a lower number will direct exhaust flow more at the tips of the wheel (higher shaft torque, less flow).
As stated earlier, compressor a/r is a non issue, as most are matched with wheel size and have little effect on output.
Re: Let Me Pass This By You Turbo Guys [Re: TRENDZ] #1109909
11/25/11 01:17 PM
11/25/11 01:17 PM
Allan G.
Thanks guys... I'm STILL trying to figure out this
turbo stuff... I think most of my problem is the
terminology that is used by different companies and
people... I still need to figure out the hot side
and where to get the turbo's
