Re: Polishing Asen aluminum slot to a chrome shine??? [Re: Pacnorthcuda] #1109836
11/13/11 01:53 PM
11/13/11 01:53 PM
The clear will often reduce the mirror shine to some degree.
I would NOT clear them.
Oh OK no spray clear should be used. Got it Thanks Pac EDIT Didn't read the whole thread, that was my prob
Re: Polishing Asen aluminum slot to a chrome shine??? [Re: RapidRobert] #1109837
11/13/11 02:44 PM
11/13/11 02:44 PM
Downtown Roebuck Ont
Twostick Online content
Still wishing...
Twostick  Online Content
Still wishing...
Jeweler's Rouge with a buffing wheel is what you want to use. The red stuff will likely get you the results you want but if you really want to over do it you can follow it with green and finish with white.
You will need a buffer like this.
http://www.grainger.com/Grainger/DEWALT-Right-Angle-Polisher-4LD98?Pid=search
Iowa80 has kits and supplies
http://www.iowa80.com/DirectionsWEB/webcart_category3.php?catid=BUFFKITS
Kevin
Re: Polishing Asen aluminum slot to a chrome shine??? [Re: Twostick] #1109838
11/13/11 10:06 PM
11/13/11 10:06 PM
Mi.
G-Money1320 Offline
G-Money1320  Offline
Mi.
The best polish I have used is called Purple and you can get it at truck stops or some vendors have it at the bigger shows. I have used all kinds of polish including Mothers, Blue Magic,Wenol, Never Dull and the Purple has the best after shine to where it takes a whole lot more time to oxidize back up. Now mind you im talking on big rig fuel tanks that are subjected to all kinds of weather conditions and get dirtier faster than your wheels but you want a polish that not only cleans but stays that way longer. Use some kind of buffer wheel or ball and that should save some time as well as have more effect while polishing.
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out.
11.06 open headers----so far!!
Re: Polishing Asen aluminum slot to a chrome shine??? [Re: G-Money1320] #1109839
11/14/11 12:26 PM
11/14/11 12:26 PM
dogdays Offline
dogdays  Offline
Anyone ever try clear powder coat?
R.
Re: Polishing Asen aluminum slot to a chrome shine??? [Re: Twostick] #1109840
11/14/11 12:36 PM
11/14/11 12:36 PM
scratchnfotraction Offline
Kevin
had my weld done at the I-75 chrome shop,this is what they used,12 yr old untouched welds looked like the new 12s i put on the back2 days before the fronts got polished.
Re: Polishing Asen aluminum slot to a chrome shine??? [Re: dogdays] #1109841
11/14/11 12:38 PM
11/14/11 12:38 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
any type of coating will dull it some and heat will make it yellow over time also you will throw them away before you ever get the powder coat off if need be
try some gibbs oil on them to keep them from oxidizing i use it on my mag. polished parts them things will corrode over night lol
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: Polishing Asen aluminum slot to a chrome shine??? [Re: Pacnorthcuda] #1109842
11/14/11 02:15 PM
11/14/11 02:15 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
OK mothers only & what about clearing (cleaning) the rim?
Clearing the polished rims?
Pros: The clear protects your polish work from oxidizing
Cons: The clear is subject to damage. Easy to crack/peel from a polished surface.
I would NOT clear them. I have uncoated aluminum wheels on both my daily driver and 'Cuda and they are just fine.
If you wish to "clear coat" the rims, 2 choices IMHO, powdercoat in clear, or yes POR-15 makes a product for polished/chromed finishes called "Glisten PC" if I recall the name correctly, stuff drys rock hard and stays clear, I did a few motorcycle parts with it.....no issues, as long as you remove all traces of wax/polish and FINGERPRINTS before coating
Re: Polishing Asen aluminum slot to a chrome shine??? [Re: JAMESDART] #1109843
11/14/11 11:58 PM
11/14/11 11:58 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
to get the best possible shine from aluminum you have to sand all imperfections out of them, right down to the very fine machined finish, any pits, scratches... treat them like paint, start with a coarse paper to know everything down and go finer in steps to the point you can polish them,there are so many different way to polish once you get to this point. that is the only way you will get a real reflection out of them. if you polish the surface you have now, they will improve, but you can still get them better.
This is the true answer. You need to sand out the scratches and pits. I've restored many vintage wheels. Due to casting quality they may have pits even after sanding. Some wheels will look better do to casting quality. Newer wheels are better quality and generally look better. This is not to say older ones won't look nice. Start as fine as possible. If 400 grit doesn't get it, go coarser. You don't need to sand coarser everywhere, only the bad spots. I go to 80 grit if necessary. Finish aluminum with 1000 grit then a wool pad. Stainless can be repaired the same way. Just finish with 2000 grit. I'm doing a set of American 200S right now. Here's a pic of the results in stainless.
Doug
Re: Polishing Asen aluminum slot to a chrome shine??? [Re: TX9H6E4CUDA] #2358983
08/24/17 05:01 AM
08/24/17 05:01 AM
Alaska
Johnsnow Kornar Offline
Alaska
Might anyone be able to give me some contribution on what they utilized and additionally did to clean aluminum to a mirror wrap up? It was cash well spent. This stuff is truly astounding with regards to cleaning aluminum. Visit my webpage for details
http://automobiledecor.com/best-aluminum-polish-reviews/
Re: Polishing Asen aluminum slot to a chrome shine??? [Re: TX9H6E4CUDA] #2359014
08/24/17 09:43 AM
08/24/17 09:43 AM
crlush Offline
crlush  Offline
Another recomendation for Autosol
Re: Polishing Asen aluminum slot to a chrome shine??? [Re: crlush] #2359214
08/24/17 04:44 PM
08/24/17 04:44 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
By the time you buy all of the items to do a really nice job, you can probably pay a pro to do it for you.. NOT some high priced shop, but a polish guy that works out of his home..
You can start with the cotton wadding cleaner, Neverdull.. If its not cleaning them, go to sand paper or steel wool with an aluminum cleaner type of polish..
Finish with a mothers or autosol type of polish...
There were two types of finish's offered on Ansen type slot wheels in the day, polished and a "turned" finish... I am sure you can polish out the "turned" finish if you want to...
Personally I would never clear coat em..
I did see a few years ago some sort of sealer ( Zoop) you apply to aluminum after you are done polishing them.. It claimed to "seal" the aluminum pores so the shine would last longer... Never have used it...
I had the wheels polished by a pro ( truck in pic) in the early 90's.. They were really sad before I had them polished and looked unbelievable when done... NEVER had to redo them in the 10 years I had that stepside truck...
First two pics are before, second two are after...
