Page 1 of 3 1 2 3
BOTTOM-END GIRDLE KIT??? #1109418
11/08/11 05:13 PM
11/08/11 05:13 PM
Clinton Twp... north of Deetro...
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Can someone refresh my memory,and tell me who sells the bottom-end girdle kit? Also...can I get some input..good..or bad on it? I'm thinking of buying one in the future. Thanks in advance! Randy B.
Re: BOTTOM-END GIRDLE KIT??? [Re: Labratt] #1109419
11/08/11 05:42 PM
11/08/11 05:42 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
the one I am using is from CRE...the engine is a 499 and was just broke in with 3 runs...havent run the engine in years but will be going into my 63 Dodge project to see some street duty...
the other one is BCR...thats the best one going...he said he's looking for another machine shop to produce these...
Re: BOTTOM-END GIRDLE KIT??? [Re: smokinwoody] #1109420
11/08/11 06:05 PM
11/08/11 06:05 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
I think you do have to go to main studs which means you have to have it line bored on the mains.
67' charger 499 RB 10.57 at 127
Re: BOTTOM-END GIRDLE KIT??? [Re: dragram440] #1109421
11/08/11 07:55 PM
11/08/11 07:55 PM
organ
maximum entropy Offline
organ
imo, any girdle is a good idea on any bb mopar. i've installed a bunch of 'em from various suppliers- chenoweth, source, mancini, bcr. i prefer the drop in units. the bcr was a lot of work, as the machine shops in my area were unable to handle the machine work necessary. it is a very nice piece, but overkill in my estimation.
Re: BOTTOM-END GIRDLE KIT??? [Re: maximum entropy] #1109422
11/08/11 08:31 PM
11/08/11 08:31 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i use the one from mike at chenoweth,bolts right in
Re: BOTTOM-END GIRDLE KIT??? [Re: bonefish] #1109423
11/08/11 08:47 PM
11/08/11 08:47 PM
farmingdale ny 11735
blracing Offline
blracing  Offline
the one i found is from chenoweth girdles. the phone # is 626-869-0270. it was on racing junk awhile back. i hope this helps!sorry i don't have anymore info! the price was 425.00.
Re: BOTTOM-END GIRDLE KIT??? [Re: blracing] #1109424
11/08/11 08:51 PM
11/08/11 08:51 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
thats CRE....yeah the studs and all the fastners come with it...be kinda expensive just for a metal plate...
Re: BOTTOM-END GIRDLE KIT??? [Re: smokinwoody] #1109425
11/08/11 10:30 PM
11/08/11 10:30 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
How much clearance between the oil pan and center drag link with the girdle installed?
Re: BOTTOM-END GIRDLE KIT??? [Re: nss guy] #1109426
11/08/11 10:38 PM
11/08/11 10:38 PM
Shannonville, Ont
Blown 68 R/T Offline
Shannonville, Ont
Randy,
I have the BCR kit, alum caps & girdle.Nice peice,hopefully Greg chimes in for ya.
Re: BOTTOM-END GIRDLE KIT??? [Re: Blown 68 R/T] #1109427
11/08/11 11:13 PM
11/08/11 11:13 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
if you are going to use a girdle, the only one worth buying is the bcr piece in my opinion.
It is more machine work, but when its all said and done, you look at it and say with out question that it will help.
I run one on my motor labratt....remember, stock block and 1300hp
It also comes with the aluminum main caps, the girdle ties the pan rail to the main caps (all of them) and is a top notch piece.
I actually tried to purchase the BCR product line from Greg, I was such a firm believer in it.
Becareful of the type that use washers and spacers to make up the difference between the mains and the pan rail as those really dont do what you are looking to accomplish
Re: BOTTOM-END GIRDLE KIT??? [Re: nss guy] #1109428
11/08/11 11:15 PM
11/08/11 11:15 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
it moves the pan down .550 if i remember correctly
Re: BOTTOM-END GIRDLE KIT??? [Re: joshking440] #1109429
11/09/11 01:27 AM
11/09/11 01:27 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thank you for ALL the info,gentleman..and Josh! I'll check into these! A few people have suggested that at my power level,I REALLY don't need one. I have to do some research on this! Thanks again JOSH...Kevin..and my Moparts brethren!
Re: BOTTOM-END GIRDLE KIT??? [Re: Labratt] #1109430
11/09/11 02:41 AM
11/09/11 02:41 AM
Alberta Canada
StrokerAspen Offline
Alberta Canada
Hey Randy.... When I am not making decals..... I am making engine girdles. want me to get a BB dodge girdle together to send down with the decals I am doing for you?
-Kenny
Re: BOTTOM-END GIRDLE KIT??? [Re: StrokerAspen] #1109431
11/09/11 02:44 AM
11/09/11 02:44 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Howdy,Kenny! Please send me a PM with all the details! Thanks,Buddy! Randy
Re: BOTTOM-END GIRDLE KIT??? [Re: Labratt] #1109432
11/09/11 05:02 AM
11/09/11 05:02 AM
Wichita Kansas
CH3NO2 Offline
CH3NO2  Offline
Wichita Kansas
I am not endorsing any product, but look at the BRC kit. Since I balance jet engines, anything that can absorb the shock and can contain harmonics-keyword- is the best thing you can do to save a factory block. Not everybody can pony up for a aftermarket block. Just do some research, then decide for yourself. Steve DeTar
Engine by DeTar http://www.kansasbadman.com
Re: BOTTOM-END GIRDLE KIT??? [Re: joshking440] #1109433
11/09/11 05:24 AM
11/09/11 05:24 AM
Mooresburg, Tn
'72CudaRacer Online content
'72CudaRacer  Online Content
Mooresburg, Tn
Josh, what does the BRC one do that the others don't. I got one from Hughes on mine and it uses spacers and shims between the plate and the main studs.
Thanks,
Brian Dunnigan
Re: BOTTOM-END GIRDLE KIT??? [Re: '72CudaRacer] #1109434
11/09/11 09:56 AM
11/09/11 09:56 AM
Florida-West Coast
Thor500 Offline
Thor500  Offline
Florida-West Coast
My engine builder was impressed with the one I got from Hughes, and he's even a chevy guy!
Re: BOTTOM-END GIRDLE KIT??? [Re: Thor500] #1109435
11/09/11 10:06 AM
11/09/11 10:06 AM
Delray beach, Florida
P
Performance Only Offline
P
really?
machine shop owner and engine builder
Re: BOTTOM-END GIRDLE KIT??? [Re: Performance Only] #1109436
11/09/11 11:26 AM
11/09/11 11:26 AM
bcrproducts Offline
super gas
bcrproducts  Offline
super gas
Hi Guys
I am in the works again to handing the product line to another well respected Moparts machinist. The first time did not work out and that was a major setback. CRE is no longer in business I guess the times have been hard on Mike and Dale. There website went down a while back and have not heard a thing from them in months. So the only option for a true bolt in Girdle kit that will truly do what is is supposed to is the one Tom myself Dan and a few others designed here a few years ago and that is the BCRproducts one. Being in Canada was just too much work shipping to the US and sourcing all the components neede to build this setup. I promise this time it will happen and the guy who is taking BCRproducts over has a great reputation and has build some very custom parts for all of us who love BB Mopars. That is is about all I can do to hint who as it is not my place yet to disclose the new manufacturer. I will do all the preinspects to ensure quality control so it will happen and the pieces will be of the same quality as before.
Greg
Re: BOTTOM-END GIRDLE KIT??? [Re: Labratt] #1109437
11/09/11 12:02 PM
11/09/11 12:02 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
... A few people have suggested that at my power level,I REALLY don't need one...
You're pretty close to the power level where I was seeing clear evidence of cap walking w/ only OEM caps and studs. Do you absolutely have to have something beyond that? No. Would it be a good idea to add some insurance? IMO, yes.
The CRE kit is nice (I have one that I haven't actually used, yet), but their competitors came out later w/ comparable products for less money. Hughes or whomever can provide you w/ a viable option, since IMO (again) the BCR approach ( ) is overkill for your application. As pointed out by others, if you don't have main studs installed in your current build, they do say you'll need to align hone everything w/ the new studs to ensure cap location.
Page 1 of 3 1 2 3
