Machined out 2, 1" steel plates the same diameter as the carrier bearings and 2, 1" steel plates the same diameter as the axle bearings. Drilled them out to 1-1/4". Used a piece of 1-1/4" steel shafting to slip through them and line everything up. Dave
thanks
theres nothing as permanent as a temporary fix 70 super bee 79 red express 67 fargo 8o aspen rt
