help with a suggestion for a cam choice 426 Hemi #1108947
11/07/11 08:30 PM
11/07/11 08:30 PM
At a gas station near you
badblack68 Offline OP
I`m looking for suggestion for a cam choice in my 426 Hemi. The engine is going into a 67 GTX with a 727 auto, dana 60 with 3:54 gears. The rear tire is 28" in diameter. I want a cam with a little more than what the engine came with in stock form. The engine has a measured 10.25:1 compression ratio. I want suggestions for a good hydraulic cam.
Thanks!
Nobody gets in to see the wizard!
Ain`t no way!
Ain`t no how!
Re: help with a suggestion for a cam choice 426 Hemi [Re: badblack68] #1108948
11/07/11 09:32 PM
11/07/11 09:32 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Well it cam stock with a 484 cam, but I would suggest a mild solid cam. Same cost, more performance, and less issues. We have been running a cam in the .575" range with mild duration, and gone as fast as 11.1 with it in a street car. the .484 has about 244* duration at 50 and we kept ours similar at 248*/252*, but with just awesome performance...
http://www.hughesengines.com/Index/produ...mp;partid=21819
