Dumb@ss SS Hemi crank questions 8^P #1108900
11/07/11 07:46 PM
11/07/11 07:46 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
I've been meaning to ask these for awhile just out of curiosity.
What type of crankshafts are used in modern SS/AH engines (e.g. billet vs. forged, preferred brands)?
Are they allowed to run reduced rod journal diameters as long as stroke checks w/in NHRA spec, or do they have to stick w/ the OEM 2.375" journal?
What sort of bob weight does an SS/AH engine have?
How many RPM do they turn?
What's the life expectancy of one of these cranks (assuming measured in # of runs)?
Re: Dumb@ss SS Hemi crank questions 8^P [Re: BradH] #1108901
11/07/11 07:55 PM
11/07/11 07:55 PM
detroit area
moderncylinder Offline
detroit area
forged by rules,, must have a forging line on one of the rod throws remaining
any size journals
2200 is a good bobweight
charlie runs almost 10,000 barton about 9500 others 9000-9200 valvetrain is the problem,, not cranks to run the engine higher
run them till you make a mistake and blow it up,, other than that they probably will crack on their own after 400-500 runs,, who knows
Re: Dumb@ss SS Hemi crank questions 8^P [Re: moderncylinder] #1108902
11/07/11 09:17 PM
11/07/11 09:17 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
Jeff, does anyone run the Honda rod journal size (1.888")? Carrillo has legal rods listed for that size, so I figured someone has at least tried them. Brave souls they must be.
Floyd Lippencott IV
Re: Dumb@ss SS Hemi crank questions 8^P [Re: mr_340] #1108903
11/07/11 09:30 PM
11/07/11 09:30 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
I think a legal S/S HEMI rod has to weigh 850 gms.
Re: Dumb@ss SS Hemi crank questions 8^P [Re: S/ST 3040] #1108904
11/07/11 09:55 PM
11/07/11 09:55 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
CARRILLO B.E. 2.496 S.E. 0.991 Length 6.879 Wgt 833* CR-426SS 426 Hemi
* = SUPER STOCK ONLY
Floyd Lippencott IV
Re: Dumb@ss SS Hemi crank questions 8^P [Re: mr_340] #1108905
11/07/11 10:25 PM
11/07/11 10:25 PM
Sterling Heights, MI
MCHBOB Offline
MCHBOB  Offline
Just about everyone runs the honda journal
Re: Dumb@ss SS Hemi crank questions 8^P [Re: MCHBOB] #1108906
11/08/11 12:25 AM
11/08/11 12:25 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Great article about Barton's motor in the Feb. 2011 MoPar Action.
A standard M.P. crank sent to Sonny Bryant for " massaging "
830 gram ( mandated weight ) Carillo H beams for a 1.88 crank pin ( Honda ) and 800.00 a set F-1 quality bolts.
a " dead stock " standard volume pump , fixed rear pick up and shallow Moroso pan.
What they do that is amazing is with lifter bore spacing.
narrower center 3 cam bearings and re-located bores that yield a very straight push rod angle.
9/16ths X .220 wall pushrods and 1,300 lbs. open valve springs.
I don't know how much of the article is gospel , but there were some surprises for me.
Re: Dumb@ss SS Hemi crank questions 8^P [Re: tubtar] #1108907
11/08/11 12:56 AM
11/08/11 12:56 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
NOT to sound sarcastic......but i would believe NOTHING of any article, in any magazine...These guys are not telling anthing ..LOL
What is in the article is "old" info im sure
....BAD A$$ STREET CAR.....
Re: Dumb@ss SS Hemi crank questions 8^P [Re: tubtar] #1108908
11/08/11 12:56 AM
11/08/11 12:56 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
today's rules have allowed the SS Hemi to stray so far from basics it should be in comp eliminator
I have lost all interest in them
home of the
Sox and Martin Hemi Duster
Re: Dumb@ss SS Hemi crank questions 8^P [Re: n20mstr] #1108909
11/08/11 01:14 AM
11/08/11 01:14 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I get skeptical too.
But pictures of the re-located lifter bores and narrow cam bearings , with button head screws to retain them in the block are pretty far removed from any build I am contemplating.
They did not give cam specs or show pictures of inside the ports......this didn't surprise of disappoint me.
The point of the article was how they manage to spin the motors to 9,800 r.p.m. , and it did answer questions.
I don't expect trade secrets , but I do know cool when I see it.
I thought this was pretty cool.
Re: Dumb@ss SS Hemi crank questions 8^P [Re: tubtar] #1108910
11/08/11 12:02 PM
11/08/11 12:02 PM
detroit area
detroit area
i think ray was pretty honest in that article,, i think that since that they have backed down on engine speed but will have it back up over this winter due to their addition of a spintron in their shop.
the spread lifter thing was really done by charlie first i believe,, ray spread them some awhile ago and charlie took it further,, then further again.. it does help,, but the rocker system is where the higher engine speed comes from
and a motor with std rods in it past 9200 or so it a time bomb waiting to come apart,, there is alot of housing bore distortion and bearing pinching at the parting line,, so you need to run alot of clearance.. with the honda stuff you could run that stuff to 10,000 and not worry about it
Re: Dumb@ss SS Hemi crank questions 8^P [Re: n20mstr] #1108911
11/08/11 06:02 PM
11/08/11 06:02 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
They aren't going to give too much away with some photos, the average guy isn't going to pick up any top secret stuff. It was a good article, but these engines have certainly changed since the MP SS/AH book was released. I was shocked when I saw how many changes the rules allowed back then (I can remember when no material could be added to the ports). It would be interesting to see how Jeff's SS/AH heads look now as to when that book was produced.
Alan Jones
Re: Dumb@ss SS Hemi crank questions 8^P [Re: tubtar] #1108912
11/09/11 10:24 AM
11/09/11 10:24 AM
the frozen wastes...
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
Did i just read that right...??? $800 for 16 rod bolts...??? What do the rods cost...???
Re: Dumb@ss SS Hemi crank questions 8^P [Re: Pale_Roader] #1108913
11/09/11 11:53 AM
11/09/11 11:53 AM
Kansas City Metro
mbogina Offline
mbogina  Offline
Kansas City Metro
The Carillo 1.88 Rods w the good bolts are right around 3K for a set.
Be a Rebel- Break the Laws of Physics!
Re: Dumb@ss SS Hemi crank questions 8^P [Re: mbogina] #1108914
11/09/11 02:47 PM
11/09/11 02:47 PM
detroit area
detroit area
i used crower and they were 250 each rod with the best a-1 bolts you could get,, but its not needed anymore really,,, a good bolt is fine with trhe honda stuff,, you dont need killer bolts like with the std housing rods
and my heads?? well im not the man for that currently,, not many are selling packages like that very often,, maybe charlie and barton sell a few here and there,,, im doing a new head now and trying to get it to do something i think is important,, and its a pain in the a-- we will see if i can get my act together for next year and test and come out with something really good
Re: Dumb@ss SS Hemi crank questions 8^P [Re: moderncylinder] #1108915
11/09/11 06:31 PM
11/09/11 06:31 PM
LA360 Offline
LA360  Offline
When did the rules change allowing different rods journal sizes, material being added to the cylinder heads etc? The intakes are basically a tunnel ram nowadays (what is the minimum the carbs are offset? 1/4"??), I can see what many liken these engines more so to a comp eliminator engine. But the same can be said for alot of the other SS classes anyway.
Alan Jones
Re: Dumb@ss SS Hemi crank questions 8^P [Re: LA360] #1108916
11/09/11 07:01 PM
11/09/11 07:01 PM
detroit area
detroit area
i think the rule for the cylinder heads that you could add epoxy or weld in the ports was in 1988 maybe,, or a few years before
rod journals could be changed maybe in 2007, but housing bore of rod had to be stock,, then in 2009 any housing bore was allowed
the primary throttle shafts can line up with secondaries going outward
Re: Dumb@ss SS Hemi crank questions 8^P [Re: moderncylinder] #1108917
11/09/11 11:00 PM
11/09/11 11:00 PM
LA360 Offline
LA360  Offline
Jeff, you have an email!
Alan Jones
Re: Dumb@ss SS Hemi crank questions 8^P [Re: LA360] #1108918
11/10/11 01:54 AM
11/10/11 01:54 AM
DFW
mr_340 Offline
mr_340  Offline
DFW
Here is the NHRA layout of the crossram carbs.
Floyd Lippencott IV
Re: Dumb@ss SS Hemi crank questions 8^P [Re: HEMIFRED] #1108919
11/11/11 12:47 AM
11/11/11 12:47 AM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
What's that drivel have to do with SS Hemi crankshafts? Go start a thread about ruining a classic pro stock with a fat lazy motor and a 2 speed slushbox.
On the SS Hemi crank deal, I think you guys need to shrink the mains if you have'nt gone that way yet.
