Need pics of Caltracs in A-bodies #1106193
11/02/11 08:07 PM
11/02/11 08:07 PM
Elbridge, NY
Dart1031 Offline OP
Dart1031  Offline OP
Elbridge, NY
Does anyone have a pic of the front spring hanger in an A-body with Caltracs installed? My Dart has the springs moved inboard of the frame. The chassis shop made the spring hangers and I'm wondering if it will work the way it is, or if I have to change it. And FWIW, I bought the car this way!
Re: Need pics of Caltracs in A-bodies [Re: Dart1031] #1106194
11/02/11 08:43 PM
11/02/11 08:43 PM
Greenville, South Carolina
BBLM23 Offline
BBLM23  Offline
I read on here that Caltrac has a set-up for the relocated springs without the bolt. I didn't have that set-up...
Walter
1969 Dart Swinger w/ARC Pump Gas 493 B1/BS 10.18 at 130mph
Racing Pro in street trim.
1981 Aries ARC 548 B1 8.88 at 147mph (footbraking)
1996 Ram 2500 V10 16.52 at 80mph
1981 Reliant 400
Re: Need pics of Caltracs in A-bodies [Re: BBLM23] #1106195
11/03/11 12:09 AM
11/03/11 12:09 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
....BAD A$$ STREET CAR.....
Re: Need pics of Caltracs in A-bodies [Re: n20mstr] #1106196
11/03/11 12:12 AM
11/03/11 12:12 AM
N
n20mstr Offline
n20mstr  Offline
N
Re: Need pics of Caltracs in A-bodies [Re: n20mstr] #1106197
11/03/11 12:14 AM
11/03/11 12:14 AM
N
n20mstr Offline
n20mstr  Offline
N
Re: Need pics of Caltracs in A-bodies [Re: Dart1031] #1106198
11/03/11 08:33 AM
11/03/11 08:33 AM
Elbridge, NY
Dart1031 Offline OP
Dart1031  Offline OP
Elbridge, NY
Thanks for the pics guys And thanks for the heads up, Walter. I didn't realize there were two styles. Then again Tony's pics show me what I need, lol.
Re: Need pics of Caltracs in A-bodies [Re: Dart1031] #1106199
11/03/11 11:41 AM
11/03/11 11:41 AM
Tennessee
727builder Offline
727builder  Offline
Tennessee
I put them inside the frame rails
Re: Need pics of Caltracs in A-bodies [Re: 727builder] #1106200
11/03/11 01:51 PM
11/03/11 01:51 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Relocation box cantilever.
Re: Need pics of Caltracs in A-bodies [Re: 727builder] #1106201
11/03/11 08:21 PM
11/03/11 08:21 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Do you have a pic of how you did the rear hanger?
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Need pics of Caltracs in A-bodies [Re: 1967dartgt] #1106202
11/03/11 09:30 PM
11/03/11 09:30 PM
Tennessee
727builder Offline
727builder  Offline
Tennessee
Don't have one on my pc. On A-bodys I cut out the spare tire well and weld in metal to make the truck floor flat. Then i run 2x3 box tubing from frame to frame in line where the factory rear hangers were bolted in. I weld factory A-body hangers to the 2x3 box tubing making sure the leaf springs are straight from front to rear. There's just enough room to put the rear bushing back in. And i bolt the shackles back by pushing them back in toward factory frame rail. Works out good. I have a 66 coronet on the lift now. Did it different. Will take a pic and post it tomorrow when i get in. Will see if i can get a pic this weekend at the track of a-body car i did?
I also cut and re-weld the frame rails to narrow them up to match the width at the rear of the factory tubs. I dont like that they get wider as they go forward. It gets about an extra inch for tire clearance by doing it. A-bodys end up having about 16.5' for tires. 13x31's phoenix slicks fit easy. They are about 15" of section on 12" wheels. This pic show the bottom side of the frame rail after i cut it before i clamped it back together for welding. Make the bottom of the frame rail about 1/2 inch narrower than stock. After it welded i cut the top of the frame rail I move them in about 1" before welding.
Re: Need pics of Caltracs in A-bodies [Re: 727builder] #1106203
11/03/11 09:34 PM
11/03/11 09:34 PM
Tennessee
727builder Offline
727builder  Offline
Tennessee
After the bottom is welded this is How far i move the top of the frame in before i weld it.
Re: Need pics of Caltracs in A-bodies [Re: 727builder] #1106204
11/03/11 10:17 PM
11/03/11 10:17 PM
Elbridge, NY
Dart1031 Offline OP
Dart1031  Offline OP
Elbridge, NY
That's how my car is. The springs are inboard of the frame, not inside. This is on the blue Dart you used to own, that Robbins had for a while.
Re: Need pics of Caltracs in A-bodies [Re: Dart1031] #1106205
11/03/11 10:33 PM
11/03/11 10:33 PM
Tennessee
727builder Offline
727builder  Offline
Tennessee
I forgot who got that dart. You do know the welding is not guaranteed? Think i did 2x3 frame connectors welded in it too? Been racing it any???
Re: Need pics of Caltracs in A-bodies [Re: 727builder] #1106206
11/03/11 10:40 PM
11/03/11 10:40 PM
Elbridge, NY
Dart1031 Offline OP
Dart1031  Offline OP
Elbridge, NY
It was certed to 8.50, so it can't be all that bad No racing yet. Hoping for next year
Re: Need pics of Caltracs in A-bodies [Re: Dart1031] #1106207
11/03/11 11:09 PM
11/03/11 11:09 PM
Tennessee
727builder Offline
727builder  Offline
Tennessee
I didnt own that car. Just did the frame connectors and think I moved in the springs??? Chris Buffington own it and painted it. I bought all of the 360/904 stuff after they blew some head gaskets by spraying it. he was going to put a BB in it. Think his funds dried up? That's when he sold it to Robbins? Rebuilt the 360/904 and put it in this dart i was building.
Re: Need pics of Caltracs in A-bodies [Re: 1967dartgt] #1106208
11/03/11 11:30 PM
11/03/11 11:30 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Ditto! I would really like to see a pic of that...
Re: Need pics of Caltracs in A-bodies [Re: cudadoug] #1106209
11/05/11 10:31 AM
11/05/11 10:31 AM
Tennessee
727builder Offline
727builder  Offline
Tennessee
Should have a pic from an a-body by tonight. This is from a 66 coronet i did about 7 years ago.
Re: Need pics of Caltracs in A-bodies [Re: 727builder] #1106210
11/05/11 10:41 AM
11/05/11 10:41 AM
Tennessee
727builder Offline
727builder  Offline
Tennessee
Coronet pic
Re: Need pics of Caltracs in A-bodies [Re: cudadoug] #1106211
11/05/11 11:46 PM
11/05/11 11:46 PM
Tennessee
727builder Offline
727builder  Offline
Tennessee
Here's how i do an A-body rear shackle. Weld in 2x3 box tubing from side to side. Weld the factory hanger to it. Also weld the new floor pan to 2x3 tubing.
Re: Need pics of Caltracs in A-bodies [Re: 727builder] #1106212
11/06/11 04:20 PM
11/06/11 04:20 PM
maryland
buck440 Offline
buck440  Offline
maryland
here's mine with the mancini roller kit
