1999 360 magnum compression ratio? #1105327
11/01/11 06:29 PM
11/01/11 06:29 PM
Indiana, United Staes, Vevay
LikarockCrusher Offline OP
Anyone give me the copression ratio for a 1999 360?
Re: 1999 360 magnum compression ratio? [Re: LikarockCrusher] #1105328
11/01/11 07:59 PM
11/01/11 07:59 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
About 8.75 to 9.0
Re: 1999 360 magnum compression ratio? [Re: HotRodDave] #1105329
11/01/11 11:32 PM
11/01/11 11:32 PM
thanks!
Re: 1999 360 magnum compression ratio? [Re: HotRodDave] #1105330
11/03/11 12:51 PM
11/03/11 12:51 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
About 8.75 to 9.0
Oh well, should be able to chuck a turbo or two on mine without changing a thing.
Mo' Farts
Moderated by "tbagger".
Re: 1999 360 magnum compression ratio? [Re: Grizzly] #1105331
11/03/11 01:50 PM
11/03/11 01:50 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
IIRC "blueprint" is 9:1...if you actually do the math (~63cc chamber, ~10cc dish on piston .060-.070 in the hole, .040-.050 head gasket), real-world compression is more like 8.25-8.75....
2017 Grand Cherokee Overland
Re: 1999 360 magnum compression ratio? [Re: patrick] #1105332
11/03/11 08:04 PM
11/03/11 08:04 PM
chatham, Ilinois
fox Offline
super street
fox  Offline
super street
chatham, Ilinois
I think it is advertised at 8.9 to 1 but Patrick has it right.Actually measuring it you are lucky to have 8.25.
The 360 response very well to a jump in compression. Up to maybe 9.25 and it should be fine, depending on cam and octane etc.
Re: 1999 360 magnum compression ratio? [Re: fox] #1105333
11/03/11 08:55 PM
11/03/11 08:55 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
My 95 responded VERY well with stock pistons, so well it pulled off 12.5s @ 105 in my dart with bolt-ons & 87 octane, so if jumping the compression a solid point really wakes them up, that would be sweet.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: 1999 360 magnum compression ratio? [Re: LikarockCrusher] #1105334
11/06/11 10:42 AM
11/06/11 10:42 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
It is my belief that the 1993-1995 Magnum 5.9 V8 pistons had 11 cc 'soapdishes'
Willem Weertman's memoir on his time as the chief engineer at Chrysler engines
http://www.allpar.com/reviews/other/engines.html
says that these same hyper-eutectic aluminum cast pistons were used in the 1994-1995 iron V10 Ram pickup engines as well.
But somewhere in the 1996-1998 time frame I think the 5.9L V8 piston soapdish was enlarged to 13 to 14 cc
When this change was made Chrysler started calling the official compression ratio 8.9
whereas the early FSM manuals list the 5.9L as 9.1 just like the 5.2L engine.
As others have posted above
the deck height clearance
varies a lot
and will determine what real world static compression ratio will be for any given engine.
There seems to be a hint
that the deck clearance runs tighter on the rear most cylinders.
Larry Shepard wrote that the
Magnum combustion chamber was 'about 60 cc'
but most of the reports of actual measurements by owners are 62 cc to 65 cc.
Once again, there seems to be a trend that the factory machining leaves the rearmost chambers of the cylinder head slightly smaller.
We know that the early 1992-1993 5.2L engines had a larger exhaust manifold and exhaust pipe back to the catalytic converter,
then in 1994 this was surprisingly made smaller and more restrictive.
The only plausible answer I have read for this change was that the exhaust gas temperature was "too cool" for the catalytic converter to reduce the NOx pollution,
and so Chrysler had to find a way to raise the exhaust gas temperature, even if it meant worse horsepower and fuel economy.
Lower static compression ratio also raises exhaust gas temperature,
so it is possible that Chrysler fiddled with the compression ratio in a year that they were having problems pass the EPA test for NOx,
or maybe the CARB test instead.
