More progress and another new best! #1105179
11/01/11 02:53 PM
11/01/11 02:53 PM
Redding,CA USA
440charger500 Offline OP
Redding,CA USA
Got the charger all shined up and ready for the races. So Dad and I set the timing @ 39 and I jetted the 750's from 78 sqare to 80 sq. The 440 really liked it, ran my new best to date 12.20 @ 109 with a 1.67 sixty. I still think I'm just a bit lean but I will have to wait till next season to jet up some more and find out. Its going to be a long winter wait to find out.
Re: More progress and another new best! [Re: 440charger500] #1105180
11/01/11 03:06 PM
11/01/11 03:06 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
good, now get a hood on that thing!
You might need to work on your 60 foot. I'd think if you got it down to 1.60-62 you'd be well into the 11's.
Coming soon!!!!
Re: More progress and another new best! [Re: 440charger500] #1105181
11/01/11 03:06 PM
11/01/11 03:06 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Way to go. How about some more pics of that sweet Charger ? Congrats on the new best. Ron
Re: More progress and another new best! [Re: Mr.Yuck] #1105182
11/01/11 04:25 PM
11/01/11 04:25 PM
Redding,CA USA
Redding,CA USA
Oh another thing I uncorked the exhaust and only picked up about 5 hundredths and .5 mph. I'm hoping for my 11 sec pass so mabey theres alittle more in it to get me there.
Re: More progress and another new best! [Re: 383man] #1105183
11/01/11 04:26 PM
11/01/11 04:26 PM
Redding,CA USA
Redding,CA USA
Ron I'm going to have to hire a photographer I only got about three pic's of my car since 1997.
Re: More progress and another new best! [Re: Mr.Yuck] #1105184
11/01/11 05:11 PM
11/01/11 05:11 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I think his 60 ft. already looks pretty good when compared to his ET. By comparison, my car runs 12.0's and typically 60's right at 1.75, with a best of 1.746 on a 12.06 / 112.98 run. If he's 60-ing @ 1.67, I think he's already got the launch to go 11's, especially with the big-end charge that should come with 1500 cfm worth of carburetion. But again, the 109mph seems a tad on the low end for 12.20, I think its the big end that's hurting him right now. I'd try taking a little timing out of it (39 is on the high side of what wedges usually like), and also.... as the saying goes, Lean is Mean. Jetting up at the track without opening the exhaust might be going in the wrong direction ????. (But then again, what do I know.... )
Bench racing season is in full swing here.....
Re: More progress and another new best! [Re: StealthWedge67] #1105185
11/01/11 05:23 PM
11/01/11 05:23 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
seemed my old 440 coronet like to 60 foot in the 1.68 range and run 12.90's. If I went over 1.70 it'd run 13.0. This car 60 foot is at 1.60 and is in the mid 11's. I want to drop it to 1.55 and see if I can pull an 11.teen. I think if he got his 60 down to 1.60ish it will run 11's pretty easy. I wonder if running w/o a hood is hurting him?
Re: More progress and another new best! [Re: Mr.Yuck] #1105186
11/01/11 05:37 PM
11/01/11 05:37 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
His 60 is about average for the et. I would say 12.20's is not a bad et for 109 mph. Ron
Re: More progress and another new best! [Re: 383man] #1105187
11/01/11 05:46 PM
11/01/11 05:46 PM
Redding,CA USA
Redding,CA USA
I think my engine is not pulling as hard as it should be on the big end. Also I was hoping to pick up 2-3 tenths when uncorking the 2 1/2" full exhaust system.
Re: More progress and another new best! [Re: 440charger500] #1105188
11/01/11 08:04 PM
11/01/11 08:04 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
you should have. what's the fuel pressure at the stripe? what are you shifting at?
Re: More progress and another new best! [Re: Mr.Yuck] #1105189
11/01/11 11:08 PM
11/01/11 11:08 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
I was running identical times in a street 64, I figured the cam was too small(mopar .528) or the gear was too high(4.56). I did end up getting 12.04 at 110 with all the goodies at the end of the year (no alt, no air cleaner, good air,etc.) That was with a 1.639 60'.(5500 stall)
Re: More progress and another new best! [Re: Mr.Yuck] #1105190
11/02/11 12:12 AM
11/02/11 12:12 AM
Redding,CA USA
Redding,CA USA
Dont know the fuel pressure at the stripe but its set @ 9 psi. I shift @ 5800 and cross the finish line at 6000. Tried shifting at higher rpms and the car slows down. The comp 285hl hyd cam and 906's are done making power before 6000 rpm.
Re: More progress and another new best! [Re: 440charger500] #1105191
11/02/11 01:19 AM
11/02/11 01:19 AM
One real easy way to see if you have enough fuel delivery is to jet the carbs up( a little at a time) until the car starts to slow down in the 1/4 MPH If it gets to a jet size that dooesn't change and still goes the same MPH fix the fuel delivry problem Been there, done that Mine was to small of a fuel filter size element once and the needles and seats being to small the next time Lots of gremlins out there messing with us drag racers
Re: More progress and another new best! [Re: 440charger500] #1105192
11/02/11 04:43 AM
11/02/11 04:43 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Lifter pump up?
Re: More progress and another new best! [Re: RemCharger] #1105193
11/02/11 08:04 AM
11/02/11 08:04 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
are you running air filters in that bug catcher? if so take them out and give it a wack. Those little things do not flow that great.
Re: More progress and another new best! [Re: Mr.Yuck] #1105194
11/02/11 09:11 AM
11/02/11 09:11 AM
Utah
topbrent Offline
topbrent  Offline
Utah
Any chance you are floating the valves?
Re: More progress and another new best! [Re: StealthWedge67] #1105195
11/02/11 10:07 AM
11/02/11 10:07 AM
Wisconsin
BLONDE BARRACUDA Offline
Wisconsin
I agree
Re: More progress and another new best! [Re: Mr.Yuck] #1105196
11/02/11 02:11 PM
11/02/11 02:11 PM
Redding,CA USA
Redding,CA USA
I've got a K&N 18" x 4" oval filter fabbed into the bugcatcher, mabey I will try to remove it and make some passes. Oh and I've got good Isky valve springs and there is no valve floating. Mabey my carter mechanical pump cant keep up with the 2 750's at the higher rpm. Hmm
Re: More progress and another new best! [Re: Cab_Burge] #1105197
11/02/11 02:16 PM
11/02/11 02:16 PM
Redding,CA USA
Redding,CA USA
CAB I started at 76 jets and everytime I have gone up 2 sizes I have picked up et and mph. I'm at 80 sq now and want to try 82's and mabey a smaller high speed air bleed. Its a B*^$ch changing jets so I hope I find the right ones on the next try.
Re: More progress and another new best! [Re: 440charger500] #1105198
11/02/11 06:39 PM
11/02/11 06:39 PM
Real North Cal.
66er Offline
66er  Offline
Real North Cal.
Great job Anthony, Your car has come a long way. BTW an elactric fan and water pump was good for two tenths for me. Just sayin
