Disc brakes A body,WILWOOD or scarebird? #1104346
10/30/11 09:07 PM
10/30/11 09:07 PM
Amherst,NY
challengermike Offline OP
Amherst,NY
Im going to be putting disc brakes on a 72 dart i just bought.I cant seemed to decide which route to go,WILWOOD DISC BRAKE kit or go with the scarebird conversion.I want to stay with the small bolt pattern front wheels,Centerline 15x3 or 15x4s,not sure which width.It seems like the scare bird kit would be alot cheaper,but that worries me alittle.Any thoughts?
http://www.ebay.com/itm/370548530298?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
http://www.ebay.com/itm/400218429944?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Re: Disc brakes A body,WILWOOD or scarebird? [Re: challengermike] #1104347
10/30/11 09:24 PM
10/30/11 09:24 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
scarebirds are affordable and you can buy everything you need at your local autoparts.... but if you want the wow factor and performance go wilwood
Re: Disc brakes A body,WILWOOD or scarebird? [Re: challengermike] #1104348
10/30/11 09:27 PM
10/30/11 09:27 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
I have the sacrebird setup on my '72. It works great and replacement parts are right off the shelf from anywhere. That was the deciding factor for me.
I didn't have any problems setting up the proportioning valve- I used a stock disc one with an aftermarket adjustable knob style after it. My 275/60-15 tires are harder to lock up than the stock skinnies anyway.
Be careful not to use too big of a m/c bore. I originally put my kit together with an aluminum mc a bit larger than 1" bore and got a fairly wooden pedal. I think my new mc (smaller) is around 1 1/32 or something. Works good but I'm a big dude.
The initial cost and the parts availability is what scared me off from wilwood, ssbc, etc. My 73 dart I converted to 5x4.5" big bolt single piston brakes and they work awesome too, but I didn't want big bolt on my 72 demon.
Good luck
Rdr
Re: Disc brakes A body,WILWOOD or scarebird? [Re: radar] #1104349
10/30/11 09:32 PM
10/30/11 09:32 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
There's also Engineered Components, but I don't know if they offer them in the 4.0" pattern. They're around $550 IIRC.
Re: Disc brakes A body,WILWOOD or scarebird? [Re: topside] #1104350
10/30/11 10:09 PM
10/30/11 10:09 PM
Amherst,NY
Amherst,NY
I guess i will try the scarebird kit then.
Re: Disc brakes A body,WILWOOD or scarebird? [Re: challengermike] #1104351
10/30/11 11:14 PM
10/30/11 11:14 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Iput the Wilwood HD kit on the front of my Demon.It stops great.I added the M/Cyl from Ehrenberg and left the rest as it came from the factory(prop valve lines etc.)The car isgoing back to street duty and the Wilwoodswill work fine there too.I went with the HD kit as my Demon has a 440 in it.
Nautilus Racing-
Re: Disc brakes A body,WILWOOD or scarebird? [Re: Chris2581] #1104352
10/30/11 11:50 PM
10/30/11 11:50 PM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
I have a Wilwood kit that I picked up at Summit racing on clearence for $400. Its a bolt on for the 9" drum brake spindle. Thats the reason I got it. It allows the use of either bolt pattern and 4 piston calipers. I have nothing but good things about the scarebird kit, so I wouldn't worry about that as an option. Plus, like said above, you can get parts at your local parts stores.
Re: Disc brakes A body,WILWOOD or scarebird? [Re: Chris2581] #1104353
11/01/11 08:34 AM
11/01/11 08:34 AM
Amherst,NY
Amherst,NY
Mines gong to have a 499 rb in it.So i think i might go with the scarebird kit and get some drilled and slotted rotors and some ceramic pads.Where did everybody get there disc brake prop valve from the junkyard off another a body?Also what master cylinder should i order?late a body?
Re: Disc brakes A body,WILWOOD or scarebird? [Re: challengermike] #1104354
11/01/11 08:53 AM
11/01/11 08:53 AM
Frederiction. New Brunswick ,C...
RTshaker Offline
RTshaker  Offline
Will the" scare bird kit" increase front track width beyond stock ?
Re: Disc brakes A body,WILWOOD or scarebird? [Re: RTshaker] #1104355
12/04/11 08:47 PM
12/04/11 08:47 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
to answer your question it will increase the track width less then the thickness of the rotor hat..
Re: Disc brakes A body,WILWOOD or scarebird? [Re: Dakota_Don] #1104356
12/05/11 11:18 AM
12/05/11 11:18 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
What rotors does the scarebird use to keep the 4" bolt circle ?
Re: Disc brakes A body,WILWOOD or scarebird? [Re: challengermike] #1104357
12/05/11 11:51 AM
12/05/11 11:51 AM
AndyF Offline
AndyF  Offline
Wilwood or Scarebird? Wow, talk about between a rock and a hard spot.
Re: Disc brakes A body,WILWOOD or scarebird? [Re: JohnRR] #1104358
12/05/11 12:06 PM
12/05/11 12:06 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
The scarebird kit uses a shelf (forgot application probably on their website) rotor with an insert to fill the center hole (dodge spindle is smaller) and they give you a pattern to drill out the boltpattern.
Re: Disc brakes A body,WILWOOD or scarebird? [Re: radar] #1104359
12/05/11 03:29 PM
12/05/11 03:29 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
That's what I thought , no thanks to that .
Re: Disc brakes A body,WILWOOD or scarebird? [Re: JohnRR] #1104360
12/05/11 04:37 PM
12/05/11 04:37 PM
AndyF Offline
AndyF  Offline
Come on John, it isn't that tough. You just put the rotor down in the mud so to hold it firm, then you use a hand held drill with a rusty drill bit. If you don't have a big enough drill bit you just wallor out the hole a little bit by chewing on the sides. The wheels might wiggle a bit but nobody cares about that.
Re: Disc brakes A body,WILWOOD or scarebird? [Re: AndyF] #1104361
12/05/11 04:42 PM
12/05/11 04:42 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
You're right , what was I thinking ....
I already have a set of rotors and hubs that were home drilled for large bolt pattern , wasn't done by me , with a small amount of runout. i'm going to return them back to SBP at some point so no big deal.
Re: Disc brakes A body,WILWOOD or scarebird? [Re: JohnRR] #1104362
12/05/11 06:16 PM
12/05/11 06:16 PM
Amherst,NY
Amherst,NY
the rotor they want you to use is for a toyota previa.I bought every thing but havn't installed it yet.
Re: Disc brakes A body,WILWOOD or scarebird? [Re: challengermike] #1104363
12/05/11 08:41 PM
12/05/11 08:41 PM
North of the Motor City
DartGTDan Offline
DartGTDan  Offline
Don't know about the cost factor, but I used SSBC on my '71 Dart GT. Has the option of 5 on 4" or 5 on 4.5" bolt pattern. Very complete kit & instructions. I paid ~$830 to my door from Mancini about 5 years ago. No trouble to date. Just food for thought.
Re: Disc brakes A body,WILWOOD or scarebird? [Re: DartGTDan] #1104364
12/05/11 09:45 PM
12/05/11 09:45 PM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
It all depends on what you think will work best for you. Wouldn't surprise me one bit if there isn't someone wondering how to convert their SRT8 to 9" drums w/14" steelies...
Re: Disc brakes A body,WILWOOD or scarebird? [Re: Bill MeLater] #1104365
12/06/11 02:55 AM
12/06/11 02:55 AM
Philadelphia
radar Offline
radar  Offline
Philadelphia
I definitely understand the appeal of parts that work well and don't need any work, but is it that hard to centerpunch and drill five holes? How accurate are the parts we buy from overseas for applications like this? Do you think the guy working on a drill press with a worn out jig in china cares more than you do about getting it dead on? Is it only ok to use parts that bolt on how you get them in the mail from summit?
I always thought making stuff work and solving problems with simple tools was one of the best parts of hot rodding and also a skill Americans are rapidly losing. It was pretty easy to check the runout once the rotors were mocked up. Not everybody has a thousand bucks laying around for lightweight billet parts.
I happen to like my scarebird setup and if I hadn't bought it I probably would have cobbled together a similar setup without the luxury of a mill, lathe, and foundry. It's the same bull crap with Harleys- people pay over a thousand bucks for billet aluminum brake setups that half the time are plumbed to the wrong diameter master cylinder. My shovelhead is upgraded from 10" single piston disc brakes to 11" rotors with four and six piston tokico brakes off crashed crotch rockets on eBay. It stops awesome and the brackets are home made.
Why all the mud slinging?
